I added some new profiles to the Camera Raw ->Settings directory, and they now show up in ACR but not showing up in Lightroom (yes, I'm using a RAW file). I've installed profiles before and they work fine in LR. Any Idea why they would appear in ACR but not Lightroom?
Thanks very much for any help!
Bart
Hi Bart,
As the profiles are not appearing in Lightroom, could you please let us know which exact version of Lightroom and opearting system you're working on?
Also, what is the file format of the profiles?
Could you try the steps on this link and let us know if it helps? https://lutify.me/support/documentation/how-to-install-lutify-me-luts-into-adobe-photoshop-lightroom...
Sahil
Hi Sahil,
Thank you for replying.
I'm using the most recent version of everything: Lightroom 7.4 [ 1176617 ] on Windows 10. The profiles are .xmp files. I moved the files into the Settings folder, as per normal. The profiles are now visable and useable in Camera Raw, but they are not showing up in the Lightroom Profile Browser. I have added other profiles in the past, and they show up in both ACR and LR.
This seems very odd, but there must be some simple solution that I'm overlooking.
Bart
Are you putting them in the right folder? They are supposed to go in C:\Users\[Your Username]\AppData\Roaming\Adobe\CameraRaw\Settings and not in the more general system folder that is also present. Lightroom only looks for profiles in the local folder in your own account's directory.
Have you tried restarting LR after adding in ACR?
Hi Tony,
Yes, I have restarted LR several times. Even restarted the computer.
Bart
Hi Jao,
Yes, the files are in the right folder. I have installed other profiles (LUTs) and they have worked properly. And the profiles in question work in Camera Raw, just not in Lightroom.
Here are screenshots I just made in ACR and LR. Below is the Profile panel in ACR. The profiles I just installed are circled in yellow, so everything is fine in ACR.
This is the Profile panel in Lightroom, showing that the profiles circled in yellow (above), which SHOULD be there, are not there.
What the heck is going on?
