12 Replies Latest reply on Aug 9, 2018 5:50 AM by toxictool
    Simple Link Path Find/Replace Script
    toxictool Level 1
      I'm looking for assistance with creating a simple Applescript that will parse through all linked files in an InDesign document and find/replace a portion of the link's path.
      Background
      The volume name at our office is changing slightly and that will break ALL our links within InDesign. The change is so minimal but it's at the root level, IT is removing a space in our server volume name.
      Example
      Current Link: /Volumes/Our Server/Client/Division/ProjectFolder/Links/image.psd
      Future Link: /Volumes/OurServer/Client/Division/ProjectFolder/Links/image.psd
      Literally it's just removing a space for the volume name. There has to be an easy way to scrub through all link paths via script, finding "Our Server" and replace with "OurServer" in link path data. All done right from within the document, not the convoluted way of saving IMDL, fixing and then opening the IMDL file and saving a new document.
      I've searched this forum but the scripts are pretty complex and doesn't fit this need exactly.
        • 1. Re: Simple Link Path Find/Replace Script
          S Hopkins Adobe Community Professional
          With a document open, the following has the user choose the new folder where a duplicate of the original linked files will be placed. Then it updates the link information for the image using the duplicated file. It's not bullet proof--I'll leave that up to you. You could have Finder move the file, but I think this is safer. In place of using choose folder, you can set the newFolderPath to a path to the new folder structure.
          set folderRef to choose folder
          set newFolderPath to folderRef as string
          tell application "Adobe InDesign CC 2018"
            tell document 1
            set linkList to item link of every image of every spline item
            repeat with i from length of linkList to 1 by -1
            set linkRef to item i of linkList
            set origFilePath to file path of linkRef
            set fileName to name of linkRef
            my copyFile(origFilePath, newFolderPath)
            set newFilePath to newFolderPath & fileName
            if exists (file newFilePath) then
            relink linkRef to file newFilePath
            end if
            end repeat
            end tell
          end tell
          on copyFile(origFilePath, newFolderPath)
            tell application "Finder"
            duplicate file origFilePath to newFolderPath
            end tell
          end copyFile
          • 2. Re: Simple Link Path Find/Replace Script
            toxictool Level 1
            Interesting approach and thank you much for the quick response. It's not 100% what I'm looking for but I will experiment and attempt to modify the script you provided.
            Best example, if I didn't explain it correctly is, let's say you had an external drive with thousands of InDesign documents and images. Everything was pointing and linking to the assets on this drive. All is working perfectly however you had to change the name of the external hard drive! Now EVERY link is broken because the link path is different due to only the name change of the external drive. The pathing within that drive are identical, just the name of the volume changed. So, what I was asking for was a simple script that reads/modifies the link paths when the file is open.
            The process would go something like:
            1. Open InDesign File
            2. Run InDesign script to repair link paths
            3. Artist preforms any changes/modifications needed
            4. Command S (save file)
            5. Close InDesign File
            Nothing really changes from the typical procedure but the run script to repair the link paths.
            • 3. Re: Simple Link Path Find/Replace Script
              BarlaeDC Adobe Community Professional
              Assuming the structure does not change under the main volume name, you should be able to do the following.
              Current Folder structure: (example)
              Current Doc: /Volumes/Our Server/Client/Division/ProjectFolder/Document.indd
              Future Folder Structure:
              Future Doc: /Volumes/OurServer/Client/Division/ProjectFolder/Document.indd
              If you are using indesign CC/2015/2017/2018 and you have these settings checked
              InDesign->Preferences->File Handling
              In the Links panel
              Make sure
              - Check Links Before Opening Document
              - Find Missing Links Before Opening Document
              Are both checked.
              Then just open and save the file, which you can do by script or the next time the document is opened.
              The settings above search using a relative path from the document, so as long as the files are in the same relative position they should be found.
              Hope this helps
              Malcolm
              • 5. Re: Simple Link Path Find/Replace Script
                toxictool Level 1
                I've taken a stab at modifying an Applescript I found in the forums but I'm hitting a snag during the "relink" process. Maybe this will make more sense from a code perspective. There is NO interaction with the end user, this is what I want. Simply open document with broken links, double click script, links are repaired to new server name, done. No pop-ups, no save file, no interaction other than maybe a dialog at end of script saying "Links Repaired!".
                tell document 1
                     set linkList to links
                     set errInfo to "" -- Displays error if it can't relink an item
                     repeat with x in linkList
                if (x's status) is not normal then -- Checks for broken links only
                     set linkPath to (x's file path) as string
                if "Volumes:Our Server" is in linkPath then
                     set AppleScript's text item delimiters to "Volumes:Our Server"
                     set linkPath to (linkPath's text items) -- Create a list of text items
                     set AppleScript's text item delimiters to "Volumes:OurServer"
                     set linkPath to (linkPath as string) -- Concatenate with new path
                     set AppleScript's text item delimiters to "" -- Reset TIDs
                     -- I used display dialog to view path at this point. The path is correct with new server location but fails on relink in next step
                     -- display dialog linkPath
                try
                     relink x to linkPath
                try
                     update x -- This can be helpful
                     end try
                on error err
                     set errInfo to (errInfo & return & x's name)
                end try
                end if
                end if
                end repeat
                  -- Displays error
                if (count errInfo) > 0 then display dialog ("Can't relink:" & errInfo)
                end tell
                end tell
                • 6. Re: Simple Link Path Find/Replace Script
                  toxictool Level 1
                  I have both of these checked but it still doesn't find the links from a server with a space removed from it. Something so simple but still doesn't repair.
                  • 7. Re: Simple Link Path Find/Replace Script
                    Kevin Parrott Level 2
                    is this any closer?
                        tell document 1
                                    display dialog 1
                                    set tString to "Volumes:Our Server" as string
                                    if tString contains "Volumes:Our Server" then
                                        try
                                            relink x to linkPath as alias -- added as alais
                                            try
                                            end try
                                        on error err
                                        end try
                                    end if
                                end if
                            end repeat
                            -- Displays error
                        end tell
                    end tell
                    cheers
                    Kev
                    1 person found this helpful
                    • 8. Re: Simple Link Path Find/Replace Script
                      Just created a new share with a space, and yip, it doesn't work, works if you don't change the space, but removing the space or adding one causes it to fail.
                      Think that needs to be logged as a bug.
                      Regards
                      Malcolm
                      • 9. Re: Simple Link Path Find/Replace Script
                        toxictool Level 1
                        YES, YES, YES! Thank you Kevin! Your modification did the trick!
                        While this script does what I asked, I get a relink error if the server "OurServer" is not mounted. The link path does not update. Is there anyway to force the path change to the new server name even if the server isn't available?
                        • 10. Re: Simple Link Path Find/Replace Script
                          would checking in advance to see if "OurServer" is mounted and if not then mount it?
                          • 11. Re: Simple Link Path Find/Replace Script
                            Laubender Adobe Community Professional & MVP
                            Hi toxictool ,
                            not directly I think.
                            You could do the trick by exporting the frame to IDMS, editing the link in the IDMS, placing the IDMS and removing the frame holding the original.
                            Uwe
                            • 12. Re: Simple Link Path Find/Replace Script
                              toxictool Level 1
                              Might not be a bad idea as a fail safe. But then again, the users are on the server getting the documents so it should be mounted. I guess the check would be helpful if the documents that needed to updated were on a local machine where there was no reliance on the server.
                              It's too bad that InDesign doesn't allow the change/saving of the path change via script without requiring a "relink". The relink is failing when the server isn't mounted.
                              Thank you Kevin for your assistance!
                              By the way BarlaeDC, I did a few more tests and in some situations the Auto link update after server name change worked! So thank you for mentioning that to me.
                              Between the auto link repair built into InDesign and the repair link script, I think we're good! Thank you everyone for your assistance! Much appreciated!
