Hi Everybody,
why new version of adobe premiere make clip volume little bit louder?
Tested in Adobe CC 2017 and Adobe 2018 CC with same settings.
Fig. Premiere CC 2017 old version
Fig. Premiere cc 2018 12.1.1 new version
Kind regards
Tomas Svab
You're on a different frame. Audio levels change over time. So there's nothing to be determined with those posted images.
I can say that I've experienced no changes to clip volume when I updated PP.
Could you make an export of the same projet, first from cc17 then cc18 and compare the outputed volume on both ?
Best guess here is effects. Gain, Volume...something is different between the projects.
Clear of this issue yet, Tomas?
Kevin
Hello,
here is link with two raw video clips from camera. (B-roll, Interview)
Maybe works fine on yours systems.
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
This two clips was tested both versions with default settings.
Adobe 2018 version show audio levels 6 db higher.
Kind regards
Tomas Svab
