Whenever I go to open this file I get this error message every time.
Is their anyway to fix this so I can open the file, without using 3rd party tools?
Hi Joshuaa,
As per the issue description mentioned above, you are facing issue when trying to open a pdf in Acrobat, is that correct?
Please try the troubleshooting steps given in the following help documents:
Resolve damaged document error when opening PDF files
You may also refer to the following forum threads discussing the similar issue:
File is damaged and could not be repaired...
The file is damaged and could not be repaired
Shivam
The problem is occurring when ever I try to open the file in Acrobat, now I tried going through the HKCU path, now I don't now much about that stuff, I do my best to stay away from editing anything in their.
I go as far as this HKCU\Software\Adobe\Adobe Acrobat\2017\AVGeneral\
Their was no bValidateBytesBeforeHeader, is that something I have to create myself, if so can you explain to me carefully what I have to do?
Hi Joshuaa,
I have sent you a private message, please check the inbox for the same.
Shivam
