A low level exception occurred in: ImporterMPEG (Importer:37)
Jul 17, 2018 Jul 17, 2018
PP finally starts working after crashing constantly and now this with the new update: 12.1
A low level exception occurred in: ImporterMPEG (Importer:37)  - rendering the imported footage unusable.
Nothing else has changed barring the AE and AME updates.
Anybody else with this?
Error or problem
59.8K
Community Expert , Jul 19, 2018 Jul 19, 2018
If it was working on previous versions, roll back, I don't think this version of Premiere on this generation of your CPU
will handle H.264 files normally ... are you on the latest premiere pro update released days ago ? if no try to update
premiere to the latest, if yes, roll back to previous working versions
01. Delete all your Media Cache files
02. Delete all render files (go to Sequence - Delete Render Files)
03. Manually delete all Video and Audio Previews (render files, location related to scratch disks)
Thanks for the reply but unfortunately this didn't help in my case and maybe not related but no Premiere is crashing on startup 90% of the time and when it doesn't it will crash on save. Love Adobe products
Try Jeff's suggestions in this thread :
Low Level Exception??
Jul 18, 2018 Jul 18, 2018
After 10 crashes when PP actually started correctly - no - unfortunately this also didn't work. Thank you for the suggestion.
can you share your system specs in details ?
Operating System: Windows 10 Pro 64-bit (10.0, Build 16299) (16299.rs3_release_svc_escrow.180502-1908)
                 Language: English (Regional Setting: English)
      System Manufacturer: ASUS
             System Model: All Series
                     BIOS: 1601
                Processor: Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz (12 CPUs), ~3.4GHz
                   Memory: 32768MB RAM
      Available OS Memory: 32676MB RAM
                Page File: 7131MB used, 30408MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
Card name: NVIDIA Quadro M4000
        Manufacturer: NVIDIA
           Chip type: Quadro M4000
            DAC type: Integrated RAMDAC
Anything else?
Are you running the latest update 12.1.2 ?
Deleting Media Cache is required before updating, try deleting media cache, uninstall premiere,
install premiere .. sorry im trying my best to help you out
I appreciate your help!
Yes the very latest update. I will try that hopefully today. I need to get on with other work after losing time (thanks again Adobe) maybe I won't reply till tomorrow about this fix.
Thanks again for your help.
no problem, we are here to help you
Have tried this solution twice - yesterday and now with the same result - still has the low-level exception problem and then crashes.
There is a specific file or files that are corrupt
try importing into after effects or media encoder and export to a different format
.mov and .avi versions import and play OK. Mp4 seems to be the problem.
Except when I try to save and then nothing works.
the files that seem to cause the problem, try to import them into after effects or media encoder,
then export them from there and import back to premiere, what happens ?
Yes that is what I did before. AE and AME both accept the files with no problems and export normally as they always have even with the MP4's that are causing Premiere to crash. So really it is only Premier that is having the issues after the upgrade with these files that were not a problem before the upgrade.
Please go to Edit - Preferences - Media - uncheck Enable accelerated H.264 Decoding
Restart
Let us know what happens
Only this on mine no "Enable accelerated H.264 Decoding" but no change even with this un-ticked.
I don't think your CPU supports accelerated H.264 decoding
From Adobe help concerning the latest update and hardware acceleration :
Hardware acceleration updates
Hardware-accelerated H.264 and HEVC decoding on Mac
Hardware-accelerated H.264 and HEVC decoding is now supported on MacBook Pro and iMac Pro machines with Mac OS 10.13. Hardware decode acceleration is automatically selected as the default option (Preferences > Media > Enable hardware accelerated decoding) in PremierePro on Mac if the hardware supports it.
Windows Intel Hardware Encoding for MP4/HEVC
Hardware acceleration is now available on Windows 10 with 7th Generation (or later) Intel® Core™ processors and Intel Graphics enabled.
If your hardware supports it, then Hardware Accelerated is enabled in the Performance menu of the Export Settings dialog box.
If your system hardware does not support it, the Performance menu switches automatically to Software Only.
or since your files open on after effects and media encoder, export them from there to different formats
keeping the same settings and preserving quality
Thanks for your help over the past days. I unfortunately now have projects that have this problem that can't be opened in previous versions as they where saved while testing the latest. Of course the lesson learnt is not to trust Adobe and save all your files in different versions of the software. My processor is two years old according to Intel and my machine is fully specced to run all the other software I need. Surely Adobe don't see it as a good idea to disable everybody work with this update? Why doesn't disabling the hardware acceleration work?
Very annoying.
But when opening on newer versions didn't you have the option thaht pops up to save as a copy ?
Don't you still have Auto Saves from the previous version ?
One user at another thread was in contact with Adobe Care yesterday and they told him that engineers
are working on another major fix that will be released soon ... video files are becoming bigger and bigger
every day, with new technologies that really require hardware improvements and upgrades to accommodate
to the vast technical progress ... all other software are suffering as well ... seems like these are somehow
tough times that we will pass through ...
Yes - it does increment it but I must have saved over the original name instead. I found a hack here that actually works and is easy to fix the "newer version" issue so that is good.
software - How do I 'downgrade' an Adobe Premiere Pro project file to open in older versions? - Vide...
OK - well fingers crossed for the new version!
Yeah lets wait for the new improvements coming soon .... for now don't
update and finish your deadlines on previous versions and keep monitoring
the forums here during these tough times where technology is moving at
light speed...
