I'm trying to move a sequence from Avid Symphony to Premier to color it (because Avid Symphony sucks to color in) everything is transferring fine except for the 4k AVCIAV.MFX files. I get a corrupt or incompatible file format error. Is there a codec I can install to make this work?
I have not experienced this issue but have read posts that say the following suggestion helps:
Try moving those source files into a new folder with a different name.
Then try linking to those files that you located in a new folder.
Results?
MtD
haydonl,
Did you try what MtD suggested? Please let us know.
Kevin
