When i export to XML Final Cut File premiere doesn't work and show me a message of error within create XML file.
In to Final Cut Pro 7 or earlier, or FCP-X?
If FCP-X you need to convert the file:
Make sure you read the documentation about what will and will not transfer in this process.
MtD
Yes, I use that but the error is on premier that doesn’t create the file XML
Are you XMLing a single sequence or an entire project?
MtD
I select All project (I have all files in a fold) and next I go on Export -> XML for Final Cut
Test the exported XML by creating a new project and see if you can import that XML successfully.
Sometimes you will get an error dialog box when you export an XML that means there were things that Premiere could not translate into XML. You can dismiss that and check the XML.
MtD
I managed to create XML but I only selected the video sequence, i had to select only the video sequency but now i have another problem XD.... when SendToX import the file on FCPX the Sequence in the project of the GoPro films are black and i don't see anything....
Another question i filmed in 1080 60fps with the sun while ride moto but when i export the file with applied color correction with FCPX or Premiere, video is out of focus and details can be seen...
i did it, i had to select only the video sequency but now i have another problem XD.... when SendToX import the file on FCPX the Sequence in the project of the GoPro films are black and i don't see anything....
i can not export xml ~form premiere 2019
has error about "text" ~i can export xml video but text fault alway
