Layer merge using Batch processing in Acrobat pro
Contributor ,
Jul 11, 2018 Jul 11, 2018
I want to merge layers using batch processing tool. Could some please help this. I have 200 more pdf files. Each and every file takes more time to merge using layer panel. Please help some one.
General troubleshooting
1.5K
Jul 12, 2018 Jul 12, 2018
There's a "Flatten Layers" command under the Content panel in the Action Wizard. Have you tried it? Make sure to have a backup copy of the files, just in case it's not what you had in mind, as this process is often not reversible.
Contributor ,
Flatten layers and Merge layers option works similar condition.
Flatten:
Flatten means all the layers are merged as like normal text and the layers will removed in layer panel.
Merging example for my requirement:
My pdf contains 5 seperate layers for Questions, Answers, Guide and Grids, line numbers and Marks & Bleeds.
Now i want merge as in below:
Guide and Grids, line numbers and Marks & Bleeds layers need to merge and naming should be ‘Guides and Grids’
Answer layer should in stay separately
Question layer should in stay separately
Finally i need 3 Layers in pdf.
I am usually merge the above activity through Acrobat pro by manually. Now i have 200 more pdf files. Could you please advice is there any automation is available in Acrobat Pro for merging multiple pdf files with single run.
Please let me know if anything is unclear.
Santhosh
[personal info removed by mod]
Adobe Employee ,
HI Santhoshr,
As try 67 mentioned above, you can try flatten layers option under Action wizard using following steps:
Launch Acrobat > click Tools > type action and click action wizard
New action > content > flatten layers > double-cllick to add it to the right-hand pane > save
Let us know if you have further questions.
Shivam
Contributor ,
Flatten:
Santhosh
Contributor ,
Jul 19, 2018 Jul 19, 2018
I dont get anwer on this. Could some one please give solution for this?
Santhosh
You can use the Action to process all files at once.
Contributor ,
Aug 02, 2018 Aug 02, 2018
i don't need to flatten it. I want to merge the layers.
Oct 16, 2019 Oct 16, 2019
Hi ! do you find an issue ?
