Hihi
I understand that DDX can watermark PDF documents using a
string of static text but i am searching for a solution to
implement dynamic watermarking on an existing PDF. Any idea how to
approach this? beside using iTEXT?
meowo wrote:
> Hihi
a string of static
> text but i am searching for a solution to implement
> existing PDF.
a string of static text ...
> i am searching for a solution to implement dynamic
watermarking
Yes, the question is not clear to me either. You can generate
DDX dynamically, so by extension the text can be dynamic. Is that
what you are asking?
sorry that my question is not clear.
ok i have this ddx and cfm file, my question is how can
watermark the downloader name dynamically on the generated pdf? How
do i pass a variable from cfm to ddx in my case?
The "ddxFile" value does not have to be a physical file. It
can also be a variable containing a ddx string. You can use
cfsavecontent to construct your ddx string. Using whatever
variables you need. Then pass that variable to cfpdf:
