Using Seamonkey 2.49.3 with Adobe PDF Plug-In For Firefox and Netscape 17.11.30080 plugin
Just installed Acrobat 2017 Pro.
Download pdf file gives following error:
(p.s.: it works OK with IE and Firefox. Also, checked that Acrobat is the default pdf program)
[moved from Installing, Updating, & Subscribing to Acrobat to PDF workflow]
[And then from there to Acrobat General Troubleshooting​ by a different moderator]
Hi Mdgny,
Sorry for the delayed response.
As mentioned in the description above, you are using Adobe PDF Plug-In with Seamonkey 2.49.3 which is not supported. Refer to this help document for more info: Web browsers and PDFMaker applications compatible with Acrobat and Reader
You may check with Seamonkey and see what they have to suggest.
Shivam
