Hello,
In order to be faster, i wish to have a personalized icon in this windows:
In the right i wish to remove "raccolte" for example, and insert a folder i want. How can i do this?
Try a forum for MS Windows.
This has nothing to do with Acrobat. It's a system setting. As mentioned, try searching the web. It's important to mention your version of Windows, as these settings can vary.
if someone is interested, i went on here
Ok, the ms forum told me to advise the developer in order to do what i request
I think Microsoft are right. You cannot add folders unless the app gives you a way to do this. It is very unusual for an app to allow you to add new folders. You can make a feature request for Acrobat here Feature Request/Bug Report Form
They are wrong. This is not a setting of the application, but of the OS. What exact version of Windows are you using?
This is a standard system dialog, but the standard system dialog cannot be customized at an application or system level.
Correction: an expert administrator can edit the registry to edit what appears at the left; this is called the "places bar". This is a risky procedure and should only be done by an expert who understands how to repair the system if it is left destroyed or not bootable ! How to Customize the File Open/Save Dialog Box in Windows
