Hi Folks:
I just got a new system to edit on, and am having a problem where two of the four camera feeds from a live music shoot are not playing back correctly in a project. QuickTime .movs are fine, but mpeg .mov's and ,mts streams are playing back all green/purple, lined and wavy. Any ideas out there? Thanks so much, trying to learn the basics here and appreciate any leads. Thanks - TB
Hi HitCity,
Here you go: Green or purple streaks appear in the Source and Program monitors
Let us know how that goes.
Kevin
OK, it looks like I found the answer to my own question. Thank you LindaJM….
LindaJM May 23, 2018 6:58 AM (in response to shellss)
HERE'S THE SOLUTION FROM ADOBE: You have to change the video rendering setting.
Premiere Pro
File > Project Settings > General > Video Rendering and Playback > (choose from dropdown) Mercury Playback Engine Software Only
Media Encoder
File > Preferences > General > Video Rendering > (choose from dropdown) Mercury Playback Engine Software Only
This is a known bug in the current version and will be addressed in the next upgrade.
I spent two days with our IT department and 1 hour with Adobe support trying to figure this out. For now, the resolution is a pretty simple fix. No need to update any drivers, hardware, or software.
Its not a fix but a workaround
Which current build are you using?
Hi HitCity,
Kevin
