I have a couple drawings with slightly different dimensions. When I want to compare which dimensions I changed, I use the compare document tool. When I have it all set up, I can click on the changes, and they show up in a pop-up picture. However, this picture is too small for me to read the dimensions, and when I try to click on the picture, it disappears when my cursor goes over it.
Hi Cyrusfunk,
As per the issue description mentioned above, you are facing issue when trying to compare files in Acrobat, is that correct?
Could you let us know if you are referring to the pop-up window as seen in the screenshot below?
If yes, sorry to say but this functionality is not available.
Let us know if that is not the case.
Shivam
Hello Shivam,
I think the pop-up I am referring to is different than the comment box that also can show up.
For example, in these two images, the exclamation mark is the only change. I can click on it and it shows that this is the only change. However, on more complicated drawings, sometimes that pop-up window is too small for me to see the dimensions and other small details.
Cyrus
If this is not available in the current version of Acrobat, then please make a feature request at User Voice where the engineers will see it and you can track it. It's a great idea!
Acrobat for Windows and Mac: Top (1698 ideas) – Share your feedback on Acrobat DC
It seems the size of the pop-up depends upon on the size of the text added on the pdf (please find attached the screenshot for the same) As Jane mentioned above, you may share your feedback to the team using the link.
Thanks.
Shivam
