リンクをクリップボードにコピー
コピー完了
webフォントを全て標準フォントに変更したのにエラーが出てパブリッシュできません。
使用フォントはヒラギノ明朝Pro W3とOsaka一等幅 です。
解決方法を教えて下さい。
Ok, glad we went through the first one.
Now for the next I must suggest you to use "upload all files" option rather then "modified files only"
You get this option while uploading the site. If you are uploading though a third party tool, then deleting the all the files form server and re uploading the site shall work out.
Please update how it goes.
Ankush
リンクをクリップボードにコピー
コピー完了
Hi there,
Sorry for the issues you are dealing with web fonts.
If I understand the issue correctly, you are saying that the web fonts are getting changed after you export the site, correct?
Can you please tell what process are you following to add the web fonts in your system (A screen shot will be enough)?
Also have you checked with the font vendor weather it is working at their end?
Ankush
リンクをクリップボードにコピー
コピー完了
Thank you for your answer.
Sorry, my explanation about my issue was poor.
My issue is that when I tried to publish my web site, I got error "error code 400"(saying can't finish because some web fonts can't be used.)
So I changed all the web fonts used to standard font.(Hiragino Mincho Pro W3 and Osaka)
But it did't work.
Please tell me how to solve this issue.
I apologize for my poor English. Thank you.
リンクをクリップボードにコピー
コピー完了
Thanks for providing me with the details.
Have you checked for any H1, H2.....tags or any paragraph styles applied to it.
If yes please try removing them all and then see if works.
リンクをクリップボードにコピー
コピー完了
Thank you, it worked.
But, I got new issue...
Uploading was finished but the changes did not be reflected on the website.
Thank you.
リンクをクリップボードにコピー
コピー完了
Ankush
リンクをクリップボードにコピー
コピー完了
Thank you.
But I already tried use "upload all files" option. It din't work.
Anyway, I will try to delete the all the files form server and re uploading the site.
I wii be busy, so I will be back in about 2 days.
Thank you.
リンクをクリップボードにコピー
コピー完了
Hi. I got new problem. The website was not updated though uploading was finished.
I
リンクをクリップボードにコピー
コピー完了
Thank you for the update.
Have you tried deleting the cache of your browser and then loading the site?
リンクをクリップボードにコピー
コピー完了
Yes.I had. But didn't work.
リンクをクリップボードにコピー
コピー完了
I tried upload after closing app, and it worked!
I can see my website now correctly.
Thank you!!
