So basically when i export a video, the audio seems fine but the footage is sped up. Any suggestions on how to solve the problem? the raw footage was fine as well as the playback on the timeline..
Post computer specs. OS. Premiere build, media used (please be specific: no just Premiere 2018 and mp4)
and screenshot export setting with left tab to output with visible image.
Sorry im new to this
aight so im using Windows 8.1 with 7.68 gb ram, intel core i5-4200U cpu and 64 bit processor
For premiere im using Premiere pro cc 2015
For my footage i used mp4 files which are 720 60fps
and here's my current export settings
Turn of max render (only if you have a dedicated Nvidia or amd graphics card, max bit depth if checked and frame blending.
Would have been nice if the left tab had a visible image instead of black.
Set sequence audio to 48.000.
And try again.
I dont have a dedicated graphics card. I've tried it anyways, checked off max render, frame blend and bit depth. I've also set the audio sequence too. I exported it and its still the same.e..
Check your Audio Hardware in the Preferences: set it to MME and input to none.
Yep its already set to MME. Not sure what you mean by setting my input to none, it only shows my mic.
Not sure about this but unplug your microphone and try again.
Im using my built in one...
