I use Cadence OrCAD software which has the ability to create Intelligent PDF's of the circuit diagrams. Once created you can click on parts in the ciruit to get their relevant properties, you can click and descend hierarchies (much like using the actual OrCAD software).I want to get these relevant properties and all interface data.Can I do this?
In Acrobat you can select the option to "Edit All JavaScript", which loads all JavaScripts in the document into a text editor, with some XML wrapping. It's going to be a bit difficult to parse the custom dialog code programmatically though.
moved from Forum comments to Acrobat General Troubleshooting
Without seeing a sample file it's pretty impossible to say, since we don't have access to this software you're talking about...
You can share it via Dropbox, Google Drive, Adobe Track & Send, etc., and post the link to it here.
you can down load the pdf as follow: Dropbox - bugle_sch_x1_2018_0704_1001 13.pdf
Are you sure you want to share this file? It clearly says on it that it's a restricted secret of HP...
The document contains links with JavaScript code.
So can I extract the JS
Sorry guys, I reuploaded the document Dropbox - bugle_sch_x1_2018_0704_1001 13_wrapper.pdf
You can't extract JS code using a script. It might be possible using a plugin, though. I know for sure it can be done using a stand-alone application, too, but it's not a simple task.
Thanks! So, what application can do this job ? Could you tell me more clearly? Thanks a lot!
It will have to be a custom-made application. For example, written in Java, or C++.
If you're interested, I could develop such a tool for you (for a fee). You can contact me privately via try6767 at gmail.com to discuss it further.
