mano.coolguy wrote:
> Hi,
> I am adding seurity(authentication) elements to SOAp
Header using
> addSOAPRequestHeader() function. I am passing the
mustUnderstand value as true.
> The generated output is as follows
> <?xml version="1.0" encoding="UTF-8"?>
> <soapenv:Envelope xmlns:soapenv="
http://schemas.xmlsoap.org/soap/envelope/"
> xmlns:xsd="
http://www.w3.org/2001/XMLSchema"
> xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance">
> <soapenv:Header>
> <wsse:Security soapenv:actor=""
soapenv:mustUnderstand="1"
> xmlns:wsse="
http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-s
> ecext-1.0.xsd">
> I am not adding any soapenv:actor attribte anywhere in
my code. But this
> attribute is created with a blank value. My web service
request is failing for
> this reason. I am getting fault exception from AXIS
Server.
> I need to remove this attribute to make it work. Does
anybody know how I can
> do this?
I had this problem when trying to access a .net web service.
I ended up
creating the soap request XML manually.
Mack
