6 Replies Latest reply on Jul 26, 2018 6:25 AM by George_Salnik
    Table Cells breaking across page boundaries
    KevinBird1966 Level 1
      Having trawled through the archives, it seems that InDesign will only break tables on rows, not cells.
      I am importing a two-column, multi-page table from Word. Some of the paragraphs are very long and the current breaks are not desired. I could manually split the cells but this document will go through several revision cycles, which will no doubt change the flow/breaks at each revision. I can think of nicer things to be doing than manually re-flowing tables!!
      So, has anyone tried to script a solution? Is it even possible, or do I look at converting to text (although I have no idea how that would work either!).
      Suggestions, solutions or sympathy are all allowed!
      Kevin
