When moving photo's from a main folder to a sub folder by dragging and dropping photo's - the photo's appear to stay in the main folder as well be in the sub folder. If I delete the photo's in the main folder, they get deleted in the sub folder. What can I do to move photo's to folders and sub folders?
You have turned on the option "Show Photos in Subfolders". Turn it off. Click on the + sign to the right of Folders
Thanks so much - worked like a dream.....as you can tell....I am a newbie to Lightroom!
Since you are a newbie ... a suggestion ... don't use folders to organize, don't move photos from here to there, use keywords and other metadata to organize and search. There are a lot more benefits to organizing by keywords and metadata then using folders to organize.
When you are in the Library module, go to the Library menu option. There is an option there to show photos in subfolders. If you uncheck that option then when you move photos to subfolders they won't show in the parent folder anymore.
Thanks Jim - went right to where you pointed - unclicked it + sign....and now is working the way I had hoped.. Thanks for taking the time to helping me. I am still a rookie at Lightroom!
