When i am working in premiere pro cc , premiere pro cc is closing. why can not use it ? this error is to be often.
Process: Adobe Premiere Pro CC 2018 [30689]
Path: /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
Identifier: Adobe Premiere Pro CC 2018
Version: 12.1.2 (12.1.2)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Premiere Pro CC 2018 [30689]
User ID: 501
Date/Time: 2018-08-07 15:19:07.163 +0300
OS Version: Mac OS X 10.13.6 (17G65)
Report Version: 12
Anonymous UUID: AD8CAE94-CADC-90D0-2960-6DC040D16D10
Sleep/Wake UUID: 2D942A1A-45A0-436E-BFBF-A91B169CE22B
Time Awake Since Boot: 220000 seconds
Time Since Wake: 13000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000001
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.HandlerTimeline.framework 0x000000012047f158 HandlerTimeline::SelectionEditor::GetEmptySpaceSelection() + 24
1 com.adobe.HandlerTimeline.framework 0x00000001205b0d08 HandlerTimeline::TrackView::OnTrackInfoChanged(ASL::InterfaceRef<BE::ITrack, BE::ITrack>, dvamediatypes::TickTime const&, dvamediatypes::TickTime const&) + 56
2 com.adobe.HandlerTimeline.framework 0x00000001203e9f8e HandlerTimeline::TrackView::ListenToMessage(ASL::Message const&) + 318
3 com.adobe.ASLMessaging.framework 0x000000010319688c ASL::BroadcastMessageInner(ASL::BroadcastMessageRecord const&) + 44
4 com.adobe.Frontend.framework 0x000000010275e1f9 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 41
5 com.adobe.ASLMessaging.framework 0x0000000103196127 ASL::Broadcaster::BroadcastMessage(ASL::Message const&) + 1047
6 com.adobe.ASLMessaging.framework 0x000000010319c9ba ASL::StationUtils::BroadcastMessage(dvacore::utility::ImmutableString const&, ASL::Message const&) + 42
7 com.adobe.Backend.framework 0x0000000105207759 BE::MessagePool::BroadcastExternalMessages() + 201
8 com.adobe.Backend.framework 0x00000001051fa799 BE::Executor::Execute(ASL::InterfaceRef<BE::IAction, BE::IAction>, ASL::InterfaceRef<BE::IProperties, BE::IProperties>, ASL::InterfaceRef<BE::IUndoStack, BE::IUndoStack>, bool) + 1689
9 com.adobe.Backend.framework 0x00000001051f9f5a BE::Executor::Execute(ASL::InterfaceRef<BE::IAction, BE::IAction>, ASL::InterfaceRef<BE::IProperties, BE::IProperties>) + 106
10 com.adobe.Backend.framework 0x0000000105200784 BE::ExecutorImpl::Execute(ASL::InterfaceRef<BE::IAction, BE::IAction>, ASL::InterfaceRef<BE::IProperties, BE::IProperties>) + 132
11 com.adobe.Mezzanine.framework 0x000000010f19f313 MZ::ExecuteAction(ASL::InterfaceRef<BE::IExecutor, BE::IExecutor>, ASL::InterfaceRef<BE::IAction, BE::IAction>, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 435
12 com.adobe.Mezzanine.framework 0x000000010f665885 MZ::SequenceActions::RemoveItemsInternal(ASL::InterfaceRef<BE::ISequence, BE::ISequence>, ASL::InterfaceRef<BE::ITrackItemSelection, BE::ITrackItemSelection>, bool, bool, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >) + 629
13 com.adobe.Mezzanine.framework 0x000000010f665a2d MZ::SequenceActions::RemoveItems(ASL::InterfaceRef<BE::ISequence, BE::ISequence>, ASL::InterfaceRef<BE::ITrackItemSelection, BE::ITrackItemSelection>, bool, bool) + 157
14 com.adobe.Mezzanine.framework 0x000000010f628905 MZ::Sequence::ClearItems(bool, bool) + 117
15 com.adobe.HandlerTimeline.framework 0x000000012062053c HandlerTimeline::TrackViewAreaCommander::OnEditClear(UIF::Command const&) + 1132
16 com.adobe.HandlerTimeline.framework 0x0000000120649baf HandlerTimeline::TrackViewAreaCommander::ObeyCommand(UIF::Command const&) + 287
17 com.adobe.HandlerTimeline.framework 0x00000001205eedda HandlerTimeline::TrackViewArea::ObeyCommand(UIF::Command const&) + 26
18 com.adobe.UIFramework.framework 0x000000010dcb1eb5 UIF::Commander::PostCommandInner(UIF::Command const&, bool&) + 1157
19 com.adobe.Frontend.framework 0x000000010275e1f9 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 41
20 com.adobe.UIFramework.framework 0x000000010dcb19a2 UIF::Commander::PostCommand(UIF::Command const&) + 114
21 com.adobe.UIFramework.framework 0x000000010dd9168b UIF::ShortcutManager::TranslateKeyboardEvent(UIF::KeySpec const&, bool, bool) const + 619
22 com.adobe.UIFramework.framework 0x000000010dd93f0f UIF::ShortcutManager::DispatchKeyboardEvent(dvaui::ui::KeyboardEvent const&, bool) const + 191
23 com.adobe.UIFramework.framework 0x000000010de739f9 UIF::TopLevelWindowImpl::UI_DoKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 121
24 com.adobe.dvaui.framework 0x0000000100c3d0ba dvaui::ui::UI_Node::UI_DispatchKeyboardEventToNode(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 138
25 com.adobe.dvaui.framework 0x0000000100c3fd99 dvaui::ui::UI_Node::UI_DispatchKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 409
26 com.adobe.dvaui.framework 0x0000000100cb0803 dvaui::ui::OS_Node::UI_DispatchKeyboardEventFromOS(dvaui::ui::OS_Event*) + 147
27 com.adobe.dvaui.framework 0x0000000100cb6f24 dvaui::ui::OS_View::UI_DispatchPlatformKeyDownEvent(dvaui::ui::OS_Event&) + 148
28 com.adobe.dvaui.framework 0x0000000100cb66f1 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 305
29 com.adobe.dvaui.framework 0x0000000100cb6596 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 22
30 com.adobe.dvaui.framework 0x0000000100cb7d76 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 70
31 com.adobe.dvacore.framework 0x000000010012116c int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
32 com.adobe.Frontend.framework 0x000000010275e1f9 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 41
33 com.adobe.dvacore.framework 0x0000000100121223 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::function0<void>, bool*) + 99
34 com.adobe.dvacore.framework 0x0000000100121b61 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 161
35 com.adobe.dvaui.framework 0x0000000100cc6d3c -[DVAMacContainerView keyDown:] + 156
36 com.apple.AppKit 0x00007fff2d5d143d -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 5040
37 com.apple.AppKit 0x00007fff2d5cfc70 -[NSWindow(NSEventRouting) sendEvent:] + 497
38 com.apple.AppKit 0x00007fff2d431236 -[NSApplication(NSEvent) sendEvent:] + 2462
39 com.adobe.dvaui.framework 0x0000000100cbcd8b -[DVAMacApplication sendEvent:] + 619
40 com.adobe.Frontend.framework 0x000000010281e2dd -[PremiereCocoaMacApplication sendEvent:] + 349
41 com.apple.AppKit 0x00007fff2cc918b5 -[NSApplication run] + 812
42 com.adobe.Frontend.framework 0x00000001028200fd FE::MacApplication::RunSelf() + 45
43 com.adobe.Frontend.framework 0x000000010271ae80 FE::Application::Run(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 8768
44 com.adobe.Frontend.framework 0x0000000102822945 FE::AppMain(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 405
45 com.adobe.Frontend.framework 0x00000001028240c3 FE::Run(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int) + 659
46 com.adobe.PremierePro.CC12 0x0000000100007bc0 main + 896
47 libdyld.dylib 0x00007fff5753e015 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff5768fbea kevent + 10
1 com.adobe.dvatransport.framework 0x000000010412fbac boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 268
2 com.adobe.dvatransport.framework 0x000000010412f65c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 380
3 com.adobe.dvatransport.framework 0x000000010412f325 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 181
4 com.adobe.dvatransport.framework 0x0000000104124c42 SkyConnectionEnv::MainLoop() + 162
5 com.adobe.dvatransport.framework 0x00000001041245f9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
7 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
8 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
9 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff5768ea16 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff57857589 _pthread_cond_wait + 732
2 com.adobe.dvatransport.framework 0x000000010412f5e7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 263
4 com.adobe.dvatransport.framework 0x000000010413a75a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_io_service_runner>::run() + 42
5 com.adobe.dvacore.framework 0x00000001001b21e3 boost_asio_detail_posix_thread_function + 19
6 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 3:
2 com.adobe.dvacore.framework 0x00000001000f3831 boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 65
3 com.adobe.dvacore.framework 0x00000001000f356b dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 171
4 com.adobe.dvacore.framework 0x000000010020eb41 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::__1::auto_ptr<dvacore::threads::AllocatedFunctionT<boost::function<void ()> > >&, int) + 145
5 com.adobe.dvacore.framework 0x000000010020d029 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 153
6 com.adobe.dvacore.framework 0x000000010020a16f dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 367
7 com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
8 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
9 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
10 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 4:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff5768ec32 __recvfrom + 10
1 VulcanMessage5.dylib 0x000000010a6dc2b8 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2 VulcanMessage5.dylib 0x000000010a6db67c vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3 VulcanMessage5.dylib 0x000000010a6da974 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4 VulcanMessage5.dylib 0x000000010a6da838 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5 VulcanMessage5.dylib 0x000000010a6d5477 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6 VulcanMessage5.dylib 0x000000010a6d5f06 vcfoundation::io::Serializer::InternalDeserialize() + 30
7 VulcanMessage5.dylib 0x000000010a6d589f vcfoundation::io::Serializer::Deserialize() + 9
8 VulcanMessage5.dylib 0x000000010a6d9924 vcfoundation::ncomm::Connection::ReadIn() + 22
9 VulcanMessage5.dylib 0x000000010a6d937d vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10 VulcanMessage5.dylib 0x000000010a6d906a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11 VulcanMessage5.dylib 0x000000010a6d8fbd vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12 VulcanMessage5.dylib 0x000000010a6cc7f8 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13 VulcanMessage5.dylib 0x000000010a6cba36 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14 VulcanMessage5.dylib 0x000000010a6da1bc vcfoundation::thread::AbstractThread::Run() + 72
15 VulcanMessage5.dylib 0x000000010a6dc0b9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
17 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
18 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 5:
2 com.adobe.dvacore.framework 0x00000001000f397a boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 74
3 com.adobe.dvacore.framework 0x00000001000f3647 dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 391
Thread 6:
Thread 7:
Thread 8:
0 libsystem_kernel.dylib 0x00007fff5768525e semaphore_timedwait_trap + 10
1 com.apple.CoreServices.CarbonCore 0x00007fff308e5eb8 MPWaitOnSemaphore + 74
2 REDR3D.dylib 0x0000000133ae7c87 0x1339a0000 + 1342599
3 REDR3D.dylib 0x0000000133a9ee02 0x1339a0000 + 1043970
4 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
5 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
6 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 9:
2 REDR3D.dylib 0x0000000133ae8807 0x1339a0000 + 1345543
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
0 libsystem_kernel.dylib 0x00007fff5768520a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff57684724 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff2f702785 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff2f701ad7 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff2f701153 CFRunLoopRunSpecific + 483
5 com.apple.AVCVideoServices 0x000000013bd6cad2 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
Thread 18:
Thread 19:
0 libsystem_kernel.dylib 0x00007fff5768ed82 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff57609724 nanosleep + 199
2 com.adobe.ScriptLayerPPro.framework 0x000000011dfeff38 ScObjects::Thread::wait(unsigned int) + 56
3 com.adobe.ScriptLayerPPro.framework 0x000000011e01c1ec ScObjects::BridgeTalkThread::run() + 252
4 com.adobe.ScriptLayerPPro.framework 0x000000011dfefb61 ScObjects::Thread::go(void*) + 161
5 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
6 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
7 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 20:
Thread 21:
2 com.adobe.headlights.LogSessionFramework 0x0000000123b4d2dc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x0000000123b4bbff boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x0000000123af9149 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x0000000123ac8221 RealTimeProcessor::WorkerThread(int, int) + 3633
6 com.adobe.headlights.LogSessionFramework 0x0000000123b4af79 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 22:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff2e84be84 -[__CoreSchedulingSetRunnable runForever] + 722
6 com.apple.Foundation 0x00007fff3180c1f8 __NSThread__start__ + 1197
Thread 23:
2 com.apple.CoreServices.CarbonCore 0x00007fff3090774d TS_exception_listener_thread + 81
3 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
4 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
5 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 24:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff5768ecf2 __select + 10
1 com.apple.CoreFoundation 0x00007fff2f73c88b __CFSocketManager + 635
2 libsystem_pthread.dylib 0x00007fff57856661 _pthread_body + 340
3 libsystem_pthread.dylib 0x00007fff5785650d _pthread_start + 377
4 libsystem_pthread.dylib 0x00007fff57855bf9 thread_start + 13
Thread 25:: MF::DirectoryChangeMonitor
1 com.adobe.MediaFoundation.framework 0x000000010481770d MF::DirectoryChangeMonitor::(anonymous namespace)::EventQueueThreadProc(void*) + 1037
Thread 26:
5 com.apple.Foundation 0x00007fff319067fe -[NSConnection run] + 149
Thread 27:: CEPMonitorThread
5 com.apple.Foundation 0x00007fff31898710 -[NSConcreteTask waitUntilExit] + 220
6 com.adobe.PlugPlug 0x0000000109420ae9 -[HtmlEngineMonitor monitorThreadProc] + 160
7 com.apple.Foundation 0x00007fff3180c1f8 __NSThread__start__ + 1197
Thread 28:
Thread 29:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff2cdd9fc4 _NSEventThread + 184
Thread 30:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff2f15a87a HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 124
3 com.apple.audio.CoreAudio 0x00007fff2f15a7ed HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4 com.apple.audio.CoreAudio 0x00007fff2f157859 HALC_ProxyIOContext::IOWorkLoop() + 977
5 com.apple.audio.CoreAudio 0x00007fff2f1572bc HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6 com.apple.audio.CoreAudio 0x00007fff2f156ffe HALB_IOThread::Entry(void*) + 72
Thread 31:
Thread 32:
0 libsystem_kernel.dylib 0x00007fff5768f28a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff5785620e _pthread_wqthread + 1552
2 libsystem_pthread.dylib 0x00007fff57855be9 start_wqthread + 13
Thread 33:
1 libsystem_pthread.dylib 0x00007fff57856009 _pthread_wqthread + 1035
Thread 34:
Thread 35:
2 com.mainconcept.mc.bc.dec.avc 0x0000000112601e6b 0x11250b000 + 1011307
3 com.mainconcept.mc.bc.dec.avc 0x0000000112541458 0x11250b000 + 222296
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55:
Thread 56:
Thread 57:
Thread 58:
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
Thread 65:
Thread 66:
Thread 67:
2 com.apple.AppleGVAFramework 0x00007fff3f917c6b 0x7fff3f8da000 + 253035
3 com.apple.AppleGVAFramework 0x00007fff3f917b81 0x7fff3f8da000 + 252801
Thread 68:: com.apple.coremedia.asyncpixeltransfer
2 com.apple.CoreMedia 0x00007fff306b2c3a WaitOnCondition + 11
3 com.apple.CoreMedia 0x00007fff306b2af7 FigSemaphoreWaitRelative + 149
4 com.apple.VideoToolbox 0x00007fff3beaab4e 0x7fff3be9a000 + 68430
5 com.apple.CoreMedia 0x00007fff306b298b figThreadMain + 277
Thread 69:
Thread 70:
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 77:
Thread 78:
Thread 79:
Thread 80:
Thread 81:
Thread 82:
Thread 83:
Thread 84:
Thread 85:
Thread 86:: com.apple.coremedia.asyncpixeltransfer
Thread 87:
Thread 88:: com.apple.coremedia.asyncpixeltransfer
Thread 89:
Thread 90:: com.apple.coremedia.asyncpixeltransfer
Thread 91:
Thread 92:: com.apple.coremedia.asyncpixeltransfer
Thread 93:
Thread 94:: com.apple.coremedia.asyncpixeltransfer
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:
Thread 111:
Thread 112:
Thread 113:
Thread 114:
Thread 115:: com.apple.coremedia.asyncpixeltransfer
Thread 116:
Thread 117:: com.apple.coremedia.asyncpixeltransfer
Thread 118:
Thread 119:
Thread 120:
Thread 121:
Thread 122:
Thread 123:
Thread 124:
Thread 125:
Thread 126:
Thread 127:: com.apple.coremedia.asyncpixeltransfer
Thread 128:
Thread 129:: com.apple.coremedia.asyncpixeltransfer
Thread 130:
Thread 131:
Thread 132:
Thread 133:: com.apple.coremedia.asyncpixeltransfer
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007ffeefbfd210 rcx: 0x00000000ffffffff rdx: 0x0000000185515288
rdi: 0x0000000000000001 rsi: 0x00000001621d4800 rbp: 0x00007ffeefbfd1c0 rsp: 0x00007ffeefbfd1b0
r8: 0x000000015be68c98 r9: 0x0000000000000040 r10: 0x000000015be68c90 r11: 0xffffffffffffffff
r12: 0x00007ffeefbfd400 r13: 0x0000604000578a80 r14: 0x0000000185515290 r15: 0x0000000185515288
rip: 0x000000012047f158 rfl: 0x0000000000010202 cr2: 0x0000000000000001
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x100000000 - 0x100007ff7 +com.adobe.PremierePro.CC12 (12.1.2 - 12.1.2) <4B73B4B4-B982-34C9-81B2-A9A664CB8847> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
0x10000d000 - 0x100013fff +com.adobe.AdobeCrashReporter (7.7 - 7.7.0) <FA36FB74-CC30-3BFC-BC2C-4025E64F8C6A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x10001f000 - 0x100020ff3 +com.adobe.boost-system.framework (12.1.2 - 12.1.2.69) <24EF9CA8-E663-3396-B593-3E275BE83204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x100028000 - 0x10002cfff +com.adobe.boost-date-time.framework (12.1.2 - 12.1.2.69) <E4727EFC-83A2-31C7-8740-6AAB964723D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x10003d000 - 0x10004aff7 +com.adobe.boost-threads.framework (12.1.2 - 12.1.2.69) <60EB538A-DB63-33DA-B351-2189E2945EA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x100068000 - 0x100075fff +com.adobe.boost-filesystem.framework (12.1.2 - 12.1.2.69) <169D6D1B-EBBF-3529-B93E-0107A43FB7D7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x10008a000 - 0x1000a3fff +com.adobe.dvaunittesting.framework (12.1.2 - 12.1.2.69) <3BF41758-7436-3E39-A4DF-C7BB0C2EE018> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0x1000d8000 - 0x100450fff +com.adobe.dvacore.framework (12.1.2 - 12.1.2.69) <4E8C8538-6240-36EF-B307-BEFF249EB67B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x10075e000 - 0x100792fff +com.adobe.dvaappsupport.framework (12.1.2 - 12.1.2.69) <5234904E-FF9B-3AB9-8229-3F01CDF6B746> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaappsupport.framework/Versions/A/dvaappsupport
0x1007ea000 - 0x100ed7fff +com.adobe.dvaui.framework (12.1.2 - 12.1.2.69) <7DDB6DAD-68D9-37FD-AEB7-6BBC905B8848> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x101ac7000 - 0x101cd8ff7 +com.adobe.MBCProvider.framework (12.1.2 - 12.1.2.69) <433E47AB-1261-3BBE-A0EF-0D1B655BB5D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
0x101e8c000 - 0x101eb1fff +com.adobe.dvamediaui.framework (12.1.2 - 12.1.2.69) <6F1A328B-D44F-39AD-9101-9AB84944D299> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
0x101f13000 - 0x102070fff +com.adobe.dvamediabrowser.framework (12.1.2 - 12.1.2.69) <D8DD93F0-663B-33CA-8902-AF52126A58CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
0x10231a000 - 0x1023c8ff7 +com.adobe.TransmitVRHost.framework (12.1.2 - 12.1.2.69) <0496432C-78E7-3E98-AC62-64DA66CE449C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitVRHost.framework/Versions/A/TransmitVRHost
0x1024ec000 - 0x1024eeff7 +com.adobe.PRM.framework (12.1.2 - 12.1.2.69) <CDE494A8-D9E9-39F4-852A-7E04445D83DE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x1024f9000 - 0x102566fff +com.adobe.dvamediatypes.framework (12.1.2 - 12.1.2.69) <CF1C0566-8AF5-3ED5-9935-86E98B060B29> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
0x10261b000 - 0x102673ff7 +com.adobe.ASLFoundation.framework (12.1.2 - 12.1.2.69) <C7FE2F6C-F42D-3131-BA2C-D1A005CFF2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
0x1026e7000 - 0x10291ffff +com.adobe.Frontend.framework (12.1.2 - 12.1.2.69) <145FFDBF-A0FF-3651-A931-F972C952031B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
0x102c9c000 - 0x102e5eff7 +com.adobe.amtlib (10.0.0.250 - 10.0.0.250) <172741F8-9E54-317F-A72B-51D05CC05182> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x102e79000 - 0x102f4cfff +com.adobe.dvascripting.framework (12.1.2 - 12.1.2.69) <DC030805-7C1A-3B1A-A027-90AFC649C226> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
0x103191000 - 0x1031b3fff +com.adobe.ASLMessaging.framework (12.1.2 - 12.1.2.69) <5F55175A-5BAC-39B2-93ED-2908DC2EEE0E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
0x103203000 - 0x103ae8fc7 +com.adobe.dvaaccelerate.framework (12.1.2 - 12.1.2.69) <6B237AA5-FB0C-39B9-BB20-D7A942D98464> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
0x103bed000 - 0x103e4afe7 +com.adobe.dvaaudiodsp.framework (12.1.2 - 12.1.2.69) <818F0533-0CB6-3289-B4D7-1C3B69A10DDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
0x104101000 - 0x104103ff7 +com.adobe.Memory.framework (12.1.2 - 12.1.2.69) <29A797B7-5BD7-3A40-8275-DAAC57B061ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x10410b000 - 0x104163ff7 +com.adobe.dvatransport.framework (12.1.2 - 12.1.2.69) <88F78E08-C945-39A2-BA73-D052FEB1A166> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
0x104200000 - 0x104221fff +com.adobe.dvamarshal.framework (12.1.2 - 12.1.2.69) <97B637CC-1E4F-3A2B-A206-C4A175EDF68C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
0x104265000 - 0x1044b4fff +com.adobe.dynamiclink.framework (12.1.2 - 12.1.2.69) <FDFB3C59-C8C9-3261-8C76-12E44E5A0C3C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
0x1047b6000 - 0x104859fff +com.adobe.MediaFoundation.framework (12.1.2 - 12.1.2.69) <419C7E97-5046-3739-A6A2-555E0236466B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
0x104946000 - 0x1049c0fff +com.adobe.AudioRenderer.framework (12.1.2 - 12.1.2.69) <97A27DC9-971D-364A-8948-EEF7D3211025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
0x104a87000 - 0x104bb3ff7 +com.adobe.dvacaptioning.framework (12.1.2 - 12.1.2.69) <5C9A446F-8338-3529-AF9F-2EE687B445EF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
0x104ca7000 - 0x104cf2fff +com.adobe.dvatemporalxmp.framework (12.1.2 - 12.1.2.69) <A5051B93-5997-306D-8D19-E16FECF946A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
0x104d28000 - 0x104db1ff7 +com.adobe.dvametadata.framework (12.1.2 - 12.1.2.69) <74880A28-97DC-3774-AA80-41730CFF3699> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
0x104e81000 - 0x105b7bff7 +com.adobe.Backend.framework (12.1.2 - 12.1.2.69) <8A85E254-7073-30F3-8D08-0E24F00A13D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x106b82000 - 0x106babfff +com.adobe.MLFoundation.framework (12.1.2 - 12.1.2.69) <70A8FD1A-3FF3-3D05-8678-ECB3D808F60C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
0x106c06000 - 0x106d5efd7 +com.adobe.ImageRenderer.framework (12.1.2 - 12.1.2.69) <8D838BA1-F6A6-3BD5-A04C-D8832165554D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
0x106ea5000 - 0x106f55fff +com.adobe.VideoFrame.framework (12.1.2 - 12.1.2.69) <AACAF49F-0186-38D4-9AC5-F2F8D6E5C7BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
0x106fef000 - 0x10703dff7 +com.adobe.PluginSupport.framework (12.1.2 - 12.1.2.69) <E3E53E37-97C4-3727-91D2-07B0BC61FD06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
0x1070a8000 - 0x1070d1ff7 +com.adobe.SweetPeaSupport.framework (12.1.2 - 12.1.2.69) <EF1AFE64-61B8-3503-8D95-C2429C9AE27D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
0x107116000 - 0x107152fff +com.adobe.AudioSupport.framework (12.1.2 - 12.1.2.69) <BD56A6CB-3540-359C-BD3C-C9736202C285> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
0x1071d0000 - 0x1071e8fff +com.adobe.MediaUtils.framework (12.1.2 - 12.1.2.69) <FFB2D8D5-4B45-3833-AE5D-EC3F7FEAFFBF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
0x10720c000 - 0x1073a4fff +com.adobe.ImporterHost.framework (12.1.2 - 12.1.2.69) <69FE0A9E-9B5B-3B82-9662-DA60B115E91B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
0x10762e000 - 0x107681ff7 +com.adobe.AudioFilterHost.framework (12.1.2 - 12.1.2.69) <81C4C349-0F0A-3D2E-8DFC-12419277E082> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
0x10770e000 - 0x107835ff7 +com.adobe.VideoRenderer.framework (12.1.2 - 12.1.2.69) <75A24572-0877-3454-85AD-8A0594EFCD0B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
0x1079bb000 - 0x107aeafff +com.adobe.VideoFilterHost.framework (12.1.2 - 12.1.2.69) <7604CA03-B7FD-38DC-AD07-4E5734FA128C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
0x107c6d000 - 0x107c85fff +com.adobe.ProjectSupport.framework (12.1.2 - 12.1.2.69) <D2E66A75-7DA9-3021-8991-58367227D7D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
0x107cbc000 - 0x107e0dff7 +com.adobe.dvametadataDB.framework (12.1.2 - 12.1.2.69) <4708F30C-E326-37AE-B6EE-DA3BF602C229> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
0x107e58000 - 0x107f6cfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 145 - 79.162860) <9C4D43CC-0925-3157-85D3-266A1F093831> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x1080cb000 - 0x108134ff7 +com.adobe.DynamicLinkMedia.framework (12.1.2 - 12.1.2.69) <060E5F73-BF96-39F7-884F-79F5579C8C0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
0x108222000 - 0x108236fff +com.adobe.CCLibrariesSupport.framework (12.1.2 - 12.1.2.69) <8B9F7E1C-E419-3431-A29D-8FCA6D177F2F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
0x10826b000 - 0x10828dff7 +com.adobe.dvavulcansupport.framework (12.1.2 - 12.1.2.69) <535CE33D-2DC8-3972-AD5E-6CF385043CDA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
0x1082c3000 - 0x108320fff +com.adobe.csxsmanager.framework (12.1.2 - 12.1.2.69) <7544549A-7115-313A-836B-3F1BD8C0B5B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
0x1083a7000 - 0x1083d8ff7 +com.adobe.boost-program-options.framework (12.1.2 - 12.1.2.69) <228DFA51-8A91-3A05-AC26-872AE6517D9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_options
0x108435000 - 0x1084cffff +com.adobe.boost-regex.framework (12.1.2 - 12.1.2.69) <411D4511-E2D7-33E6-AB96-0B00C7D34887> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x108545000 - 0x108677fff +com.adobe.dvastorage.framework (12.1.2 - 12.1.2.69) <70DEA66D-58FF-39F6-95E3-417C78F050FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorage.framework/Versions/A/dvastorage
0x1086e2000 - 0x108842fff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 42 - 79.162860) <1F29F6FF-53E8-39A1-9B5E-0A27BBE9FDE7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0x10897f000 - 0x10899bffb +com.adobe.libzip.framework (12.1.2 - 12.1.2.69) <A0AA6A5E-AA7A-38A5-ADF7-3A54AAC02880> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
0x1089b3000 - 0x108eaeff7 +com.adobe.ATEWrapper.framework (12.1.2 - 12.1.2.69) <CAD2611D-B7D8-341E-B13F-4A2D87F311AA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ATEWrapper.framework/Versions/A/ATEWrapper
0x10941d000 - 0x1096a3fcb +com.adobe.PlugPlug (8.0.0.55 - 8.0.0.55) <B685BDFA-3EA3-3BF7-A88A-5EE5164DBCED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x10991c000 - 0x109bcdff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libxerces-c-3.1.dylib
0x109d7d000 - 0x109e2ffff +libgit2.dylib (0) <DB34258D-83CF-3F30-ABCA-1F2FA4D52D53> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libgit2.dylib
0x109e53000 - 0x109f4dfff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x109f5e000 - 0x10a019fff +com.adobe.dvaaudiofilterhost.framework (12.1.2 - 12.1.2.69) <B68A17BE-0CD9-35FA-8D86-4AED6C0AC62C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
0x10a140000 - 0x10a29eff7 +com.adobe.dvaaudiofilters.framework (12.1.2 - 12.1.2.69) <2090E919-55A3-36B8-8C3C-CE2CC321A444> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
0x10a491000 - 0x10a54afff +com.adobe.dvanet.framework (12.1.2 - 12.1.2.69) <FA83A194-6156-3BA8-B834-0F666F2DB153> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
0x10a66d000 - 0x10a691fff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanControl.dylib
0x10a6be000 - 0x10a6f9ff7 +VulcanMessage5.dylib (5.3.0.18 - 5.3.0.18 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <9E8F32A6-84F5-33EF-854C-9D0590105050> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanMessage5.dylib
0x10a743000 - 0x10a75bfff +com.adobe.TeamProjectsLocalClient.framework (12.1.2 - 12.1.2.69) <674A1891-89B4-3035-94E7-82AA716912BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLocalClient
0x10a795000 - 0x10a79afff +com.adobe.dvaundo.framework (12.1.2 - 12.1.2.69) <15A81932-504B-31EA-89C0-92BF8EA83387> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
0x10a7aa000 - 0x10a7f4acf dyld (551.4) <8A72DE9C-A136-3506-AA02-4BA2B82DCAF3> /usr/lib/dyld
0x10a848000 - 0x10afabfff +com.adobe.EAClient.framework (12.1.2 - 12.1.2.69) <F57BDECE-C558-370B-AB80-1BDAF7FA4B74> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
0x10b9b9000 - 0x10ba79ff7 +com.adobe.dvaeve.framework (12.1.2 - 12.1.2.69) <9EBF04FD-F699-35CD-9080-903E763BA3A7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x10bbd3000 - 0x10bcc6ff7 +com.adobe.dvanetsync.framework (12.1.2 - 12.1.2.69) <81666DDC-1449-36B0-9CC2-91F88EEA266C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
0x10be3a000 - 0x10bfacff7 +com.adobe.dvaworkspace.framework (12.1.2 - 12.1.2.69) <5167E87B-9BFF-3482-8ED3-D97177623CDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x10c2b4000 - 0x10c374ff7 +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 7 - 79.162860) <E8B0F4F8-F9FB-3A4E-9B6F-A3C4CAB5D995> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompareAndMerge
0x10c4df000 - 0x10c6aefff +com.adobe.GPUFoundation.framework (12.1.2 - 12.1.2.69) <95B23730-940A-3BC4-B774-7BF7A28767C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
0x10c7e7000 - 0x10c7fafff +com.adobe.RuntimeInstaller.framework (12.1.2 - 12.1.2.69) <56CF8516-E47B-34D7-8CA7-028B4FAA623B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
0x10c819000 - 0x10c8fdff7 +com.mainconcept.mc.mfimport (10.5 - 10.5.17.5963) <C3926B1A-0AB4-37B6-9F44-39E399CD2B94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
0x10c90c000 - 0x10ca93fff +com.adobe.atl-audio.framework (12.1.2 - 12.1.2.69) <44F6270C-417D-3B01-A05A-8AEFE2E1F2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
0x10cabd000 - 0x10cb93fff +com.adobe.dvaaudiodevice.framework (12.1.2 - 12.1.2.69) <A95196BF-AF0A-30B2-9186-2AF95ACA18FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
0x10cd4d000 - 0x10ce21fff +com.adobe.OpticalFlow.framework (12.1.2 - 12.1.2.69) <3D947580-654E-3718-AF85-801839184764> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
0x10cee7000 - 0x10cef3fff +com.adobe.BravoInitializer.framework (12.1.2 - 12.1.2.69) <436469E3-B3AE-320B-B960-3EB40539BCA8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
0x10cf10000 - 0x10d01cfff +com.adobe.ACE (AdobeACE 2.20.02.40104 - 2.20.02.40104) <4E99F32C-DF9A-30DE-ADCB-75498D2B206C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x10d035000 - 0x10d52efff +com.adobe.AGM (AdobeAGM 4.30.87.40104 - 4.30.87.40104) <D7DD88C5-47A8-3771-AA98-D3898889A554> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x10d5db000 - 0x10d5f1fff +com.adobe.BIB (AdobeBIB 1.2.03.40104 - 1.2.03.40104) <8FB4C147-F145-3886-BBC9-66F4027EBAE5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x10d5fa000 - 0x10d8faff7 +com.adobe.CoolType (AdobeCoolType 5.17.00.40104.1 - 5.17.00.40104) <BD3DFF22-2E03-391E-8E1A-933AA0046204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x10d94c000 - 0x10da76ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
0x10dacc000 - 0x10daecff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.40104 - 1.1.40104) <3D52E2D3-C27B-314F-83B6-BCBA00F6D87D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x10daf4000 - 0x10db04fff +com.adobe.ProjectConverterHost.framework (12.1.2 - 12.1.2.69) <3BA089F2-EE8C-39FF-9E0C-E7DD6D23F06B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHost
0x10db2c000 - 0x10db4dfff +com.adobe.ImmersiveVideo.framework (12.1.2 - 12.1.2.69) <36E93CA8-ECAF-352D-B139-FA538A56DD19> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
0x10db71000 - 0x10dbddff7 +com.adobe.DisplaySurface.framework (12.1.2 - 12.1.2.69) <C9B98269-28C9-3F52-96EA-C0AE3D9E3CAC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
0x10dc5d000 - 0x10e016fff +com.adobe.UIFramework.framework (12.1.2 - 12.1.2.69) <868C7FBC-6E27-3059-A2A1-95247905D36B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
0x10e84d000 - 0x10e872ff7 +com.adobe.dvavirtualui.framework (12.1.2 - 12.1.2.69) <46C049C3-FD4D-3880-950F-7F43883330EE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavirtualui.framework/Versions/A/dvavirtualui
0x10e8cd000 - 0x10e935ff7 +com.adobe.PlayerHost.framework (12.1.2 - 12.1.2.69) <2D45B21F-9E60-3F8E-94F4-0D6D99365F91> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
0x10ea11000 - 0x10eaddff7 +com.adobe.ExporterHost.framework (12.1.2 - 12.1.2.69) <8CA3E0BA-FB21-373B-95BC-B1BAF9164374> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
0x10ebf9000 - 0x10ed8bfff +com.adobe.EncoderHost.framework (12.1.2 - 12.1.2.69) <8C6A2EBD-ED0A-3438-9C22-3F67AAF19BBE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
0x10ef8c000 - 0x10eff7ff7 +com.adobe.RecorderHost.framework (12.1.2 - 12.1.2.69) <CEDFCFD3-8C14-3995-B21E-0D88C75DA73B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
0x10f0f0000 - 0x10f124ff7 +com.adobe.AudioFilters.framework (12.1.2 - 12.1.2.69) <91453FBC-53DC-3B29-A566-75527CBC3A55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
0x10f198000 - 0x10fc26fff +com.adobe.Mezzanine.framework (12.1.2 - 12.1.2.69) <15380DB2-236C-3B52-A156-BE7A11113AD0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
0x110819000 - 0x110851ff7 +com.adobe.MediaCoreUI.framework (12.1.2 - 12.1.2.69) <FC3FFAE7-F381-34B8-96A1-DB959675BA38> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
0x1108b1000 - 0x110b11ff7 +com.adobe.SettingsUI.framework (12.1.2 - 12.1.2.69) <E52003A4-B314-3F16-AE88-BFF7941F7DBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
0x110f89000 - 0x1113f2fff +com.adobe.HSL.framework (12.1.2 - 12.1.2.69) <D575B13E-1FEA-3BDB-B5B9-B853FAA8021D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
0x111a5e000 - 0x111aa1fff +com.adobe.TransmitHost.framework (12.1.2 - 12.1.2.69) <037FEF47-EC5C-3762-BFB9-858AB74779FF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
0x111b04000 - 0x111bc9ff7 +com.adobe.exo.framework (12.1.2 - 12.1.2.69) <968342CE-E32F-3E52-811C-B7F1B9EE4B84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x111d94000 - 0x111dd9ff7 +com.adobe.dynamiclinkUI.framework (12.1.2 - 12.1.2.69) <1F3F6F73-FEA2-3210-B6C6-4CAB1870B85F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
0x111e6e000 - 0x111f02fff +com.adobe.drawbotagm.framework (12.1.2 - 12.1.2.69) <3CC7CD7A-D378-3C33-9ED0-274F038E9E42> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/drawbotagm.framework/Versions/A/drawbotagm
0x111fc0000 - 0x1121b4fe7 +com.adobe.CodecSupport.framework (12.1.2 - 12.1.2.69) <8FE9AE4A-B2D3-3765-9CA2-51AABA7D2CD8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
0x112363000 - 0x1124fcfef +com.mainconcept.mc.dec.mp2v (10.5 - 10.5.17.5963) <6566B253-5F5D-38B7-9667-E1D62249F4BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
0x11250b000 - 0x11279dfcf +com.mainconcept.mc.bc.dec.avc (10.5 - 10.5.17.5963) <9CF5072E-9C3F-3E48-B18A-48D8DB988539> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
0x1127b4000 - 0x11298cfe7 +com.mainconcept.mc.dec.mp4v (10.5 - 10.5.17.5963) <3D65323B-3AA2-399F-923A-3C7E670957D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
0x11299f000 - 0x113f08fef +com.canon.CrmSdk (2.0.0.35 - 2.0.0.35) <975241B6-A7F7-3ED4-A5F4-65EC2B948400> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CrmSdk.framework/Versions/A/CrmSdk
0x114104000 - 0x11414afef +com.adobe.ProResOpt.framework (12.1.2 - 12.1.2.69) <93A0800B-59F1-3E14-9128-8C0547C640B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
0x114181000 - 0x11418dfff +com.adobe.QT64Utils.framework (12.1.2 - 12.1.2.69) <2FC70546-FAC0-36B3-AA2E-D6C30AD71A68> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
0x1141a5000 - 0x114686fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libDNxHR.dylib
0x114775000 - 0x1148e3ff7 +libSonyRawDev.dylib (3) <0DEAB123-EEB1-3567-BEB4-074484F55878> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libSonyRawDev.dylib
0x11497f000 - 0x115bdbfff +libArriRawSDK.dylib (0) <EB0D5F76-6989-3DAC-8560-35016D7E4D47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libArriRawSDK.dylib
0x116300000 - 0x1163dcfe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmp4decMT.dylib
0x11643b000 - 0x116545fff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDDecoder.dylib
0x1165e6000 - 0x1166e8fff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDEncoder.dylib
0x116797000 - 0x1167d4ff7 +libcudart.6.5.dylib (6.5.14) <D461AB76-19EE-3BDD-A579-3942130A15B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.6.5.dylib
0x1167e0000 - 0x116900fef +libiomp5.dylib (0) <24D4D9F0-95F7-3930-9662-CD356D42B2C1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libiomp5.dylib
0x116970000 - 0x11699fff7 +libcilkrts.5.dylib (0) <04FF28DE-1EA4-3A82-ACED-7B8BD7CA100A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcilkrts.5.dylib
0x1169bd000 - 0x1169e2ff7 +com.adobe.QTParser.framework (12.1.2 - 12.1.2.69) <451126BD-5016-3F2C-A571-CC87C87CF169> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
0x116a0a000 - 0x116aeffdf +libProResDecoder.dylib (0) <F006F4E9-D737-3E29-949E-113035495E4B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libProResDecoder.dylib
0x116b30000 - 0x116b6bfff +libcudart.dylib (0) <6E55D67C-1A95-3C2B-B2C1-C3F5827A3F03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.dylib
0x116b79000 - 0x116b9fff7 +com.adobe.TimeCarving.framework (12.1.2 - 12.1.2.69) <EF7B833B-1611-3F22-92F5-55CDD228697E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
0x116be3000 - 0x116c63fff +com.adobe.MediaFinder.framework (12.1.2 - 12.1.2.69) <9656E167-BFDD-38CE-AA0F-252BA63C6BF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
0x116d66000 - 0x116f0ffff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
0x11703b000 - 0x1170cffff +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <ED3A028B-68A7-37D8-9127-F99AB0970B65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
0x117164000 - 0x117200ff7 +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <265AC5A0-FA72-3D47-99CF-9371A7582B62> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
0x1172a0000 - 0x1172e8ff7 +com.adobe.ahclientframework (3.0.0.7 - 3.0.0.7) <4D54E721-153B-3DE0-BC31-5B1500295EEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x117320000 - 0x117340fff +com.adobe.AMEAppFoundation.framework (12.1.2 - 12.1.2.69) <93F41D3D-9879-3EE7-8B42-EBEBAE7EA6D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
0x1173c3000 - 0x11745dfff +com.adobe.essentialsound.framework (12.1.2 - 12.1.2.69) <83657D4C-A0A8-3D72-B581-1C7E858EECA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
0x117567000 - 0x1175c0fff +com.adobe.FontEngine.framework (12.1.2 - 12.1.2.69) <2DB8738C-F712-3FAB-B598-1177C00F8E20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
0x117654000 - 0x11766bfff +com.adobe.TitleLayer.framework (12.1.2 - 12.1.2.69) <589EF00E-F74A-398C-AC9A-5810FF6151A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
0x117808000 - 0x117810ff7 +com.adobe.TitleImageManager.framework (12.1.2 - 12.1.2.69) <4006371A-05F0-3F0B-93CF-66B4AE75C274> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
0x11781f000 - 0x1178a3ff7 +com.adobe.TitleCharacterFactory.framework (12.1.2 - 12.1.2.69) <2610FFB0-AB4E-350E-8B63-689E590039D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFactory
0x1178f5000 - 0x117a44ff7 +com.adobe.TitleCG.framework (12.1.2 - 12.1.2.69) <5B6BCB7E-DA1E-3551-93FF-118B4535FD86> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
0x117b51000 - 0x117d7efff +com.adobe.TitleLayout.framework (12.1.2 - 12.1.2.69) <8B58ECBA-468E-3BA8-8BD7-FCA86B167518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
0x11828c000 - 0x1182dcfff +com.adobe.TitleRenderer.framework (12.1.2 - 12.1.2.69) <0BBB073A-A497-39E3-BA4E-8E4AD308857A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
0x11836c000 - 0x1183bfff7 +com.adobe.dvaaudiofilterhostui.framework (12.1.2 - 12.1.2.69) <6F650B83-DF5D-3693-9D24-CB28E876D6C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhostui
0x11849a000 - 0x11856afff +com.adobe.dvametadataUI.framework (12.1.2 - 12.1.2.69) <8695151E-E481-3EF6-83D2-62A819D4D67E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
0x1186b7000 - 0x1186c1ff7 +com.adobe.dvamarkerUI.framework (12.1.2 - 12.1.2.69) <20C88E1E-80B8-3B90-A141-DBE43575A58D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
0x1186e6000 - 0x1188f8fff +com.adobe.EACodec.framework (12.1.2 - 12.1.2.69) <74428346-9289-3935-9E2C-A43C9383AF82> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
0x1189d6000 - 0x118c96ff7 +com.adobe.EAMedia.framework (12.1.2 - 12.1.2.69) <D4B5E45E-0040-3A67-B9EA-8F1D8522BC14> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
0x118ff9000 - 0x119503ff7 +com.adobe.EAProjectBridge.framework (12.1.2 - 12.1.2.69) <6AFF03E3-AF61-3AE6-AB89-192F9D835371> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
0x119b62000 - 0x119b7bfff +com.adobe.dvastoryparser.framework (12.1.2 - 12.1.2.69) <BE91B646-3223-3A8A-9C4C-A46E480CF6B6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
0x119b9c000 - 0x119bc4ff7 +com.adobe.dvatypekit.framework (12.1.2 - 12.1.2.69) <594817A4-3D82-3333-B5AF-DBA5AE97DDDF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
0x119c03000 - 0x119caefff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
0x119cda000 - 0x119cefff7 +com.adobe.postprocess.framework (12.1.2 - 12.1.2.69) <A90C6102-223B-3B36-A5F3-60E4ACEB690A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
0x119d20000 - 0x11a091fe7 +com.mainconcept.mc.enc.avc (10.5 - 10.5.17.5963) <68C4B627-70A1-3451-8178-5B00CBDC4779> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
0x11a1ca000 - 0x11a3dcfc7 +com.mainconcept.mc.dec.avc (10.5 - 10.5.17.5963) <ABB8EB0E-532F-3C65-84A3-3D1206FC2E89> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
0x11a3ee000 - 0x11a67ffff +com.mainconcept.mc.mux.mp4 (10.5 - 10.5.17.5963) <9C81FC97-3172-30C6-AB48-AB49515BA1D6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
0x11a6ac000 - 0x11a6e8ff7 +com.adobe.boost-serialization.framework (12.1.2 - 12.1.2.69) <006B6435-0439-3B99-8820-20EF07908B34> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
0x11a7b5000 - 0x11ad01ff7 +com.adobe.TeamProjectsLocalLib.framework (12.1.2 - 12.1.2.69) <07742390-2F94-3303-B21D-D7BBF4D2C132> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalLib.framework/Versions/A/TeamProjectsLocalLib
0x11b2b1000 - 0x11b847b27 +adobe.cloudservices.liveedit.LiveEditClient (1.0 - 1) <9A981AA5-734D-3591-A029-96B2DAF10888> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LiveEditClient.framework/Versions/A/LiveEditClient
0x11bc64000 - 0x11c138ff7 +com.adobe.Dialogs.framework (12.1.2 - 12.1.2.69) <C436E904-AE02-38C3-8EA8-14B552E64C0C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
0x11c708000 - 0x11c7bfff7 +com.adobe.PProDynamicLinkServer.framework (12.1.2 - 12.1.2.69) <6CBD4908-B736-3D35-A4AA-FBF6C989DB70> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkServer
0x11c983000 - 0x11cb2cfff +com.adobe.EAPrBridge.framework (12.1.2 - 12.1.2.69) <C80D2C85-95AB-3D4B-BBAB-F5A8F9B6B50E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
0x11cdbe000 - 0x11cdd5ff7 +com.adobe.dvacaptioningui.framework (12.1.2 - 12.1.2.69) <684F757A-CE8A-376B-A88F-1E3F1E4E4607> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
0x11cdfd000 - 0x11cfd9ff7 +com.adobe.RendererGPU.framework (12.1.2 - 12.1.2.69) <9E5C7BA8-3A0E-3A78-B69E-D3CE87494016> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
0x11d11b000 - 0x11d2f0ff7 +com.adobe.IngestCore.framework (12.1.2 - 12.1.2.69) <0B61D9D8-35A2-36AD-8DAF-6EF0342ACE1A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
0x11d625000 - 0x11d6e9fff +com.adobe.IngestDialog.framework (12.1.2 - 12.1.2.69) <0696C3F1-A7ED-3FE8-AE93-334B0EFF4F9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestDialog.framework/Versions/A/IngestDialog
0x11d8a2000 - 0x11d8d1ff7 +com.adobe.dvacontrolsurfacehost.framework (12.1.2 - 12.1.2.69) <2E26F17D-512F-3D0C-B47E-15A436C04DA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurfacehost
0x11d95b000 - 0x11d98efff +com.adobe.dvaaudiodeviceui.framework (12.1.2 - 12.1.2.69) <8D705EA9-5C4A-37BB-B534-1B1C0CD1CF49> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
0x11d9e9000 - 0x11da1afff +com.adobe.Registration.framework (12.1.2 - 12.1.2.69) <98218561-A270-3828-91E0-96E44F38184A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
0x11da53000 - 0x11da68ff7 +com.adobe.OnBoardingBase.framework (12.1.2 - 12.1.2.69) <F9007BB0-1CF9-32B1-BD5E-229B213F4C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoardingBase.framework/Versions/A/OnBoardingBase
0x11daa2000 - 0x11dbf0fff +com.adobe.MobileAppLayer.framework (12.1.2 - 12.1.2.69) <3160CBBA-F49F-3DEE-A586-D496564AA3E5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MobileAppLayer.framework/Versions/A/MobileAppLayer
0x11df27000 - 0x11e073fff +com.adobe.ScriptLayerPPro.framework (12.1.2 - 12.1.2.69) <85CED389-8750-39BE-893A-0F6DC25BDA06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
0x11e26d000 - 0x11e646ff7 +com.adobe.ScriptLayerPProQE.framework (12.1.2 - 12.1.2.69) <E60D0D25-8AC8-3ADE-AEC1-7B6BB2C548E7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
0x11f029000 - 0x11f062ff7 +com.adobe.HandlerAudioMiniMixer.framework (12.1.2 - 12.1.2.69) <7570454C-7BDA-3A5D-B00A-4CCB27DC676C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniMixer
0x11f0d5000 - 0x11f190ff7 +com.adobe.HandlerColor.framework (12.1.2 - 12.1.2.69) <C4E933D5-5F56-3A76-9C7C-1C00A328C92D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerColor.framework/Versions/A/HandlerColor
0x11f2bc000 - 0x11f2e8ff7 +com.adobe.HandlerCSXS.framework (12.1.2 - 12.1.2.69) <2F0CCDDA-3650-3ADA-A8CA-25FA87B4E122> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
0x11f365000 - 0x11f57fff7 +com.adobe.HandlerEffectControls.framework (12.1.2 - 12.1.2.69) <4A4AB44C-0EAD-3496-9359-3478834CD518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectControls
0x11f824000 - 0x11f868ff7 +com.adobe.HandlerMediaBrowser.framework (12.1.2 - 12.1.2.69) <9B16483B-6AB3-3E24-96A2-F7F925DC4619> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
0x11f920000 - 0x11fa84fff +com.adobe.HandlerProgramMonitor.framework (12.1.2 - 12.1.2.69) <7AC73AB3-D2FA-360B-A19A-1CF5042AF0B8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMonitor
0x11fc9d000 - 0x11ff71ff7 +com.adobe.HandlerProject.framework (12.1.2 - 12.1.2.69) <DF846AD2-04FF-3F47-BAAF-646651AA1689> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
0x1203e1000 - 0x120709ff7 +com.adobe.HandlerTimeline.framework (12.1.2 - 12.1.2.69) <66195A9B-954E-3616-9967-0FF5202AF7F6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
0x120ad9000 - 0x120b2fff7 +com.adobe.HandlerTools.framework (12.1.2 - 12.1.2.69) <F8E6F606-EAAA-3D64-B2FE-39827AAD02BB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
0x120c59000 - 0x120e10ff7 +com.adobe.HandlerTitler.framework (12.1.2 - 12.1.2.69) <1863F354-F666-3565-8873-1EC5CA65EFA0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
0x121163000 - 0x1211bdfff +com.adobe.HandlerAudioClipMixer.framework (12.1.2 - 12.1.2.69) <16776F6C-A52E-347E-8451-2D3BDA5167B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipMixer
0x12127a000 - 0x12131aff7 +com.adobe.HandlerAudioMixer.framework (12.1.2 - 12.1.2.69) <E3D2B286-E9D9-35CC-9400-2FC60570FB90> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
0x121427000 - 0x12147bfff +com.adobe.HandlerCaptions.framework (12.1.2 - 12.1.2.69) <253CB6E4-EE41-313A-B033-E84192E8B59F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
0x121519000 - 0x12159dfff +com.adobe.HandlerCapture.framework (12.1.2 - 12.1.2.69) <6C3FB66F-018E-3434-9302-FE9AF70B35A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
0x1216a8000 - 0x1216f0ff7 +com.adobe.HandlerEditToTape.framework (12.1.2 - 12.1.2.69) <C826C51D-D1B3-3955-A070-5A1383EBD9D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
0x121798000 - 0x121806fff +com.adobe.HandlerEffects.framework (12.1.2 - 12.1.2.69) <8D6F4079-4A81-3AB8-B2C4-D0F6C9AEBDEE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
0x1218cd000 - 0x1218e6ff7 +com.adobe.HandlerEssentialSound.framework (12.1.2 - 12.1.2.69) <AD99F017-8C49-33B4-B78F-AD693FCB2ADE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEssentialSound.framework/Versions/A/HandlerEssentialSound
0x121934000 - 0x121953ff7 +com.adobe.HandlerEvents.framework (12.1.2 - 12.1.2.69) <27D4B764-ACE7-394F-8B42-021CA925919F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
0x1219a7000 - 0x1219bbff7 +com.adobe.HandlerGetProperties.framework (12.1.2 - 12.1.2.69) <F6583899-3713-3A40-86C3-65EEE84AFCD2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperties
0x1219f2000 - 0x121b7aff7 +com.adobe.HandlerGraphics.framework (12.1.2 - 12.1.2.69) <D8932F8B-8420-35FD-A5CA-09C9D6BEB1C9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGraphics.framework/Versions/A/HandlerGraphics
0x121df5000 - 0x121e0cff7 +com.adobe.HandlerHistory.framework (12.1.2 - 12.1.2.69) <90FDBC3E-6DA7-31EE-9E4B-84A436F11B93> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
0x121e49000 - 0x121e6afff +com.adobe.HandlerInfo.framework (12.1.2 - 12.1.2.69) <D38E5CE9-4073-3F84-ACA2-A891A10C7AEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
0x121eb7000 - 0x121efbff7 +com.adobe.HandlerMarkerList.framework (12.1.2 - 12.1.2.69) <16F37EC8-0C68-3DBC-9125-288FEFCE9EF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
0x121fa1000 - 0x121ff2fff +com.adobe.HandlerMetadataEditor.framework (12.1.2 - 12.1.2.69) <0B0E30F2-E36A-3FBD-9D31-14B8D2A20369> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEditor
0x1220ab000 - 0x1220affff +com.adobe.HandlerProgress.framework (12.1.2 - 12.1.2.69) <9ADC2841-083C-3DCA-BB34-565949086C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
0x1220c2000 - 0x1220d2ff7 +com.adobe.HandlerScopes.framework (12.1.2 - 12.1.2.69) <E40CD507-7749-3D75-9585-4803E5EED496> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerScopes.framework/Versions/A/HandlerScopes
0x1220fa000 - 0x122284ff7 +com.adobe.HandlerSourceMonitor.framework (12.1.2 - 12.1.2.69) <9AC7779E-369C-3AF6-A256-667AC8F2ADBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonitor
0x12244f000 - 0x122458ff7 +com.adobe.HandlerStoryPanel.framework (12.1.2 - 12.1.2.69) <5A6FBEB5-467E-3253-BEDC-36C8B3BF1207> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerStoryPanel.framework/Versions/A/HandlerStoryPanel
0x122478000 - 0x1224a4ff7 +com.adobe.HandlerTimecode.framework (12.1.2 - 12.1.2.69) <110975EB-9974-3598-AF65-39F0449B2F3F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
0x122509000 - 0x122824fff +com.adobe.dvaadameve.framework (12.1.2 - 12.1.2.69) <D839908C-CEB6-3152-AF34-F930AF4F891D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x122eb2000 - 0x123058fff +com.adobe.dvaaudiofiltersui.framework (12.1.2 - 12.1.2.69) <734266EF-9DA3-34C2-BB10-1ABDA9103CFA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofiltersui.framework/Versions/A/dvaaudiofiltersui
0x123398000 - 0x123419fff +com.adobe.ControlSurface.framework (12.1.2 - 12.1.2.69) <EBD39BF2-2EB4-32CD-8CD9-F747A6BD13D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
0x1234c3000 - 0x1234e3ff7 +com.adobe.OnBoarding.framework (12.1.2 - 12.1.2.69) <4B808FC0-40EE-3DD7-AECE-6936F46C5568> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoarding.framework/Versions/A/OnBoarding
0x12353d000 - 0x1236abff7 +com.adobe.Batch.framework (12.1.2 - 12.1.2.69) <AF7F59B9-2E08-374C-8599-A40538A29BE8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
0x12398d000 - 0x1239a8ff7 +com.adobe.IngestGlue.framework (12.1.2 - 12.1.2.69) <A0A8EB59-2206-3F2E-A0E7-EB43B41314FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestGlue.framework/Versions/A/IngestGlue
0x1239ed000 - 0x123b8ffff +com.adobe.headlights.LogSessionFramework (7.4.1.112.46866) <F8E6A446-3724-3F70-A396-E1A01325FE0A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x123d2b000 - 0x123e29ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
0x123e57000 - 0x123efbfff +com.adobe.dvascriptingES.framework (12.1.2 - 12.1.2.69) <3483CB3E-1DC2-3486-961F-8520D8A3FB28> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
0x123ff3000 - 0x124037ff7 +com.adobe.dvastorypanel.framework (12.1.2 - 12.1.2.69) <8C9C700C-1C8B-3700-B30A-929AB6303AFD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorypanel.framework/Versions/A/dvastorypanel
0x1240d2000 - 0x12415eff7 +com.adobe.essentialsoundui.framework (12.1.2 - 12.1.2.69) <AB7B2F5C-D98B-36FD-8CAA-50D896B60C04> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsoundui.framework/Versions/A/essentialsoundui
0x124290000 - 0x124304ff7 +com.adobe.ScriptLayer.framework (12.1.2 - 12.1.2.69) <408C5B51-D263-3A41-82D3-7F00E0FD95CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
0x128ff6000 - 0x128ff8ff3 com.apple.textencoding.unicode (4.0 - 4.0) <2E85076C-3BB1-3522-B03C-D160CD0CCB17> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x129eef000 - 0x129ef1ff3 +com.adobe.Motion.framework (12.1.2 - 12.1.2.69) <6CEE74DB-265B-3E95-B77F-856DC872057F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
0x12b800000 - 0x12bd47fff com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.36.19 - 10.3.6) <DF5C1702-E682-31DE-9840-E0A0ADD676C0> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x12dbf1000 - 0x12dbf5ffb com.apple.audio.AppleHDAHALPlugIn (281.52 - 281.52) <23C7DDE6-A44B-3BE4-B47C-EB3045B267D9> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x12ed17000 - 0x12ed19ffb +com.adobe.Opacity.framework (12.1.2 - 12.1.2.69) <9CE8890B-6AB6-3697-80AF-A44580DF5E34> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacity
0x12ed45000 - 0x12ed45ff7 +com.adobe.Mosaic.framework (12.1.2 - 12.1.2.69) <36B1404A-00E7-3F30-9DBC-146731F35057> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
0x12f255000 - 0x12f27efff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x12f309000 - 0x12f34cff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x12f378000 - 0x12f379ffb +com.adobe.Bevel-Edges.framework (12.1.2 - 12.1.2.69) <F76F2398-6094-3F77-8706-FC9B9D5D527D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/Bevel_Edges
0x12f494000 - 0x12f495ff3 +com.adobe.ImporterTransparentMatte.framework (12.1.2 - 12.1.2.69) <417B40AF-830A-38D7-97EF-F07A1C45A1F6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterTransparentMatte.bundle/Contents/MacOS/ImporterTransparentMatte
0x12f77a000 - 0x12f77aff7 +com.adobe.dvahapticcore.framework (9.1.0 - 9.1.0.0) <0A26F94F-8D32-32CE-B5C0-970C6FD8D32D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvahapticcore.framework/dvahapticcore
0x12feeb000 - 0x12ff23fff +com.adobe.pip (7.4.1.112.46866) <728B8830-2C34-343A-B763-7B5EB07BAC06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x130129000 - 0x130146ff7 +imshelper.dylib (1.0.0.12 - 1.0.0.12) <7CE614A1-E326-30D1-B110-759D7C86C12A> /Library/Application Support/Adobe/*/imshelper.dylib
0x13056f000 - 0x130571fff AppleIntelHSWVA (10.36.19) <3ED4348E-8135-35D4-810E-4C460F4F7BD6> /System/Library/Extensions/AppleIntelHSWVA.bundle/Contents/MacOS/AppleIntelHSWVA
0x1307e9000 - 0x13080ffef +com.mainconcept.mc.enc.dv (10.5 - 10.5.17.5963) <C8D63373-D045-39AA-B486-72076413C2A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
0x1339a0000 - 0x133bc3fe7 +REDR3D.dylib (0) <3F88935C-39CB-3D8F-AA68-478BEF1CC694> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDR3D.dylib
0x1379f8000 - 0x137a01fff +com.adobe.AEFilterTimecode.framework (12.1.2 - 12.1.2.69) <32CC3EEC-3777-318E-8D35-1D942952FD53> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/AEFilterTimecode.bundle/Contents/MacOS/AEFilterTimecode
0x1387f2000 - 0x1387f8ff7 +com.mainconcept.mc.enc.mp2sr (10.5 - 10.5.17.5963) <8339AD25-167D-3BFE-A37A-D914F6A10B32> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
0x139341000 - 0x139342fff +com.adobe.TransmitDesktopAudio.framework (12.1.2 - 12.1.2.69) <DC555A97-F712-317D-9758-29CBCF49B940> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents/MacOS/TransmitDesktopAudio
0x139da4000 - 0x139db5fff +com.adobe.DeviceControlFirewire.framework (12.1.2 - 12.1.2.69) <345B6CC2-5939-3112-A935-0DC2AB5A1416> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/DeviceControlFirewire.bundle/Contents/MacOS/DeviceControlFirewire
0x13a8c0000 - 0x13a943ff7 +com.adobe.ImporterRED.framework (12.1.2 - 12.1.2.69) <1CEDD72E-20C3-31B1-A2E6-A216D01CC5E6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
0x13ae7c000 - 0x13af52fff +REDCuda.dylib (0) <DC0FCD27-04BD-319F-A701-7369107E056E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDCuda.dylib
0x13b732000 - 0x13b923ff7 +REDOpenCL.dylib (0) <D54DBEDF-8CEB-3FFF-9C86-D92670D10D66> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDOpenCL.dylib
0x13bd1c000 - 0x13bd2eff7 +com.adobe.TransmitDV.framework (12.1.2 - 12.1.2.69) <F888C04F-C05B-3901-AF92-100FB4FBC18D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/TransmitDV
0x13bd5c000 - 0x13bd86ff7 com.apple.AVCVideoServices (1.0 - 42) <FEAE1854-5F7E-3B3E-B6EA-BD825B3CB467> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
0x13be41000 - 0x13be48ff7 +com.adobe.TransmitFullScreen.framework (12.1.2 - 12.1.2.69) <B81D958C-5209-3296-95BA-377CCFD5A52B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/MacOS/TransmitFullScreen
0x13be57000 - 0x13be6ffff +com.adobe.ImporterAVFoundation.framework (12.1.2 - 12.1.2.69) <A24E42DF-FAAA-31A2-9AD7-24741C960F80> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterAVFoundation.bundle/Contents/MacOS/ImporterAVFoundation
0x13be90000 - 0x13bec0ff7 +com.adobe.PlatformAudioCodecs.framework (12.1.2 - 12.1.2.69) <D09914DB-85F8-30E1-B618-9ED666CEAD6C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
0x13c200000 - 0x13c3d0fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
0x13c5a0000 - 0x13c68ffff +com.mainconcept.mc.demux.mp2 (10.5 - 10.5.17.0258) <C86FD5AF-C224-31B6-B073-023A5217E3F9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
0x13c6a1000 - 0x13c74bfff +com.adobe.ExporterXDCAMHD.framework (12.1.2 - 12.1.2.69) <89CE6B00-959C-3315-866A-D15E348BCC18> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
0x13c7f3000 - 0x13c7fdfff +com.mainconcept.mc.enc.avcsr (10.5 - 10.5.17.5963) <1727D243-B2DD-3047-B68A-98BCA1A00A7E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
0x13c803000 - 0x13c9f3fe7 +com.mainconcept.mc.enc.mp2v (10.5 - 10.5.17.5963) <111832A9-C088-350C-8096-0EDF0BEA00D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
0x13ca47000 - 0x13cdc0fff +com.mainconcept.mc.bc.enc.avc (10.5 - 10.5.17.5963) <16AA44F7-D279-35D8-AD8D-7D48BFB06E65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
0x13cefa000 - 0x13cf24ff7 +libMOG_Framework.5.0.14.dylib (0) <4D5416B3-194E-30A2-B35B-7F500E754E1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.5.0.14.dylib
0x13cf42000 - 0x13d6ccfff +libMXF_SDK.5.0.14.dylib (0) <29E0F2C6-A091-3C82-9962-A0DB3071FC4E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.5.0.14.dylib
0x13dc8e000 - 0x13dca1ff7 +com.adobe.ImporterDataStream.framework (12.1.2 - 12.1.2.69) <E78A8666-3F9A-3169-9239-F93497100971> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterDataStream.bundle/Contents/MacOS/ImporterDataStream
0x13dcc7000 - 0x13dd68fff +com.adobe.AdobeSensorManager (Adobe Sensor Manager 2.0 -s 018 - 79.162672) <E5812E75-AF80-3066-B077-2A74FCF23C5A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeSensorManager.framework/Versions/A/AdobeSensorManager
0x13de10000 - 0x13dfe8fff +com.adobe.TransmitScopes.framework (12.1.2 - 12.1.2.69) <C390FFD2-1720-35AF-9413-83110826D152> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitScopes.bundle/Contents/MacOS/TransmitScopes
0x13f80d000 - 0x13f837ff7 +com.adobe.EASequenceRenderer.framework (12.1.2 - 12.1.2.69) <BA94E812-51CE-3D7C-8936-F88F0E00EAD3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/EASequenceRenderer.bundle/Contents/MacOS/EASequenceRenderer
0x13f889000 - 0x13fcdefff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
0x1401a1000 - 0x1402edfe7 +com.adobe.ExporterMPEG4.framework (12.1.2 - 12.1.2.69) <85D17E66-6CD9-3C84-A9B3-FDF3AA8DF0C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
0x14039d000 - 0x14056bfff +com.mainconcept.mc.enc.mp4v (10.5 - 10.5.17.5963) <6DC87BB2-C6B8-3606-B594-4A456FD44149> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/10/mc_enc_mp4v
0x1405af000 - 0x1405befff +com.mainconcept.mc.enc.mpa (10.5 - 10.5.17.5963) <8011D934-1E46-3917-A050-F1BD6C7DB12A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
0x1405de000 - 0x1406e6ff7 +com.mainconcept.mc.mux.mp2 (10.5 - 10.5.17.5963) <FA2E5FB7-A906-38AC-A19D-16D3B5B031E2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
0x1406fe000 - 0x1407a4fef +com.adobe.IPPMPEGDecoder.framework (12.1.2 - 12.1.2.69) <FB14E648-0856-368C-A42B-E0138F91A643> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
0x1407ef000 - 0x1407feff7 +com.adobe.TransitionsMetaPlugin.framework (12.1.2 - 12.1.2.69) <AF8E096B-A87A-3F44-868E-4B7533602178> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMetaPlugin
0x140811000 - 0x14081fff7 +com.adobe.PremiereFiltersMetaPlugin.framework (12.1.2 - 12.1.2.69) <FA8AE1CB-9997-36C8-8AAC-F11CBE825C94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereFiltersMetaPlugin
0x140831000 - 0x140967ff7 +com.adobe.ExporterMXF.framework (12.1.2 - 12.1.2.69) <AF061E97-35D2-3ACB-85A1-F3233147E223> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
0x140a06000 - 0x140a89fff +com.adobe.TransmitVR.framework (12.1.2 - 12.1.2.69) <EBAE97DE-9EAC-3484-BD5E-7F2D7419B9CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitVR.bundle/Contents/MacOS/TransmitVR
0x140b29000 - 0x140ba5ff7 +com.adobe.ExporterMPEG2.framework (12.1.2 - 12.1.2.69) <9C5C4423-F378-30C1-AB6B-A714BAFBD550> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
0x140c0b000 - 0x140c67fff +com.adobe.PlayerMediaCore.framework (12.1.2 - 12.1.2.69) <A50C7094-8BB4-3254-9D8B-ECD64499B48B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
0x140cd1000 - 0x140d04fff +com.adobe.RendererCPU.framework (12.1.2 - 12.1.2.69) <D6F9D3C4-B510-36D9-B730-DEA05C755E47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
0x140d45000 - 0x140d94fff +com.adobe.ExporterQuickTimeHost.framework (12.1.2 - 12.1.2.69) <5A393D08-B475-384B-979C-879E85E127DB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQuickTimeHost
0x140dd6000 - 0x140deeff7 +com.adobe.QTWriter.framework (12.1.2 - 12.1.2.69) <31B98252-B41F-35AE-86F6-D9BB27EFA16D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
0x140e5b000 - 0x140e9afff +com.adobe.ExporterMPEGPreview.framework (12.1.2 - 12.1.2.69) <96227B34-145C-359F-9382-2C9E5B69918B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGPreview
0x1410e4000 - 0x14111dff7 +com.mainconcept.mc.enc.aac (10.5 - 10.5.17.5963) <D4FB82FE-A372-38EA-B45F-5ACC4A72A273> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
0x14141b000 - 0x14141ffff +com.adobe.Twirl.framework (12.1.2 - 12.1.2.69) <C431B120-4F55-356F-B2A2-2769116455A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
0x14143f000 - 0x1414e2fff +com.adobe.aelib.framework (15.1.2 - 15.1.2.68) <087E9BDF-94C6-36D5-9BC9-C23134A6171C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/aelib.framework/aelib
0x1415ed000 - 0x14165afff +com.adobe.ICUData (4.0 - 3.61) <604A18BB-29F6-34EC-98D4-3CC65EA9298C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x14165f000 - 0x1416cdfff +com.adobe.boost-test.framework (12.1.2 - 12.1.2.69) <319B2595-9EDA-3D10-8EA3-F20900A9F7F4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_test.framework/Versions/A/boost_test
0x14176a000 - 0x14184ffff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.39392 - 3.8.0.39392) <B14D700D-5B31-353D-947A-CCE76A2CF281> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x1418f9000 - 0x1419c6ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.39530) <5C13ACD4-BD1F-3DF5-B8A7-B388E27D7660> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x141a0e000 - 0x141a3fff7 +com.adobe.ARE (AdobeARE 1.5.02.40104 - 1.5.02.40104) <C6C3440E-3FD8-36A9-9D5E-90E999486EE6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x141a48000 - 0x141da8fff +com.adobe.MPS (AdobeMPS 5.8.1.40104 - 5.8.1.40104) <02FC8477-213B-310D-8330-A648E85BE77C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x141e23000 - 0x1425edfff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.40112) <4EB2970C-AC64-3E1B-B67A-4B7B23581025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x142bdc000 - 0x142c01fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.39392 - 3.8.0.39392) <FC4F241D-05A6-36E1-8CFE-8FDC58F2AB2B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x142c26000 - 0x142c4cfff +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.39392 - 3.8.0.39392) <A2837D5A-14F4-3A5C-BD33-2DFA5039CF99> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedExpat
0x142c79000 - 0x142d1bff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x142d46000 - 0x142dcafff +U.dylib (0) <43C3CC11-0C31-32B3-BF12-375624B4BCC6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/U.dylib
0x142ea1000 - 0x142f8dff7 +MEE.dylib (0) <83D216FE-DD20-38FC-BCFE-218287BB4559> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MEE.dylib
0x143086000 - 0x1430ddff7 +display.dylib (0) <23CB95FF-9595-3DC1-81D1-97C343EB4E1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/display.dylib
0x14312b000 - 0x143143fff +M.dylib (0) <BA9E08E4-7A64-32C8-901E-7834B7B2C32B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/M.dylib
0x143157000 - 0x143177fff +FILE.dylib (0) <0995DABB-6017-3BB9-A9D3-D28ACE7BC3FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FILE.dylib
0x1431b5000 - 0x1431fafff +SLU.dylib (0) <30AD4361-3AF8-3F0B-8F3B-9534F6AEDEAA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SLU.dylib
0x143289000 - 0x143290fff +LIST.dylib (0) <D20BF7AA-F2BF-3AFD-B47A-BFCBBB8D1376> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LIST.dylib
0x1432a1000 - 0x1432aefff +BEZ.dylib (0) <D365A64F-DA8F-3582-8D7F-F7487986C909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEZ.dylib
0x1432b9000 - 0x1432d1fff +PREF.dylib (0) <C6F46919-5B11-35E8-9D31-7B058C54ACA1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREF.dylib
0x1432f3000 - 0x1432f6ff3 +VAL.dylib (0) <E6CCE008-C8CE-39B6-B4C9-D0B25ADA3EE2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VAL.dylib
0x1432ff000 - 0x143301ff7 +T.dylib (0) <291DE13A-BFAF-37FF-A00C-B493F87B2817> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/T.dylib
0x143311000 - 0x14335fff7 +TDB.dylib (0) <AE1B295A-3190-34BA-8C60-3EBE8859AC23> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDB.dylib
0x1433cc000 - 0x1433feff7 +MC.dylib (0) <8745408B-9DCB-3DC2-B648-33E43349ED36> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MC.dylib
0x14344f000 - 0x143484ff7 +COR.dylib (0) <2DA5CF16-8294-3FCB-B452-33B436060C1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/COR.dylib
0x1434df000 - 0x1437b5ff7 +PF.dylib (0) <718ACB33-4985-3756-95E1-6CECFCDE9458> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PF.dylib
0x143934000 - 0x143e11fff +TXT.dylib (0) <565FC3ED-E9E3-38D4-BD34-4769C298410C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TXT.dylib
0x1443ec000 - 0x14443cff7 +TDL.dylib (0) <9EB1F420-1D58-35F5-9A88-D2412C19CE27> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDL.dylib
0x14447c000 - 0x1444b7ff7 +OM.dylib (0) <1FD80A95-3F36-3B83-8E75-E480794E78C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OM.dylib
0x1444f5000 - 0x14451afff +P.dylib (0) <CBFB6FB1-CD61-37EB-8402-575D62FB394B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/P.dylib
0x144534000 - 0x14455dfff +PREM.dylib (0) <1C98433E-50AA-3690-B57B-0B284C119A0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREM.dylib
0x1445af000 - 0x1445fefff +SND.dylib (0) <E9C7F81E-F718-38EF-A89F-4AA5B5B7302A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SND.dylib
0x144684000 - 0x1448d9fff +PIN.dylib (0) <AEB340E2-1C60-3853-8702-9B1247AB3795> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PIN.dylib
0x144b38000 - 0x144b67fff +RG.dylib (0) <83F4B8FF-28C3-3F37-B478-08C66EDC09F5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RG.dylib
0x144ba9000 - 0x144c50ff7 +FLT.dylib (0) <1EADE55E-4FB0-3F22-B848-4BBAB0B34204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLT.dylib
0x144d90000 - 0x144de4ff7 +MSK.dylib (0) <1A21A0F7-CD8A-326C-A3CA-2E08FED05C3D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MSK.dylib
0x144e3f000 - 0x144ef8fff +FRP.dylib (0) <37F400AB-08B8-3868-8841-FB0CE30935B5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FRP.dylib
0x144fec000 - 0x145004fff +PR.dylib (0) <004CB06D-C1BE-3159-B6CC-A985D57FC92C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PR.dylib
0x145039000 - 0x14579eff7 +BEE.dylib (0) <E32F7614-52EB-3EEF-AACF-BCF02D5AD109> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEE.dylib
0x14641e000 - 0x146467ff7 +FLO.dylib (0) <4D52795F-3A52-39E4-8CCA-DB1DE1D1A4A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLO.dylib
0x146489000 - 0x14649afff +PLUG.dylib (0) <73416E55-A2C3-398D-AF2F-BCF809F5209F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PLUG.dylib
0x1464bb000 - 0x1464f5fef +libtbb.dylib (0) <10144FAB-48B9-34ED-833B-A3F7E65BC4ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbb.dylib
0x146538000 - 0x14655cfff +libtbbmalloc.dylib (0) <4AED21B6-C175-31A4-BA52-70A811C1B0F8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbbmalloc.dylib
0x146594000 - 0x1467a6fcf +com.adobe.AIDE (1.5.0 - 1.5.0.40084) <F51445AC-916B-3012-8872-9E633C7AF505> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x1467f6000 - 0x1468b1fff +com.adobe.dvaplayer.framework (12.1.2 - 12.1.2.69) <4DE4839D-0EC6-3C20-947C-3BACF0B5CB1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
0x146a3b000 - 0x146a4cff7 +com.adobe.GPUKernels.framework (12.1.2 - 12.1.2.69) <2BAAC10B-71D2-35A3-9E91-E163A5D2EE88> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUKernels.framework/Versions/A/GPUKernels
0x146a5b000 - 0x146a72ff7 +com.adobe.eaurl.framework (12.1.2 - 12.1.2.69) <317BA78E-888B-3312-AA15-77E2E787720A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
0x146a9f000 - 0x14a61ffdf +com.adobe.psl (AdobePSL 15.1.0.38776 - 15.1.0.38776) <22036635-21E0-35A5-8103-CCD034766DE3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x14ab17000 - 0x14ac08ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x14ac55000 - 0x14bafbfe7 +libmkl_intel_lp64.dylib (0) <3A603969-1A39-3CAB-8CED-1350DFA6DFC7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_lp64.dylib
0x14bcd3000 - 0x14d5fffff +libmkl_intel_thread.dylib (0) <B03E1F34-4E4E-3FBE-A9DE-14D37A5E440A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_thread.dylib
0x14dc75000 - 0x14f399f4f +libmkl_core.dylib (0) <ED21EAB7-AFC8-3C50-8480-E28823A5D4CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_core.dylib
0x14f63d000 - 0x14f80ffff +libicui18n.dylib (0) <1B56F6C7-045A-3A03-99C1-57D1A91A7909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicui18n.dylib
0x14f9bf000 - 0x14fb03fff +libicuuc.dylib (0) <77E17D41-9214-3C2D-B526-CE0D81FAEC05> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicuuc.dylib
0x14fbd5000 - 0x14fbe4fff +libv8_libbase.dylib (0) <7CD26441-BBE7-3BFF-9935-7BCC739ADE37> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libbase.dylib
0x14fbfe000 - 0x14fc09fff +libv8_libplatform.dylib (0) <9EA88668-D5D6-3FC1-B9C6-CE1E53D228CE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libplatform.dylib
0x14fc1c000 - 0x1506cbff7 +libv8.dylib (0) <1A68B9C1-DC1C-3A70-83A4-73890130CAF9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8.dylib
0x151c58000 - 0x152a74f47 +com.adobe.AEFilterLumetri.framework (12.1.2 - 12.1.2.69) <61BB3526-653E-3EBC-AE6B-233383E03E11> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/AEFilterLumetri.bundle/Contents/MacOS/AEFilterLumetri
0x154800000 - 0x15494fff7 +IMSLib.dylib (10.0.0.32 - 10.0.0.32) <783F52A5-B8B2-39E0-811A-A733A6389E1B> /Library/Application Support/Adobe/*/IMSLib.dylib
0x15914a000 - 0x1591bbff7 +com.adobe.ImporterMPEG.framework (12.1.2 - 12.1.2.69) <8BECA63D-BD7F-38CE-82E6-A2F78D42F2A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
0x159b00000 - 0x159b37fff +com.adobe.ImporterXDCAMEX.framework (12.1.2 - 12.1.2.69) <F8F00C95-D399-3EE3-B949-303A9F42F134> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterXDCAMEX.bundle/Contents/MacOS/ImporterXDCAMEX
0x15b600000 - 0x15b725ff7 +com.adobe.ExporterP2.framework (12.1.2 - 12.1.2.69) <65EE7500-1BF3-31AE-A23F-188C5AFF9B6F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterP2.bundle/Contents/MacOS/ExporterP2
0x15beac000 - 0x15faf6f7f +com.adobe.Stabilizer.framework (12.1.2 - 12.1.2.69) <1DD4FE65-79B9-3FAA-94CF-649662BB49E7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/Stabilizer.bundle/Contents/MacOS/Stabilizer
0x173510000 - 0x1737bbfff +com.mainconcept.mc.demux.mp4 (10.5 - 10.5.17.5963) <8CFE55D7-C41F-3162-84BC-66D89DCDE09B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_demux_mp4.framework/Versions/10/mc_demux_mp4
0x1e7802000 - 0x1e783efff +com.mainconcept.mc.dec.aac (10.5 - 10.5.17.5963) <442A94E1-CBD1-339D-8BBF-B054FE63EE7F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_aac.framework/mc_dec_aac
0x23261f000 - 0x2327effff com.apple.AppleIntelHD5000GraphicsVADriver (10.36.19 - 10.3.6) <52050BB7-9129-3769-BF99-033CB5A8EED3> /System/Library/Extensions/AppleIntelHD5000GraphicsVADriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsVADriver
0x7fff27bf2000 - 0x7fff27bf3fff libLatin5Converter.dylib (70) <AEE99722-8FF4-3A67-BEF9-38F11E66AE30> /System/Library/CoreServices/Encodings/libLatin5Converter.dylib
0x7fff27c33000 - 0x7fff27f81ff7 com.apple.RawCamera.bundle (8.05.0 - 1017.4.1) <CAF490E6-CB0E-3EF0-B3D2-C4880CF85077> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff29590000 - 0x7fff29615ff7 com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.36.19 - 10.3.6) <1EB5AE0D-E027-3FDF-8258-2830487FFAEA> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
0x7fff2b850000 - 0x7fff2b854ffb com.apple.agl (3.3.1 - AGL-3.3.1) <9B886891-66A5-3026-8C61-61B3C5F4EAC9> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff2b855000 - 0x7fff2ba35ff3 com.apple.avfoundation (2.0 - 1536.36) <BB65ED51-CE44-31BD-A6EC-4B1EC5EADDD9> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff2ba36000 - 0x7fff2baeffff com.apple.audio.AVFAudio (1.0 - ???) <ECE63BA3-4344-3522-904B-71F89677AC7D> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff2bbf5000 - 0x7fff2bbf5fff com.apple.Accelerate (1.11 - Accelerate 1.11) <8632A9C5-19EA-3FD7-A44D-80765CC9C540> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff2bbf6000 - 0x7fff2bc0cfef libCGInterfaces.dylib (417.2) <2E67702C-75F6-308A-A023-F28120BEE667> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff2bc0d000 - 0x7fff2c10bfc3 com.apple.vImage (8.1 - ???) <A243A7EF-0C8E-3A9A-AA38-44AFD7507F00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff2c10c000 - 0x7fff2c266fe3 libBLAS.dylib (1211.50.2) <62C659EB-3E32-3B5F-83BF-79F5DF30D5CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff2c267000 - 0x7fff2c295fef libBNNS.dylib (38.1) <7BAEFDCA-3227-3E07-80D8-59B6370B89C6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2c296000 - 0x7fff2c655ff7 libLAPACK.dylib (1211.50.2) <40ADBA5F-8B2D-30AC-A7AD-7B17C37EE52D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2c656000 - 0x7fff2c66bff7 libLinearAlgebra.dylib (1211.50.2) <E8E0B7FD-A0B7-31E5-AF01-81781F71EBBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff2c66c000 - 0x7fff2c671ff3 libQuadrature.dylib (3) <3D6BF66A-55B2-3692-BAC7-DEB0C676ED29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2c672000 - 0x7fff2c6f2fff libSparse.dylib (79.50.2) <0DC25CDD-F8C1-3D6E-B472-8B060708424F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff2c6f3000 - 0x7fff2c706fff libSparseBLAS.dylib (1211.50.2) <722573CC-31CC-34B2-9032-E4F652A9CCFE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2c707000 - 0x7fff2c8b4fc3 libvDSP.dylib (622.50.5) <40690941-CF89-3F90-A0AC-A4D200744A5D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff2c8b5000 - 0x7fff2c966fff libvMisc.dylib (622.50.5) <BA2532DF-2D68-3DD0-9B59-D434BF702AA4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2c967000 - 0x7fff2c967fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <54FF3B43-E66C-3F36-B34B-A2B3B0A36502> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2c968000 - 0x7fff2c9c2ff7 com.apple.Accounts (113 - 113) <D2892B2B-2846-3E75-9A4B-224A9F343A44> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff2c9c3000 - 0x7fff2cc5aff7 com.apple.AddressBook.framework (11.0 - 1808.8) <8D6ED6A3-1E6A-39F6-A189-753C4A193399> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff2cc5b000 - 0x7fff2dab9fff com.apple.AppKit (6.9 - 1561.60.100) <3C27CF6F-E640-3411-A87D-CCB2222CC754> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2db0b000 - 0x7fff2db0bfff com.apple.ApplicationServices (48 - 50) <AFFBD94A-AF76-336E-B53E-57524EAE8EF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2db0c000 - 0x7fff2db72fff com.apple.ApplicationServices.ATS (377 - 445.4) <85E779EE-0219-3181-B4C4-201E4CC82AB5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2dc0b000 - 0x7fff2dd2dfff libFontParser.dylib (222.1.6) <6CEBACDD-B848-302E-B4B2-630CB16E663E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff2dd2e000 - 0x7fff2dd78ff7 libFontRegistry.dylib (221.4) <5FDB4F1A-E15C-3ACB-A5C1-F15458C0C6DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff2ddca000 - 0x7fff2ddcfff7 libFontRegistryUI.dylib (221.4) <09BB15BF-DF27-39E2-A056-53A8951D0C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistryUI.dylib
0x7fff2de1d000 - 0x7fff2de50ff7 libTrueTypeScaler.dylib (222.1.6) <9147F859-8BD9-31D9-AB54-8E9549B92AE9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff2de51000 - 0x7fff2deb9fff libType1Scaler.dylib (136.1) <73EDEE71-E58E-36B5-A027-E28A69D61771> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x7fff2deba000 - 0x7fff2debeff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <A5FB2694-1559-34A8-A3D3-2029F68A63CA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2df5e000 - 0x7fff2dfb0ffb com.apple.HIServices (1.22 - 624.1) <66FD9ED2-9630-313C-86AE-4C2FBCB3F351> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff2dfb1000 - 0x7fff2dfbffff com.apple.LangAnalysis (1.7.0 - 1.7.0) <B65FF7E6-E9B5-34D8-8CA7-63D415A8A9A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2dfc0000 - 0x7fff2e00cfff com.apple.print.framework.PrintCore (13.4 - 503.2) <B90C67C1-0292-3CEC-885D-F1882CD104BE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2e00d000 - 0x7fff2e047fff com.apple.QD (3.12 - 404.2) <38B20AFF-9D54-3B52-A6DC-C0D71380AA5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2e048000 - 0x7fff2e054fff com.apple.speech.synthesis.framework (7.8.1 - 7.8.1) <A08DE016-C8F2-3B0E-BD34-15959D13DBF0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2e055000 - 0x7fff2e2e3ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <E0B8B5D8-80A0-308B-ABD6-F8612102B5D8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2e2e5000 - 0x7fff2e2e5fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <ABF8778E-4F9D-305E-A528-DE406A1A2B68> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff2e2e6000 - 0x7fff2e426ff3 com.apple.AudioVideoBridging (680.2 - 680.2) <27B96E03-3A32-3666-A1C5-7E4FC3042810> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x7fff2e608000 - 0x7fff2e9a2ff7 com.apple.CFNetwork (902.1 - 902.1) <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff2e9b7000 - 0x7fff2e9b7fff com.apple.Carbon (158 - 158) <F8B370D9-2103-3276-821D-ACC756167F86> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff2e9b8000 - 0x7fff2e9bbffb com.apple.CommonPanels (1.2.6 - 98) <2391761C-5CAA-3F68-86B7-50B37927B104> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff2e9bc000 - 0x7fff2ecc1fff com.apple.HIToolbox (2.1.1 - 911.10) <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2ecc2000 - 0x7fff2ecc5ffb com.apple.help (1.3.8 - 66) <DEBADFA8-C189-3195-B0D6-A1F2DE95882A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff2ecc6000 - 0x7fff2eccbfff com.apple.ImageCapture (9.0 - 9.0) <23B4916F-3B43-3DFF-B956-FC390EECA284> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff2eccc000 - 0x7fff2ed61ffb com.apple.ink.framework (10.9 - 221) <5206C8B0-22DA-36C9-998E-846EDB626D5B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff2ed62000 - 0x7fff2ed7cff7 com.apple.openscripting (1.7 - 174) <1B2A1F9E-5534-3D61-83CA-9199B39E8708> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff2ed9d000 - 0x7fff2ed9efff com.apple.print.framework.Print (12 - 267) <3682ABFB-2561-3419-847D-02C247F4800D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff2ed9f000 - 0x7fff2eda1ff7 com.apple.securityhi (9.0 - 55006) <C1406B8D-7D05-3959-808F-9C82189CF57F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff2eda2000 - 0x7fff2eda8fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2ED8643D-B0C3-3F17-82A2-BBF13E6CBABC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2eec9000 - 0x7fff2eec9fff com.apple.Cocoa (6.11 - 22) <78E6C28E-4308-3D10-AD14-0CBCF6789B3F> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff2eed7000 - 0x7fff2ef90fff com.apple.ColorSync (4.13.0 - 3325) <D283C285-447D-3258-A7E4-59532123B8FF> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff2f11d000 - 0x7fff2f1b0ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EB35D3EC-56EA-33E6-98DC-BDC3A5FA8ACE> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff2f1b2000 - 0x7fff2f216ff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <1F8BBEB7-E177-35FA-A1B5-17DC1F4593F1> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x7fff2f217000 - 0x7fff2f240ffb com.apple.CoreBluetooth (1.0 - 1) <E1335074-9D07-370E-8440-61C4874BAC56> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff2f241000 - 0x7fff2f597fef com.apple.CoreData (120 - 851) <A2B59780-FB16-36A3-8EE0-E0EF072454E0> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff2f598000 - 0x7fff2f67bfff com.apple.CoreDisplay (99.14 - 99.14) <A1B91ADD-828D-33A0-8A92-CC3F83DF89D0> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff2f67c000 - 0x7fff2fb1dfef com.apple.CoreFoundation (6.9 - 1454.90) <E5D594BF-9142-3325-A62D-CF4AAF472642> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2fb1f000 - 0x7fff3012ffef com.apple.CoreGraphics (2.0 - 1161.21) <375C477F-5A89-3C49-9B63-373C81A63F7E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff30131000 - 0x7fff30420fff com.apple.CoreImage (13.0.0 - 579.5) <AAE2DFD0-9B0A-3D56-8A3E-C460BAF70394> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff3048d000 - 0x7fff304d2fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <BC3E756C-A066-325C-9383-A78A4A66C7BF> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff306af000 - 0x7fff307a5ffb com.apple.CoreMedia (1.0 - 2276.68) <5F0001EF-10FF-3334-9170-7FD5FB026205> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff307a6000 - 0x7fff307f4fff com.apple.CoreMediaIO (814.0 - 4995) <4A7FA7DF-4F7C-3378-AE5F-A33273B2FEA6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff307f5000 - 0x7fff307f5fff com.apple.CoreServices (822.36 - 822.36) <C8368F17-1589-3BA5-A0E7-89CB8DF2454F> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff307f6000 - 0x7fff3086affb com.apple.AE (735.1 - 735.1) <08EBA184-20F7-3725-AEA6-C314448161C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff3086b000 - 0x7fff30b42fff com.apple.CoreServices.CarbonCore (1178.4 - 1178.4) <0D5E19BF-18CB-3FA4-8A5F-F6C787C5EE08> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff30b43000 - 0x7fff30b77fff com.apple.DictionaryServices (1.2 - 284.2) <6505B075-41C3-3C62-A4C3-85CE3F6825CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff30b78000 - 0x7fff30b80ffb com.apple.CoreServices.FSEvents (1239.50.1 - 1239.50.1) <3637CEC7-DF0E-320E-9634-44A442925C65> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff30b81000 - 0x7fff30d3efff com.apple.LaunchServices (822.36 - 822.36) <6E68C090-B12D-3D3D-9617-E5D82C36B2D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff30d3f000 - 0x7fff30defff7 com.apple.Metadata (10.7.0 - 1191.4.13) <B5C22E70-C265-3C9F-865F-B138994A418D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff30df0000 - 0x7fff30e50fff com.apple.CoreServices.OSServices (822.36 - 822.36) <3BB2E0CE-81AE-3D3D-9FCE-E1B7FC6D6A61> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff30e51000 - 0x7fff30ebffff com.apple.SearchKit (1.4.0 - 1.4.0) <3662545A-B1CF-3079-BDCD-C83855CEFEEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff30ec0000 - 0x7fff30ee4ffb com.apple.coreservices.SharedFileList (71.21 - 71.21) <35582D88-5975-35E2-A29A-E3148C3EE727> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff31185000 - 0x7fff312d5fff com.apple.CoreText (352.0 - 578.22) <6129F39D-284D-3BBF-8999-7854AB61C01C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff312d6000 - 0x7fff31310fff com.apple.CoreVideo (1.8 - 0.0) <86CCC036-51BB-3DD1-9601-D93798BCCD0F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff31311000 - 0x7fff3139cff3 com.apple.framework.CoreWLAN (13.0 - 1350.1) <E862CC02-69D2-3503-887B-B6E8223081E7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3152a000 - 0x7fff31535ff7 com.apple.DirectoryService.Framework (10.13 - 207.50.1) <BE0D8038-7974-3B06-80E1-31E27E5CD634> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff31536000 - 0x7fff315f0fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <35D1FF9A-432C-39AD-9C1F-9022246EC5C0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff31617000 - 0x7fff3161cfff com.apple.DiskArbitration (2.7 - 2.7) <A975AD56-4CD3-3A89-8732-858CA9BD3DAA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff317dd000 - 0x7fff31ba3fff com.apple.Foundation (6.9 - 1454.90) <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff31c14000 - 0x7fff31c44fff com.apple.GSS (4.0 - 2.0) <D774A165-5581-3479-AB5D-2BBDB5CF8882> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff31d56000 - 0x7fff31e5affb com.apple.Bluetooth (6.0.7 - 6.0.7f10) <557F26F9-C7A0-34EA-A905-22E243BF6B48> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff31eba000 - 0x7fff31f55fff com.apple.framework.IOKit (2.0.2 - 1445.71.1) <2EA4F383-CAA9-3AF0-99C5-90C22ADAA6B6> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff31f57000 - 0x7fff31f5efff com.apple.IOSurface (211.15 - 211.15) <9FD406F1-6BF2-35B0-8339-DF83A1A661EB> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff31f5f000 - 0x7fff31fb4ff3 com.apple.ImageCaptureCore (7.0 - 7.0) <0DAB3D7E-8C3F-35DE-96DF-C370AD35EB65> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff31fb5000 - 0x7fff3212fff7 com.apple.ImageIO.framework (3.3.0 - 1739.3) <7C579D3F-AE0B-31C9-8F80-67F2290B8DE0> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff32130000 - 0x7fff32134ffb libGIF.dylib (1739.3) <7AA44C9D-48E8-3090-B044-61FE6F0AEF38> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff32135000 - 0x7fff3221cfef libJP2.dylib (1739.3) <AEBF7260-0C10-30C0-8F0F-8B347DEE78B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3221d000 - 0x7fff32240ff7 libJPEG.dylib (1739.3) <D8C966AD-A00C-3E8B-A7ED-D7CC7ECB3224> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff3251c000 - 0x7fff32542feb libPng.dylib (1739.3) <1737F680-99D1-3F03-BFA5-5CDA30EB880A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff32543000 - 0x7fff32545ffb libRadiance.dylib (1739.3) <21746434-FCC7-36DE-9331-11277DF66AA8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff32546000 - 0x7fff32594fef libTIFF.dylib (1739.3) <C4CB5C1D-20F2-3BD4-B0E6-629FDB3EF8E8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff32750000 - 0x7fff33436fff com.apple.JavaScriptCore (13605 - 13605.3.8) <E6B49CDA-72F0-3E58-85EF-98AF10CE04B0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff3344e000 - 0x7fff33467ff7 com.apple.Kerberos (3.0 - 1) <F86DCCDF-93C1-38B3-82C2-477C12E8EE6D> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff33468000 - 0x7fff3349dfff com.apple.LDAPFramework (2.4.28 - 194.5) <08888215-BBCE-3402-8142-2C9ADB091580> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff33726000 - 0x7fff3372dfff com.apple.MediaAccessibility (1.0 - 114) <9F72AACD-BAEB-3646-BD0F-12C47591C20D> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff337dd000 - 0x7fff33e47ff7 com.apple.MediaToolbox (1.0 - 2276.68) <CB6791F2-B401-360E-9531-BFBC5138254E> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff33e49000 - 0x7fff33ecafff com.apple.Metal (125.30 - 125.30) <975FD6B5-D695-346A-869F-0584A968D100> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff33ecc000 - 0x7fff33ee6ffb com.apple.MetalKit (1.0 - 98.3) <03D5FD53-3419-3464-B297-C95FA3CBCDAB> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff33ee7000 - 0x7fff33f02fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <AD754E8F-CA00-3878-9AF3-208C224A230B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff33f03000 - 0x7fff33f72fef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <338B7779-E608-3D68-8A07-2ACC11299744> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff33f73000 - 0x7fff33f97fff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <9CE072D7-853B-3939-9645-7EB951376B87> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff33f98000 - 0x7fff3407fff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <0DE891AD-27E5-38FF-AEC8-4A95356C4357> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff34080000 - 0x7fff34080ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <2D2D261C-50B0-32F9-BF9A-5C01382BB528> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3507f000 - 0x7fff3508bffb com.apple.NetFS (6.0 - 4.0) <471DD96F-FA2E-3FE9-9746-2519A6780D1A> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff37e74000 - 0x7fff37e7cfef libcldcpuengine.dylib (2.8.7) <EF9A91AC-029C-300A-99E7-4952C15DA09F> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff37e7d000 - 0x7fff37ed7ff7 com.apple.opencl (2.8.24 - 2.8.24) <4D7401A7-6ADD-3632-85AE-7A5012DFFA04> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff37ed8000 - 0x7fff37ef4ffb com.apple.CFOpenDirectory (10.13 - 207.50.1) <29F55F7B-379F-3053-8FF3-5C6675A3DD4D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff37ef5000 - 0x7fff37f00fff com.apple.OpenDirectory (10.13 - 207.50.1) <F895547D-4915-353F-9C1E-E95172BA803B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff3907f000 - 0x7fff39081fff libCVMSPluginSupport.dylib (16.7.4) <F9270AE0-CC3B-3E3E-BA32-CC1068DD8F27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff39082000 - 0x7fff39087ffb libCoreFSCache.dylib (162.9) <7AF87F3E-D5D0-3625-BE09-CA4223195466> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff39088000 - 0x7fff3908cfff libCoreVMClient.dylib (162.9) <115FE643-6141-39B4-8193-77DFCBE7A4E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff3908d000 - 0x7fff39096ff3 libGFXShared.dylib (16.7.4) <EB2BF8A0-E10D-35EA-8F46-B2E3C62C12A8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff39097000 - 0x7fff390a2fff libGL.dylib (16.7.4) <2BB333D3-5C61-33DF-8545-06DF2D08B83D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff390a3000 - 0x7fff390defe7 libGLImage.dylib (16.7.4) <4DA003CE-0B74-3FE4-808C-B2FBCE517EB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff390df000 - 0x7fff3924cff3 libGLProgrammability.dylib (16.7.4) <ECC9D79B-C0B1-33F9-A9BB-097EF12D9E13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff3924d000 - 0x7fff3928bffb libGLU.dylib (16.7.4) <BCB09CD8-EB0E-38FA-8B5A-9E29532EE364> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff39c03000 - 0x7fff39c12ff3 com.apple.opengl (16.7.4 - 16.7.4) <9BDE8FF9-5418-3C70-8D1C-09656884CE48> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff39c13000 - 0x7fff39daaff3 GLEngine (16.7.4) <E2EE1D9C-826E-3DA9-9DCA-2FF371CDE5BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff39dab000 - 0x7fff39dd3ffb GLRendererFloat (16.7.4) <3B51AC1B-0A3C-30E5-80EB-F64EBB1B1F77> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff39f8c000 - 0x7fff3a0d8ff7 com.apple.QTKit (7.7.3 - 3014.8) <FEDEF531-50A3-32AB-A546-E6BA994C58E1> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff3a0d9000 - 0x7fff3a33eff7 com.apple.imageKit (3.0 - 1043) <6C19A20B-6D0D-380A-A87D-F923658E1726> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff3a33f000 - 0x7fff3a42effb com.apple.PDFKit (1.0 - 677.67) <6BD11C23-1AEA-3078-8D0C-A7152BCF9031> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff3a42f000 - 0x7fff3a941ff7 com.apple.QuartzComposer (5.1 - 364) <1369D6DA-8842-3878-B546-1D09828331F5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff3a942000 - 0x7fff3a965fff com.apple.quartzfilters (1.10.0 - 1.10.0) <C95CB89D-148D-341B-BC50-82D8C32BF767> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff3a966000 - 0x7fff3aa5fff7 com.apple.QuickLookUIFramework (5.0 - 743.13) <093180B8-FB25-3292-AD99-1791CF8D6EBF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff3aa60000 - 0x7fff3aa60fff com.apple.quartzframework (1.5 - 21) <DCEB0FCC-2C32-3D02-8752-7B6FA009AB85> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff3aa61000 - 0x7fff3acadff7 com.apple.QuartzCore (1.11 - 584.62) <1950D993-DE48-3C97-95A5-66D98BDFC95D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff3acae000 - 0x7fff3ad05ff7 com.apple.QuickLookFramework (5.0 - 743.13) <8254FFF2-EE0D-323D-A6F3-BEB59615EE47> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff3aecb000 - 0x7fff3aee2ff7 com.apple.SafariServices.framework (13605 - 13605.3.8) <57BAA02F-C55A-3D8A-AFD3-25118323C0B2> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff3b4ca000 - 0x7fff3b4e1fff com.apple.ScriptingBridge (1.3.3 - 70) <2C987E75-B409-3824-84E8-0F1DD6B96E8B> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff3b4e2000 - 0x7fff3b80dfff com.apple.security (7.0 - 58286.70.7) <9FC166E1-14D0-305C-A086-02B9E83F547E> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3b80e000 - 0x7fff3b89aff7 com.apple.securityfoundation (6.0 - 55185.50.5) <D708D069-AEDB-36C2-B1DA-479DA91D7711> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff3b89b000 - 0x7fff3b8cbfff com.apple.securityinterface (10.0 - 55109.50.6) <3C20BE54-8115-3C7B-9719-F746A9EBF72B> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff3b8cc000 - 0x7fff3b8d0ffb com.apple.xpc.ServiceManagement (1.0 - 1) <71B45D83-ECA4-3265-997E-683A8B8DF413> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff3bc75000 - 0x7fff3bce5ff3 com.apple.SystemConfiguration (1.17 - 1.17) <8532B8E9-7E30-35A3-BC4A-DDE8E0614FDA> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff3be9a000 - 0x7fff3c215fff com.apple.VideoToolbox (1.0 - 2276.68) <8F6FBC7D-60EA-38B2-B583-7ECB58E8936E> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff3c4bd000 - 0x7fff3ca1cfeb libwebrtc.dylib (7605.3.8) <BCFA176B-4553-386B-B2E7-E578AC89E3E2> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff3ca1d000 - 0x7fff3e0f0ff7 com.apple.WebCore (13605 - 13605.3.8) <2F0DA536-2C93-3EB2-9FFE-13AE1B40C4DC> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff3e0f1000 - 0x7fff3e2d8ff7 com.apple.WebKitLegacy (13605 - 13605.3.8) <048392B7-89A6-37C0-9544-26D4E5A62B22> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff3e2d9000 - 0x7fff3e772fff com.apple.WebKit (13605 - 13605.3.8) <7E5D9855-D1CC-382D-B8EB-25A030D4B2FA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff3ebe2000 - 0x7fff3ec75fff com.apple.APFS (1.0 - 1) <6BBB3988-1C91-314F-A77A-4E093A1B18F0> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff3f8a0000 - 0x7fff3f8c8fff com.apple.framework.Apple80211 (13.0 - 1361.7) <16627876-8CF5-3502-A1D6-35FCBDD5E79A> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff3f8ca000 - 0x7fff3f8d9fef com.apple.AppleFSCompression (96.60.1 - 1.0) <A7C875C4-F5EE-3272-AFB6-57C9FD5352B3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff3f8da000 - 0x7fff3f9c4fff com.apple.AppleGVAFramework (11.6.8 - 11.6.8) <78A7C668-4A39-34C9-9309-F3C418487D6F> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0x7fff3f9d8000 - 0x7fff3f9e3ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <2FAF5567-CDB3-33EF-AB71-05D37F2248B7> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff3fa1d000 - 0x7fff3fa65ff3 com.apple.AppleJPEG (1.0 - 1) <8DD410CB-76A1-3F22-9A9F-0491FA0CEB4A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff3fa78000 - 0x7fff3fa96ff3 com.apple.aps.framework (4.0 - 4.0) <142A38BC-8266-3462-86A7-C39198651F2A> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff3fa97000 - 0x7fff3fa9fff3 com.apple.AppleSRP (5.0 - 1) <4CEC34CF-63E3-3023-B61B-F8D133698534> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff3faa0000 - 0x7fff3fac8fff com.apple.applesauce (1.0 - ???) <CCA8B094-1BCE-3AE3-A0A7-D544C818DE36> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff3fb91000 - 0x7fff3fb94ff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <0E33401D-7B9C-378A-8EE8-0E3D40B63C8D> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff3fb95000 - 0x7fff3fbe5ff7 com.apple.AppleVAFramework (5.0.41 - 5.0.41) <14E91E09-C345-3C5F-8D3C-4BC291FAF796> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff3fdf6000 - 0x7fff3fe0efff com.apple.AudioServerApplication (1.0 - 312.1) <AFC4AC55-9F37-388F-9D99-A5ECA1233689> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
0x7fff3ff1a000 - 0x7fff401b3ffb com.apple.AuthKit (1.0 - 1) <6CA71A11-91C5-307C-B933-9FCDEDCB580A> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff402ea000 - 0x7fff402f1ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <51A41CA3-DB1D-3380-993E-99C54AEE518E> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff402f2000 - 0x7fff40379ff7 com.apple.backup.framework (1.9.5 - 1.9.5) <5E7B0925-8C71-353D-BB0F-9CA144BB264C> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff40382000 - 0x7fff40388ff7 com.apple.BezelServicesFW (305.1 - 305.1) <7D2C4717-FFF2-3262-B822-1982596BE46B> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
0x7fff403f3000 - 0x7fff4042ffff com.apple.bom (14.0 - 194.2) <EAC5AB86-CC57-3ACD-8C71-B6F91A062D9B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff40a63000 - 0x7fff40a90fff com.apple.CalendarAgentLink (8.0 - 250) <55B60B04-2EAA-3F22-88EF-1602129D5294> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fff4115b000 - 0x7fff411aaff3 com.apple.ChunkingLibrary (189 - 189) <C021A0EB-82E7-3A1E-A772-96B0E7E038D9> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff411b1000 - 0x7fff41242ff7 com.apple.CloudDocs (1.0 - 575.14) <9A1EB33C-5038-336C-8EB8-1ED0B736E76F> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff41d33000 - 0x7fff41d3cff3 com.apple.CommonAuth (4.0 - 2.0) <4D237B25-27E5-3577-948B-073659F6D3C0> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff41d51000 - 0x7fff41d66ff7 com.apple.commonutilities (8.0 - 900) <5EC02BD4-F1F8-3A96-BE1A-6620D3080CD4> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff41f95000 - 0x7fff41ff5fff com.apple.AddressBook.ContactsFoundation (8.0 - ???) <997AADA4-DD8A-38C5-B441-C3FEDC5AFCE7> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff41ff6000 - 0x7fff42018fff com.apple.contacts.ContactsPersistence (1.0 - 2330.3) <B7EA2D0A-8A43-3E9C-A7D2-E9585064C328> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff42078000 - 0x7fff42480fff com.apple.CoreAUC (259.0.0 - 259.0.0) <B3D5289B-9E8A-37FE-855B-7277D700029E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff42481000 - 0x7fff424b1ff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <E9FF9574-122A-3966-AA2B-546E512ACD06> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff42548000 - 0x7fff4258cff3 com.apple.corebrightness (1.0 - 1) <7E67395F-F587-3EE2-AE98-339EC152807C> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff426cb000 - 0x7fff426d4ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <35A43584-2AF8-3202-A139-27D916E444BE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff42842000 - 0x7fff42852ff7 com.apple.CoreEmoji (1.0 - 69.3) <A4357F5C-0C38-3A61-B456-D7321EB2CEE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff42b56000 - 0x7fff42b6cff7 com.apple.CoreMediaAuthoring (2.2 - 956) <FBA28A76-97E2-3023-A3F6-D03280AE2889> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff42cb5000 - 0x7fff42d12ff7 com.apple.CoreNLP (1.0 - 130.5.4) <1FDB3609-F745-3874-84EB-473570632E50> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff42e9b000 - 0x7fff42ea0ff7 com.apple.CoreOptimization (1.0 - 1) <785B622B-8F7D-3B4D-83AF-EB98CB79FFF6> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff42ea1000 - 0x7fff42f46fff com.apple.CorePDF (4.0 - 414) <D64D17C3-9AD0-3A29-89DE-36BEF0156381> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff42fe6000 - 0x7fff42feeff3 com.apple.CorePhoneNumbers (1.0 - 1) <A5D41251-9F38-3AB9-9DE7-F77023FAAA44> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff42fef000 - 0x7fff4304bfff com.apple.CorePrediction (1.0 - 1) <A26425DF-E222-333B-8CAE-6141A58B172C> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff43179000 - 0x7fff431aaff3 com.apple.CoreServicesInternal (309.1 - 309.1) <4ECD14EA-A493-3B84-A32F-CF928474A405> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff434e7000 - 0x7fff43578fff com.apple.CoreSymbolication (9.3 - 64026.2) <D55A6E5B-0267-3F3A-8D90-4B8F39458420> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff435fb000 - 0x7fff43730fff com.apple.coreui (2.1 - 494.1) <B2C515C3-FCE8-3B28-A225-05AD917F509B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff43731000 - 0x7fff43862fff com.apple.CoreUtils (5.6 - 560.11) <1A02D6F0-8C65-3FAE-AD63-56477EDE4773> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff438b7000 - 0x7fff4391bfff com.apple.framework.CoreWiFi (13.0 - 1350.1) <6EC5DEB3-6E2F-3DC2-BE59-1FD05175FB0C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff4391c000 - 0x7fff4392cff7 com.apple.CrashReporterSupport (10.13 - 1) <A909F468-0648-3F51-A77E-3F9ADBC9A941> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff439aa000 - 0x7fff439b9ff7 com.apple.framework.DFRFoundation (1.0 - 191.7) <5F486F5A-3795-3CD4-86A2-FD008A23F205> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff439bc000 - 0x7fff439c0ffb com.apple.DSExternalDisplay (3.1 - 380) <901B7F6D-376A-3848-99D0-170C4D00F776> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff43a01000 - 0x7fff43a41ffb com.apple.datadetectors (5.0 - 376.1) <12BF834C-0B19-3719-BCC4-796568901107> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff43a42000 - 0x7fff43ab8fff com.apple.datadetectorscore (7.0 - 590.3) <7437160E-68A3-3FD7-8868-5E3F92E23C4F> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff43b06000 - 0x7fff43b46ff7 com.apple.DebugSymbols (181.0 - 181.0) <299A0238-ED78-3676-B131-274D972824AA> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff43b47000 - 0x7fff43c76fff com.apple.desktopservices (1.12.5 - 1.12.5) <7739C9A5-64D9-31A5-899B-5FFA242AD70D> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff43ce8000 - 0x7fff43ce9ff7 com.apple.diagnosticlogcollection (10.0 - 1000) <DA2427D1-82AA-3718-907F-05543665184B> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x7fff43d81000 - 0x7fff43e53ff7 com.apple.DiskImagesFramework (480.60.1 - 480.60.1) <4E7AE146-A4A2-3ABE-9BCC-25BD443D8569> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff43f43000 - 0x7fff43f47ff7 com.apple.DisplayServicesFW (3.1 - 380) <6F0B8AC6-7E62-3DFC-B373-BF04833724C0> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff43fd0000 - 0x7fff43fd3fff com.apple.EFILogin (2.0 - 2) <63C8BB1B-B694-3B1B-A046-FC0C9CEC9454> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff44736000 - 0x7fff4474efff com.apple.Engram (1.0 - 1) <47B568AF-DF75-3039-AD55-802A2C826D08> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
0x7fff44a90000 - 0x7fff44ebefff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <B574FE33-4A41-3611-9738-388EBAF03E37> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff44ef1000 - 0x7fff44f7aff3 com.apple.FileProvider (125.15 - 125.15) <037018DD-011E-33AB-A112-85C32DC211BA> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff46b1a000 - 0x7fff46b1afff libmetal_timestamp.dylib (802.4.8) <311A8FAA-5FA9-3AAF-887E-DC9884DE8BE5> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_timestamp.dylib
0x7fff4817a000 - 0x7fff48185ff7 libGPUSupportMercury.dylib (16.7.4) <A4D6F79C-1DFA-3E96-8F76-4882FBEDE9CF> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff48186000 - 0x7fff4818bfff com.apple.GPUWrangler (3.20.13 - 3.20.13) <9C5BD618-69E3-36D5-9BC9-A4841BC00D2A> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff4853f000 - 0x7fff48564ff3 com.apple.GenerationalStorage (2.0 - 285.3) <13B96400-FF70-376B-B20E-FB7D61064800> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff48f01000 - 0x7fff48f10fff com.apple.GraphVisualizer (1.0 - 5) <B993B8A2-5700-3DFC-9EB7-4CCEE8F959F1> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff48f93000 - 0x7fff49007fff com.apple.Heimdal (4.0 - 2.0) <93091531-CC91-34FF-8B93-5D3F02C37BC5> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff49008000 - 0x7fff49036fff com.apple.HelpData (2.3 - 167.2) <F391924B-1F5B-3FE5-9190-5EE9F40CA0D3> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff490a2000 - 0x7fff491b7fff com.apple.ids (10.0 - 1000) <1FA94847-2FD8-3B36-A1F1-CF6BB4FF53A1> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fff491b8000 - 0x7fff49298ffb com.apple.idsfoundation (10.0 - 1000) <EB8ADD29-C011-3BD1-A5E7-407F5C09F40F> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fff497e8000 - 0x7fff4984eff3 com.apple.imfoundation (10.0 - 1000) <E91460AB-5A38-30FE-AE08-659BF0C31971> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff49917000 - 0x7fff4991eff7 com.apple.IOAccelerator (378.26 - 378.26) <2274BE11-18DE-3B13-BCDB-C488C9BB19AD> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff49922000 - 0x7fff49939fff com.apple.IOPresentment (1.0 - 35.1) <7C6332FF-6535-3064-B437-1E9F70671927> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff49d04000 - 0x7fff49d2affb com.apple.IconServices (97.6 - 97.6) <A56D826D-20D2-34BE-AACC-A80CFCB4E915> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff49e37000 - 0x7fff49e3aff3 com.apple.InternationalSupport (1.0 - 1) <5AB382FD-BF81-36A1-9565-61F1FD398ECA> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff49ea8000 - 0x7fff49eb8ffb com.apple.IntlPreferences (2.0 - 227.5.2) <DA6BC4CA-14F5-3A83-82B6-812344A050D2> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff49faf000 - 0x7fff49fc2ff3 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <AED421B0-90A0-3969-98A4-CCBCF2D3360B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff49fc3000 - 0x7fff4a0b8ff7 com.apple.LanguageModeling (1.0 - 159.5.3) <7F0AC200-E3DD-39FB-8A95-00DD70B66A9F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff4a0b9000 - 0x7fff4a0fbfff com.apple.Lexicon-framework (1.0 - 33.5) <DC94CF9E-1EB4-3C0E-B298-CA1190885276> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff4a0ff000 - 0x7fff4a106ff7 com.apple.LinguisticData (1.0 - 238.3) <49A54649-1021-3DBD-99B8-1B2EDFFA5378> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff4a247000 - 0x7fff4a264ff7 com.apple.LookupFramework (1.2 - 239.1) <16BC898F-B41A-3435-87B7-456151F0A933> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup
0x7fff4a905000 - 0x7fff4a908fff com.apple.Mangrove (1.0 - 1) <27D6DF76-B5F8-3443-8826-D25B284331BF> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff4a994000 - 0x7fff4a996ff7 com.apple.marco (10.0 - 1000) <F09F17FA-D420-3C24-8C47-8DC1637453BA> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fff4aa24000 - 0x7fff4aa57ff7 com.apple.MediaKit (16 - 873) <EC6E742E-305D-362F-9E22-BF313013054C> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff4ae18000 - 0x7fff4ae81ff7 com.apple.gpusw.MetalTools (1.0 - 1) <458F319A-2707-3C83-8351-BD9F02EC05BD> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff4ae8a000 - 0x7fff4aea1ff7 com.apple.MobileAssets (1.0 - 437.60.1) <5FFD8A8B-F33F-3FA9-8F50-31C24A67862C> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff4aea5000 - 0x7fff4b000fdf com.apple.mobiledevice (988.70.1.100.34 - 988.70.1.100.34) <5D9B7AC8-4B6C-3CBF-BCB1-558D2B754C21> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x7fff4b001000 - 0x7fff4b01afff com.apple.MobileKeyBag (2.0 - 1.0) <32E63C7B-E133-33DE-A593-C3C10D64FCAA> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff4b0a6000 - 0x7fff4b0d0ffb com.apple.MultitouchSupport.framework (1404.4 - 1404.4) <45374A2A-C0BC-3A70-8183-37295205CDFA> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff4b337000 - 0x7fff4b342fff com.apple.NetAuth (6.2 - 6.2) <B3795F63-C14A-33E1-9EE6-02A2E7661321> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff4b34f000 - 0x7fff4b43bff3 com.apple.Network (1.0 - 1) <216E7165-A2C5-3846-986E-8015ED9C5B8F> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
0x7fff4cbd8000 - 0x7fff4cbe8ffb com.apple.PerformanceAnalysis (1.194 - 194) <2844933E-B71C-3BE9-9A84-27B29E111F13> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff4cc60000 - 0x7fff4cc60ff7 com.apple.PhoneNumbers (1.0 - 1) <EB82645C-AF19-3751-8A53-F6148F77EC38> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff4e94f000 - 0x7fff4e9a6fff com.apple.ProtectedCloudStorage (1.0 - 1) <99598601-64DB-3A82-A13B-B62641709213> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff4e9a7000 - 0x7fff4e9c5fff com.apple.ProtocolBuffer (1 - 260) <40704740-4A53-3010-A49B-08D1D69D1D5E> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff4eb32000 - 0x7fff4eb48ff7 com.apple.QuickLookThumbnailing (1.0 - 1) <8F0092E4-6494-349D-B4C9-494DF293D716> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff4eb8f000 - 0x7fff4eb9bfff com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.70.9) <2937CFBF-587C-33A0-B493-FFB4E606A498> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff4eb9c000 - 0x7fff4ebbfffb com.apple.RemoteViewServices (2.0 - 125) <592323D1-CB44-35F1-9921-4C2AB8D920A0> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff4ebc0000 - 0x7fff4ebd5ff3 com.apple.xpc.RemoteXPC (1.0 - 1205.70.9) <C3DB7D30-903A-306C-9DFA-1669D2B60497> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff504de000 - 0x7fff505f3ff7 com.apple.Sharing (1050.22.2 - 1050.22.2) <4E3CCDF2-EA26-334F-8EBA-79BD28486C9D> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff505f4000 - 0x7fff50613ff7 com.apple.shortcut (2.16 - 99) <201F92AE-F8E6-3A24-B9DE-26B88CD2EF18> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff5061e000 - 0x7fff5061fff7 com.apple.performance.SignpostNotification (1.2.6 - 2.6) <8F04800F-3570-3392-A24D-B229FF03F7F9> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff51367000 - 0x7fff51603ff7 com.apple.SkyLight (1.600.0 - 312.103) <27F91170-846C-3E9E-9B8A-788F27C7DAF5> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff51dcc000 - 0x7fff51dd9fff com.apple.SpeechRecognitionCore (4.6.1 - 4.6.1) <87EE7AB5-6925-3D21-BE00-F155CB457699> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff51e8b000 - 0x7fff520c9ff3 com.apple.spotlight.index (10.7.0 - 1191.4.13) <14C6EDFD-B843-35A4-AEA6-F485D756FF88> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff52286000 - 0x7fff522adfff com.apple.StreamingZip (1.0 - 1) <32F550C9-3DF8-3DF9-A1EC-699C3D32621B> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff5297f000 - 0x7fff52a08fc7 com.apple.Symbolication (9.3 - 64033) <C2C55C9A-C264-3044-A953-16457148190A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff52a19000 - 0x7fff52a21ffb com.apple.SymptomDiagnosticReporter (1.0 - 820.60.2) <66326935-2A3F-3482-B75F-AEB4CBA08DCF> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff52f79000 - 0x7fff52f81ff7 com.apple.TCC (1.0 - 1) <E1EB7272-FE6F-39AB-83CA-B2B5F2A88D9B> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff5318e000 - 0x7fff5324bff7 com.apple.TextureIO (3.7 - 3.7) <F8BAC954-405D-3CC3-AB7B-048C866EF980> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff53273000 - 0x7fff532a1ff7 com.apple.TimeSync (1.0 - 680.15) <B2B63157-5E6A-31F0-9049-543BB208B65D> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x7fff532a2000 - 0x7fff532bdffb com.apple.ToneKit (1.0 - 1) <030D229F-084B-3852-9EF8-1A608A5C9B50> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff532be000 - 0x7fff532e5fff com.apple.ToneLibrary (1.0 - 1) <40669A87-2E48-3A42-8310-34046580C684> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff532f5000 - 0x7fff532f6fff com.apple.TrustEvaluationAgent (2.0 - 31) <39F533B2-211E-3635-AF47-23F27749FF4A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff532fc000 - 0x7fff534abfff com.apple.UIFoundation (1.0 - 547.5) <86A2FBA7-2709-3894-A3D5-A00C19BAC48D> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff54180000 - 0x7fff5424fff7 com.apple.ViewBridge (343.2 - 343.2) <5519FCED-1F88-3BE6-9BE1-69992086B01B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff54975000 - 0x7fff549d5fff com.apple.xquery (1.3.1 - 30) <A335A70D-3859-3EAD-B85B-AF65B3A5A66E> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
0x7fff54bb4000 - 0x7fff54bb6ffb com.apple.loginsupport (1.0 - 1) <D1232C1B-80EA-3DF8-9466-013695D0846E> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff54bb7000 - 0x7fff54bccfff com.apple.login (3.0 - 3.0) <79189BF9-70D4-3839-9E2F-B3990B673A3E> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff54bf7000 - 0x7fff54c24fff com.apple.contacts.vCard (1.0 - 2330.3) <02AB9DF0-0471-3FDA-8EC6-27C72E00DD75> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff54d1d000 - 0x7fff54d50ff7 libclosured.dylib (551.4) <3FB6B209-51F4-38DA-B1D8-2EE29D5BDD83> /usr/lib/closure/libclosured.dylib
0x7fff54e0a000 - 0x7fff54e43ff7 libCRFSuite.dylib (41) <FE5EDB68-2593-3C2E-BBAF-1C52D206F296> /usr/lib/libCRFSuite.dylib
0x7fff54e44000 - 0x7fff54e4ffff libChineseTokenizer.dylib (28) <53633C9B-A3A8-36F7-A53C-432D802F4BB8> /usr/lib/libChineseTokenizer.dylib
0x7fff54e50000 - 0x7fff54eddff7 libCoreStorage.dylib (546.50.1) <6AFD6AAE-2EFE-3CF3-90C6-A66F67FCB309> /usr/lib/libCoreStorage.dylib
0x7fff54ee1000 - 0x7fff54ee2ff3 libDiagnosticMessagesClient.dylib (104) <9712E980-76EE-3A89-AEA6-DF4BAF5C0574> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff54f19000 - 0x7fff550e3ff3 libFosl_dynamic.dylib (17.8) <C58ED77A-4986-31C2-994C-34DDFB8106F0> /usr/lib/libFosl_dynamic.dylib
0x7fff5511b000 - 0x7fff5511bfff libOpenScriptingUtil.dylib (174) <610F0242-7CE5-3C86-951B-B646562694AF> /usr/lib/libOpenScriptingUtil.dylib
0x7fff55252000 - 0x7fff55256ffb libScreenReader.dylib (562.18.4) <E239923D-54C9-3BBF-852F-87C09DEF4091> /usr/lib/libScreenReader.dylib
0x7fff55257000 - 0x7fff55258ffb libSystem.B.dylib (1252.50.4) <CD555F3B-FDDB-35E5-A2FB-FBBF3D62031A> /usr/lib/libSystem.B.dylib
0x7fff552d7000 - 0x7fff552d8fff libThaiTokenizer.dylib (2.2) <6F416F41-BF77-3078-A05C-AFF5DA5AB008> /usr/lib/libThaiTokenizer.dylib
0x7fff552eb000 - 0x7fff552ebfff libapple_crypto.dylib (109.50.14) <48BA2E76-BF2F-3522-A54E-D7FB7EAF7A57> /usr/lib/libapple_crypto.dylib
0x7fff552ec000 - 0x7fff55302ff7 libapple_nghttp2.dylib (1.24) <01402BC4-4822-3676-9C80-50D83F816424> /usr/lib/libapple_nghttp2.dylib
0x7fff55303000 - 0x7fff5532dff3 libarchive.2.dylib (54) <8FC28DD8-E315-3C3E-95FE-D1D2CBE49888> /usr/lib/libarchive.2.dylib
0x7fff5532e000 - 0x7fff553affdf libate.dylib (1.13.1) <178ACDAD-DE7E-346C-A613-1CBF7929AC07> /usr/lib/libate.dylib
0x7fff553b3000 - 0x7fff553b3ff3 libauto.dylib (187) <A05C7900-F8C7-3E75-8D3F-909B40C19717> /usr/lib/libauto.dylib
0x7fff553b4000 - 0x7fff5546cff3 libboringssl.dylib (109.50.14) <E6813F87-B5E4-3F7F-A725-E6A7F2BD02EC> /usr/lib/libboringssl.dylib
0x7fff5546d000 - 0x7fff5547dff3 libbsm.0.dylib (39) <6BC96A72-AFBE-34FD-91B1-748A530D8AE6> /usr/lib/libbsm.0.dylib
0x7fff5547e000 - 0x7fff5548bffb libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
0x7fff5548c000 - 0x7fff554e2fff libc++.1.dylib (400.9) <7D3DACCC-3804-393C-ABC1-1A580FD00CB6> /usr/lib/libc++.1.dylib
0x7fff554e3000 - 0x7fff55507ff7 libc++abi.dylib (400.8.2) <EF5E37D7-11D9-3530-BE45-B986612D13E2> /usr/lib/libc++abi.dylib
0x7fff55509000 - 0x7fff55519fff libcmph.dylib (6) <A5509EE8-7E00-3224-8814-015B077A3CF5> /usr/lib/libcmph.dylib
0x7fff5551a000 - 0x7fff55531fcf libcompression.dylib (47.60.2) <543F07BF-2F2F-37D5-9866-E84BF659885B> /usr/lib/libcompression.dylib
0x7fff557dc000 - 0x7fff557f4ff7 libcoretls.dylib (155.50.1) <D350052E-DC4D-3185-ADBA-BA48EDCEE955> /usr/lib/libcoretls.dylib
0x7fff557f5000 - 0x7fff557f6ff3 libcoretls_cfhelpers.dylib (155.50.1) <B297F5D8-F2FE-3566-A752-E9D998B9C039> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff558ac000 - 0x7fff5598eff3 libcrypto.0.9.8.dylib (76.30.1) <D47BDA97-AF5D-39A5-9F54-8244C4B6A993> /usr/lib/libcrypto.0.9.8.dylib
0x7fff5598f000 - 0x7fff55b20fff libcrypto.35.dylib (22.50.2) <97828BFD-4675-35DF-BE2E-C6D1555BB71D> /usr/lib/libcrypto.35.dylib
0x7fff55cbb000 - 0x7fff55cc6ff7 libcsfde.dylib (546.50.1) <D02562A4-CCE6-35FE-8BDE-05BB68DA0038> /usr/lib/libcsfde.dylib
0x7fff55cc7000 - 0x7fff55d1dff3 libcups.2.dylib (462.2.4) <908099FB-C70E-38FA-9573-88CB98FDDE29> /usr/lib/libcups.2.dylib
0x7fff55d48000 - 0x7fff55d9cffb libcurl.4.dylib (105.40.1) <B04E7791-EAF9-3D72-B4ED-DD8F135140EC> /usr/lib/libcurl.4.dylib
0x7fff55e5d000 - 0x7fff55e5dfff libenergytrace.dylib (16) <A92AB8B8-B986-3CE6-980D-D55090FEF387> /usr/lib/libenergytrace.dylib
0x7fff55e5e000 - 0x7fff55e77ffb libexpat.1.dylib (16.1.1) <5E1796FA-4041-3187-B5C2-8E6B03D1D72A> /usr/lib/libexpat.1.dylib
0x7fff55e85000 - 0x7fff55e86fff libffi.dylib (18.1) <02011073-8CB7-362F-BC52-43B4E83687B0> /usr/lib/libffi.dylib
0x7fff55e8f000 - 0x7fff55e93ff7 libgermantok.dylib (17) <37C1C061-5214-3050-9C3A-783A784435A8> /usr/lib/libgermantok.dylib
0x7fff55e94000 - 0x7fff55e99ff3 libheimdal-asn1.dylib (520.50.6) <E358445A-B84E-31B5-BCCD-7E1397519D96> /usr/lib/libheimdal-asn1.dylib
0x7fff55ec5000 - 0x7fff55fb6ff7 libiconv.2.dylib (51.50.1) <2FEC9707-3FAF-3828-A50D-8605086D060F> /usr/lib/libiconv.2.dylib
0x7fff55fb7000 - 0x7fff561deffb libicucore.A.dylib (59180.0.1) <34EBADD6-4092-30EC-90E8-F75241E94D76> /usr/lib/libicucore.A.dylib
0x7fff5622b000 - 0x7fff5622cfff liblangid.dylib (128) <39C39393-0D05-301D-93B2-F224FC4949AA> /usr/lib/liblangid.dylib
0x7fff5622d000 - 0x7fff56246ffb liblzma.5.dylib (10) <3D419A50-961F-37D2-8A01-3DC7AB7B8D18> /usr/lib/liblzma.5.dylib
0x7fff56247000 - 0x7fff5625dff7 libmarisa.dylib (9) <D6D2D55D-1D2E-3442-B152-B18803C0ABB4> /usr/lib/libmarisa.dylib
0x7fff5625e000 - 0x7fff5630dfff libmecab.1.0.0.dylib (779.7.6) <334D4742-BDDD-3C2D-BBEB-85B32643BFA0> /usr/lib/libmecab.1.0.0.dylib
0x7fff5630e000 - 0x7fff56536ff7 libmecabra.dylib (779.7.6) <F462F170-E872-3D09-B219-973D5E99C09F> /usr/lib/libmecabra.dylib
0x7fff5670e000 - 0x7fff56889fff libnetwork.dylib (1229.70.2) <E185D902-AC7F-3044-87C0-AE2887C59CE7> /usr/lib/libnetwork.dylib
0x7fff56910000 - 0x7fff56cfe7e7 libobjc.A.dylib (723) <DD9E5EC5-B507-3249-B700-93433E2D5EDF> /usr/lib/libobjc.A.dylib
0x7fff56d11000 - 0x7fff56d15fff libpam.2.dylib (22) <7B4D2CE2-1438-387A-9802-5CEEFBF26F86> /usr/lib/libpam.2.dylib
0x7fff56d18000 - 0x7fff56d4cfff libpcap.A.dylib (79.20.1) <FA13918B-A247-3181-B256-9B852C7BA316> /usr/lib/libpcap.A.dylib
0x7fff56d4d000 - 0x7fff56d8afff libpcre.0.dylib (9) <435CC540-20A7-3324-B757-E7209FE84303> /usr/lib/libpcre.0.dylib
0x7fff56dcb000 - 0x7fff56de7ffb libresolv.9.dylib (65) <E8F3415B-4472-3202-8901-41FD87981DB2> /usr/lib/libresolv.9.dylib
0x7fff56e23000 - 0x7fff56e35fff libsasl2.2.dylib (211) <04EF3F61-12EC-3319-A649-851999F4C7A4> /usr/lib/libsasl2.2.dylib
0x7fff56e36000 - 0x7fff56e37ff3 libspindump.dylib (252) <D8E27057-E3CC-3D7F-A010-4A87830F6A83> /usr/lib/libspindump.dylib
0x7fff56e38000 - 0x7fff56fcbff7 libsqlite3.dylib (274.8.1) <FCAD6A57-829E-3701-B16E-1833D620E0E8> /usr/lib/libsqlite3.dylib
0x7fff56fee000 - 0x7fff57026ff3 libssl.0.9.8.dylib (76.30.1) <31E4862C-C181-3D5E-ACB3-CDE18764638F> /usr/lib/libssl.0.9.8.dylib
0x7fff57027000 - 0x7fff5707affb libssl.35.dylib (22.50.2) <AF523E9B-7183-3A87-8FB4-E26936EC4FDB> /usr/lib/libssl.35.dylib
0x7fff570cd000 - 0x7fff5711bfff libstdc++.6.0.9.dylib (104.1) <0EA35E7E-B536-3628-B462-A4098805CEAC> /usr/lib/libstdc++.6.0.9.dylib
0x7fff57123000 - 0x7fff57134fff libsystemstats.dylib (403.50.9) <334C2341-886C-3B3C-912D-E48F542E7415> /usr/lib/libsystemstats.dylib
0x7fff57152000 - 0x7fff57187fff libtidy.A.dylib (15.18.1) <D1FF31AF-3000-366D-8714-09B2330007B5> /usr/lib/libtidy.A.dylib
0x7fff5719f000 - 0x7fff571ffff3 libusrtcp.dylib (1229.70.2) <1E065228-D0E3-3808-9405-894056C6BEC0> /usr/lib/libusrtcp.dylib
0x7fff57200000 - 0x7fff57203ffb libutil.dylib (51.20.1) <216D18E5-0BAF-3EAF-A38E-F6AC37CBABD9> /usr/lib/libutil.dylib
0x7fff57204000 - 0x7fff57211fff libxar.1.dylib (400) <0316128D-3B47-3052-995D-97B4FE5491DC> /usr/lib/libxar.1.dylib
0x7fff57215000 - 0x7fff572fcfff libxml2.2.dylib (31.11) <C2B5C43F-9C0B-31E6-8EC0-939591EDAC49> /usr/lib/libxml2.2.dylib
0x7fff572fd000 - 0x7fff57325fff libxslt.1.dylib (15.12) <4A5E011D-8B29-3135-A52B-9A9070ABD752> /usr/lib/libxslt.1.dylib
0x7fff57326000 - 0x7fff57338ffb libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
0x7fff573d4000 - 0x7fff573d8ff7 libcache.dylib (80) <092479CB-1008-3A83-BECF-E115F24D13C1> /usr/lib/system/libcache.dylib
0x7fff573d9000 - 0x7fff573e3ff3 libcommonCrypto.dylib (60118.50.1) <029F5985-9B6E-3DCB-9B96-FD007678C6A7> /usr/lib/system/libcommonCrypto.dylib
0x7fff573e4000 - 0x7fff573ebfff libcompiler_rt.dylib (62) <968B8E3F-3681-3230-9D78-BB8732024F6E> /usr/lib/system/libcompiler_rt.dylib
0x7fff573ec000 - 0x7fff573f5ffb libcopyfile.dylib (146.50.5) <3885083D-50D8-3EEC-B481-B2E605180D7F> /usr/lib/system/libcopyfile.dylib
0x7fff573f6000 - 0x7fff5747bfff libcorecrypto.dylib (562.70.1) <5C26364F-2269-31EC-84AF-0FED2C902E38> /usr/lib/system/libcorecrypto.dylib
0x7fff57503000 - 0x7fff5753cff7 libdispatch.dylib (913.60.2) <232C69BD-022E-3AB9-8807-79F9FA7CB5EC> /usr/lib/system/libdispatch.dylib
0x7fff5753d000 - 0x7fff5755aff7 libdyld.dylib (551.4) <81BF3A82-5719-3B54-ABA9-76C82D932CAC> /usr/lib/system/libdyld.dylib
0x7fff5755b000 - 0x7fff5755bffb libkeymgr.dylib (28) <E34E283E-90FA-3C59-B48E-1277CDB9CDCE> /usr/lib/system/libkeymgr.dylib
0x7fff5755c000 - 0x7fff57568ff3 libkxld.dylib (4570.71.2) <C3C31E1B-3E74-3828-8429-4D442E26D41C> /usr/lib/system/libkxld.dylib
0x7fff57569000 - 0x7fff57569ff7 liblaunch.dylib (1205.70.9) <B184B521-FF24-3142-AFAF-23D170CF918C> /usr/lib/system/liblaunch.dylib
0x7fff5756a000 - 0x7fff5756effb libmacho.dylib (906) <1902A611-081A-3452-B11E-EBD1B166E831> /usr/lib/system/libmacho.dylib
0x7fff5756f000 - 0x7fff57571ff3 libquarantine.dylib (86) <26C0BA22-8F93-3A07-9A4E-C8D53D2CE42E> /usr/lib/system/libquarantine.dylib
0x7fff57572000 - 0x7fff57573ff3 libremovefile.dylib (45) <711E18B2-5BBE-3211-A916-56740C27D17A> /usr/lib/system/libremovefile.dylib
0x7fff57574000 - 0x7fff5758bfff libsystem_asl.dylib (356.70.1) <39E46A6F-B228-3E78-B83E-1779F9707A39> /usr/lib/system/libsystem_asl.dylib
0x7fff5758c000 - 0x7fff5758cfff libsystem_blocks.dylib (67) <17303FDF-0D2D-3963-B05E-B4DF63052D47> /usr/lib/system/libsystem_blocks.dylib
0x7fff5758d000 - 0x7fff57616ff7 libsystem_c.dylib (1244.50.9) <1187BFE8-4576-3247-8177-481554E1F9E7> /usr/lib/system/libsystem_c.dylib
0x7fff57617000 - 0x7fff5761affb libsystem_configuration.dylib (963.50.8) <DF6B5287-203E-30CB-9947-78DF446C72B8> /usr/lib/system/libsystem_configuration.dylib
0x7fff5761b000 - 0x7fff5761effb libsystem_coreservices.dylib (51) <486000D3-D8CB-3BE7-8EE5-8BF380DE6DF7> /usr/lib/system/libsystem_coreservices.dylib
0x7fff5761f000 - 0x7fff57620fff libsystem_darwin.dylib (1244.50.9) <09C21A4A-9EE0-388B-A9D9-DFF8F6758791> /usr/lib/system/libsystem_darwin.dylib
0x7fff57621000 - 0x7fff57627ff7 libsystem_dnssd.dylib (878.70.2) <3290768B-54DE-3AB6-B155-AC0950AC5564> /usr/lib/system/libsystem_dnssd.dylib
0x7fff57628000 - 0x7fff57671ff7 libsystem_info.dylib (517.30.1) <AB634A98-B8AA-3804-8436-38261FC8EC4D> /usr/lib/system/libsystem_info.dylib
0x7fff57672000 - 0x7fff57698ff7 libsystem_kernel.dylib (4570.71.2) <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2> /usr/lib/system/libsystem_kernel.dylib
0x7fff57699000 - 0x7fff576e4fcb libsystem_m.dylib (3147.50.1) <8CFB51C9-B422-3379-8552-064C63943A23> /usr/lib/system/libsystem_m.dylib
0x7fff576e5000 - 0x7fff57704fff libsystem_malloc.dylib (140.50.6) <7FD43735-9DDD-300E-8C4A-F909A74BDF49> /usr/lib/system/libsystem_malloc.dylib
0x7fff57705000 - 0x7fff57835ff7 libsystem_network.dylib (1229.70.2) <5E86B2DE-9E15-3354-8714-4094ED5F698D> /usr/lib/system/libsystem_network.dylib
0x7fff57836000 - 0x7fff57840ffb libsystem_networkextension.dylib (767.70.1) <D23EAFC1-E8BD-34D5-969C-6E45A1C3B4E4> /usr/lib/system/libsystem_networkextension.dylib
0x7fff57841000 - 0x7fff5784aff3 libsystem_notify.dylib (172) <08012EC0-2CD2-34BE-BF93-E7F56491299A> /usr/lib/system/libsystem_notify.dylib
0x7fff5784b000 - 0x7fff57852ff7 libsystem_platform.dylib (161.50.1) <6355EE2D-5456-3CA8-A227-B96E8F1E2AF8> /usr/lib/system/libsystem_platform.dylib
0x7fff57853000 - 0x7fff5785efff libsystem_pthread.dylib (301.50.1) <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4> /usr/lib/system/libsystem_pthread.dylib
0x7fff5785f000 - 0x7fff57862fff libsystem_sandbox.dylib (765.70.1) <553DFCC6-9D31-3B9C-AB7C-30F6F265786D> /usr/lib/system/libsystem_sandbox.dylib
0x7fff57863000 - 0x7fff57864ff3 libsystem_secinit.dylib (30) <DE8D14E8-A276-3FF8-AE13-77F7040F33C1> /usr/lib/system/libsystem_secinit.dylib
0x7fff57865000 - 0x7fff5786cff7 libsystem_symptoms.dylib (820.60.2) <585BDFA2-D54D-39D0-8046-44E824DABD43> /usr/lib/system/libsystem_symptoms.dylib
0x7fff5786d000 - 0x7fff57880fff libsystem_trace.dylib (829.70.1) <3A6CB706-8CA6-3616-8AFC-14AAD7FAF187> /usr/lib/system/libsystem_trace.dylib
0x7fff57882000 - 0x7fff57887ff7 libunwind.dylib (35.3) <BEF3FB49-5604-3B5F-82B5-332B80023AC3> /usr/lib/system/libunwind.dylib
0x7fff57888000 - 0x7fff578b5ff7 libxpc.dylib (1205.70.9) <0BC7AD67-671D-31D4-8B88-C317B8379598> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 15
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 133507
thread_create: 0
thread_set_state: 0
Model: MacBookPro11,2, BootROM MBP112.0146.B00, 4 processors, Intel Core i7, 2,2 GHz, 16 GB, SMC 2.18f15
Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.37.31.1a9)
Bluetooth: Version 6.0.7f10, 3 services, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0256F, 251 GB
USB Device: USB 3.0 Bus
USB Device: Porsche Mobile
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Receiver
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
