When I try to "Quick Export as PNG" nothing happens, and when I try to "Export As" it times-out trying to load the dialog box. This happens more often for me with bigger files. Is there a file size limit where these functions stop working?
My workaround is Save for Web (legacy) which always works, but is a slower workflow.
Hi Nenomamacita,
We're sorry to hear about the "Quick Export as PNG" not working, could you please let us know which exact version of Photoshop you're working on? (You can find that out by going to Help > System Info).
Also, which operating system you're using?
Sahil
Hi Sahil,
I'm on Adobe Photoshop Version: 19.1.2 20180302.r.277 2018/03/02: 1160083 x64
OS 10.13.3
Thanks for providing the information, could you please try updating Photoshop to version 19.1.3 via the Creative Cloud app and see if it helps?
If you do not see the update then please try signing out and signing back into the Creative Cloud app and click on the 3 dots on the top right corner and choose "Check for updates".
I am having the exact same problem in ver 19.1.3 as of today, 5/14/2018.
2017 MBP OS10.13.4
I'm having the same problem right now. So I installed the CC updates to get new version 19.1.4, and it is still happening after the update.
When I click on Export>Quick Export as PNG, nothing happens.
Update: So I restarted Photoshop and it started working again, but after editing some text, it stopped working again.
Hi, I'm having the same issue today with files of all sizes. Using:
Adobe Photoshop Version: 19.1.4 20180507.r.325 2018/05/07: 1170750 x64
quick export not opening at all and export as timing out.
Hello, could all affected users try to pinpoint when the issue arises? large files, after editing text, as jacombs states it? are you on mac or Pc, etc?
Hi, I don't seem to have any particular cause? It's working again for the moment but I haven't done anything to troubleshoot except for open and close the program several times. This doesn't reliably work either as it took maybe 3 restarts before it started working (without editing anything in program at all, just opening a saved file and trying to export).
I'm using a mac, OS High Sierra 10.13.4
In terms of anything in program that might be causing this, no text editing for me, just move tools, paint bucket, brush and eraser, and the files are no bigger than 5MB.
I just updated Photoshop from the Adobe site. I am using a very small file. Windows 10 on a PC. Nothing happens when I use quick export. No dialogue box appears when I try Export As.
What helped for me was to disable the Creative Cloud syncing from the Creative Cloud app (it might not be running, but the setting still influences Photoshop behaviour).
From YouTube, I learned that you need to enable a plug-in. Go to Edit / Preferences / Plug-Ins. Check "Load Extension Panels." Uncheck "Allow Extensions to Connect to the Internet."
I'm using a totally different computer and creative cloud account and I'm still having the same issue.
Changing the plug-ins preferences doesn't work. Has anyone else found any fixes for this?
I'm having this issue, too. I've been having it intermittently ever since I started using CC about two years ago, but now it's constant. Even after a reboot, Quick Export only works once or twice before it stops working entirely. This is maddening and it's completely screwing up my workflow. I'm using the most current version of CC available.
Erin and neon, could you please copy-paste the version of Photoshop you have from help-system info?
You might think you have the last version, and it might not be the case...
Also, what kind of files are the input (number of layers, size, etc.) and which export setting is selected?
Same problem.
The Quick Export to PNG stops working.
Have had the problem for at least a year.
I have a feeling that it happens if I'm quick to select it right after an ordinary Save.
Running a MacBook Pro 15" 2,9 GHz Intel Core i9.
PSD 19.1.6.
The document is RGB and contains 24 layers, some grouped in folders. Some adjustments layers, some gradients, some smart objects.
Doc size 1,87 MB/348,7 MB
OS X: 10.13.6 (17G2208)
Have the same issue om my iMac and my previous MacBook Pro 17" from 2011.
Here is the system info from PSD's help menu (in Swedish, sorry):
Adobe Photoshop-version: 19.1.6 20180808.r.398 2018/08/08: 1185588 x64
Antal starter: 5
Operativsystem: Mac OS 10.13.6
Systemarkitektur: Intel Datorfamilj:6, Modell:158, Version:10 med MMX, SSE-heltal, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Antal fysiska processorer: 6
Antal logiska processorer: 12
Processorhastighet: 2900 MHz
Inbyggt minne: 32768 MB
Ledigt minne: 14192 MB
Minne tillgängligt för Photoshop: 28689 MB
Minne som används av Photoshop: 70 %
Aliaslager: Inaktiverad.
Paletten Funktionsändringstangenter: Inaktiverad.
Highbeam: Inaktiverad.
Feedback för Touch Bar-egenskaper: Aktiverad.
Plattstorlek för bild: 1024K
Bildcache-nivåer: 4
Förhandsgranskning av teckensnitt: Mellan
TextComposer: Latin
Visa: 1
Primär bildskärm
Bildskärm med högt DPI-värde
Visa gränser: överst= 0 till vänster= 0, nederst= 1050 till höger= 1680
OpenGL: Aktiverad.
Tillåt gamla GPU-verktyg för OpenGL: Ej upptäckt.
Ritningsläge för OpenGL: Avancerat
Tillåt normalt OpenGL-läge: Sant.
Tillåt avancerat OpenGL-läge: Sant.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=2
NumCLGPUs=2
NumNativeGPUs=2
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="AMD Radeon Pro 560X OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon Pro 560X OpenGL Engine"
glgpu[0].GLRendererID=16915465
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (May 24 2018 22:33:53)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1536
clgpu[0].CLName="Intel(R) UHD Graphics 630"
clgpu[0].CLVendor="Intel Inc."
clgpu[0].CLVendorID=16925952
clgpu[0].CLDriverVersion="1.2(Jul 20 2018 19:20:00)"
clgpu[0].CLBandwidth=2.1038e+10
clgpu[0].CLCompute=82.7562
nativegpu[0].NativeName="AMD Radeon Pro 560X"
glgpu[1].GLVersion="2.1"
glgpu[1].IsIntegratedGLGPU=0
glgpu[1].GLMemoryMB=4096
glgpu[1].GLName="AMD Radeon Pro 560X OpenGL Engine"
glgpu[1].GLVendor="ATI Technologies Inc."
glgpu[1].GLVendorID=4098
glgpu[1].GLRectTextureSize=16384
glgpu[1].GLRenderer="AMD Radeon Pro 560X OpenGL Engine"
glgpu[1].GLRendererID=16915465
glgpu[1].HasGLNPOTSupport=1
glgpu[1].CanCompileProgramGLSL=1
glgpu[1].GLFrameBufferOK=1
glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[1].CLPlatformVersion="1.2 (May 24 2018 22:33:53)"
clgpu[1].CLDeviceVersion="1.2 "
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=4096
clgpu[1].CLName="AMD Radeon Pro 560X Compute Engine"
clgpu[1].CLVendor="AMD"
clgpu[1].CLVendorID=16915456
clgpu[1].CLDriverVersion="1.2 (Jul 20 2018 19:09:33)"
clgpu[1].CLBandwidth=7.40729e+10
clgpu[1].CLCompute=261.086
nativegpu[1].NativeName="Intel(R) UHD Graphics 630"
Licenstyp: Prenumeration
Serienummer: 90970050409586204668
GUIDBucket:
Programmapp: /Applications/Adobe Photoshop CC 2018/
Photoshops virtuella minne har asynkron I/O aktiverad
Volym(er) för virtuellt minne:
Startskiva, 1,82T, 1,30T fritt
Mappen Nödvändiga plugin-program: /Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/Plug-ins/
Primär mapp för plug-ins: /Applications/Adobe Photoshop CC 2018/Plug-Ins/
Installerade komponenter:
dvametadata.framework dvametadata 11.1.0.0
AdobeXMPScript.framework AdobeXMPScript 79.160451 79.160451
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
AdobeCrashReporter.framework AdobeCrashReporter 7.6.0
boost_system.framework boost_system 11.1.0.0
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeACE.framework AdobeACE 2.20.02.39705 79.589342
AdobeOwl.framework AdobeOwl 5.2.11
mediacoreif.framework mediacoreif 11.1.0.0
manta.framework manta 2.0.00.1 1.
dvaunittesting.framework dvaunittesting 11.1.0.0
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
k2.framework k2 1
AIDE.framework AIDE 1.5.0.36540 79.574279
dynamiclink.framework dynamiclink 11.1.0.0
dvametadataUI.framework dvametadataUI 11.1.0.0
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
AdobeExtendScript.framework AdobeExtendScript 4.5.8.1 81.1150526
boost_filesystem.framework boost_filesystem 11.1.0.0
AdobeBIB.framework AdobeBIB 1.2.03.39705 79.589342
AdobeXMPFiles.framework AdobeXMPFiles 79.160451 79.160451
AdobeLinguistic.framework 22175
dvaplayer.framework dvaplayer 11.1.0.0
PlugPlugOwl.framework PlugPlugOwl 8.5.0.87
AdobeAGM.framework AdobeAGM 4.30.87.39705 79.589342
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
AdobeSVGRE.framework AdobeSVGRE 6.0 79.588619
AdobePDFL.framework AdobePDFL 15.0.0.38423 79.226411
dvacore.framework dvacore 11.1.0.0
AdobePIP.framework AdobePIP 7.4.1.109.46827
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
dvatransport.framework dvatransport 11.1.0.0
Cg.framework NVIDIA Cg
boost_signals.framework boost_signals 11.1.0.0
AdobeXMP.framework AdobeXMPCore 79.160451 79.160451
AdobeJP2K.framework AdobeJP2K 1.2.2.38423 79.266298
dvaaudiodevice.framework dvaaudiodevice 11.1.0.0
LogSession.framework LogSession 7.4.1.109.46827
PlugPlugExternalObject.framework 8.5.0.87
AdobeScCore.framework AdobeScCore 4.5.8.1 81.1150526
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.38473 79.582907
dvametadataapi.framework dvametadataapi 11.1.0.0
CITThreading.framework
WRServices.framework
amtlib.framework amtlib 10.0.0.221
AdobeBIBUtils.framework AdobeBIBUtils 1.1.39705 79.589342
boost_threads.framework boost_threads 11.1.0.0
aif.framework aif 6.0.00.1 1.
AdobeCoolType.framework AdobeCoolType 5.17.00.39705 79.589342
dvamediatypes.framework dvamediatypes 11.1.0.0
AdbePM.framework AdbePM 2.5.00.377243 1.578146
boost_date_time.framework boost_date_time 11.1.0.0
AdobeMPS.framework AdobeMPS 5.8.1.38423 79.582572
dvaui.framework dvaui 11.1.0.0
ahclient.framework ahclient 3.0.0.6
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
dvamarshal.framework dvamarshal 11.1.0.0
3D Studio 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Adaptiv vidvinkel 19.1.6, © 2014-2018 Adobe. All rights reserved. – från filen “Adaptive Wide Angle.plugin”
Al Fresco 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Banor till Illustrator 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Basrelief 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Beskär och räta upp foton 19.1.6 © 2003-2018 Adobe. All rights reserved. – från filen “CropPhotosAuto.plugin”
Beskär och räta upp foton 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Bildpaketfilter 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “ChannelPort.plugin”
Blixt 3D 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Bläckskiss 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Blött papper 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
BMP 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Brevpapper 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Camera Raw 10.5 (1001), Copyright © 2018 Adobe Systems Incorporated – från filen “Camera Raw.plugin”
Camera Raw-filter 10.5 (1001), Copyright © 2018 Adobe Systems Incorporated – från filen “Camera Raw.plugin”
Cineon 19.1.6 © 2002-2018 Adobe. All rights reserved. – från filen “Cineon.plugin”
Collada DAE 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
CompuServe GIF 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Contékrita 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Dicom 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “dicom.plugin”
Differensmoln 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “Clouds.plugin”
Diffus glöd 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Djup 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Eazel Acquire 19.1.6 © 2007-2018 Adobe. All rights reserved. – från filen “EazelAcquire.plugin”
Ej sammanflätning 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Engraver III CS6 (60.0) ©2009-2012 – från filen “EngraverIII.plugin”
Entropi 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Exportera tabeller för färgsökning 19.1.6 © 2012-2018 Adobe. All rights reserved. – från filen “Export3DLUT.plugin”
FastCore-rutiner 19.1.6 © 1990-2018 Adobe. All rights reserved. – från filen “FastCore.plugin”
Fiber 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Filtergalleri 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Fotokopia 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Färgat ritstift 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Färgklickar 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Färgraster 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Förskjutning 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Genomsnitt 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “Average.plugin”
Gips 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Glas 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Glödande kanter 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Google Earth 4 KMZ 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Gränspunkt 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “VanishingPoint.plugin”
Gör flytande 19.1.6, © 2001-2018 Adobe. All rights reserved. – från filen “Liquify.plugin”
Halide Bottlenecks 19.1.6 © 2018 Adobe. All rights reserved. – från filen “HalideBottlenecks.plugin”
HDRMergeUI 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “HDRMergeUI.plugin”
HSB/HSL 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
IFF-format 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
IGES 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Intervall 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
JPEG 2000 19.1.6 © 2001-2018 Adobe. All rights reserved. – från filen “JPEG2000.plugin”
Kantiga streck 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Kantlinje 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Knipning 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Korn 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Kornig film 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Korsstreck 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Krackelering 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Kristallisera 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Krita & träkol 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Krom 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Krusning 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Kurtosis 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Lapptäcke 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Linsoskärpa 19.1.6, © 2002-2018 Adobe. All rights reserved. – från filen “Lens Blur.plugin”
Linsöverstrålning 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Markerade kanter 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Matlab Operation 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “ChannelPort.plugin”
Maximal 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Medel 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Median 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Mezzotint 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Minimum 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
MMXCore-rutiner 19.1.6 © 1990-2018 Adobe. All rights reserved. – från filen “MMXCore.plugin”
Moln 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “Clouds.plugin”
Mosaik 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Mätningskärna 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “MeasurementCore.plugin”
Målat glas 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Mörka streck 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Naggade kanter 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Neonljus 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
NTSC-färger 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “NTSC Colors.plugin”
Nätform 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Objektivkorrigering 19.1.6, © 2002-2018 Adobe. All rights reserved. – från filen “Lens Correct.plugin”
OpenEXR 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Palettkniv 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Pastellkrita 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
PCX 19.1.6 © 1989-2018 Adobe. All rights reserved. – från filen “PCX.plugin”
Photoshop 3D-motor 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “Photoshop3DEngine.plugin”
Photoshop Touch ©2013-2018 Adobe. All rights reserved. – från filen “PSDX.plugin”
Pixar 19.1.6 © 1989-2018 Adobe. All rights reserved. – från filen “Pixar.plugin”
Plastfilm 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
PLY 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Polära koordinater 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Portable Bit Map 19.1.6 © 1989-2018 Adobe. All rights reserved. – från filen “PBM.plugin”
PRC 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Radiance 19.1.6 © 2003-2018 Adobe. All rights reserved. – från filen “Radiance.plugin”
Radiell oskärpa 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Raster 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Rendera stödraster för färgsökning 19.1.6 © 2012-2018 Adobe. All rights reserved. – från filen “Export3DLUT.plugin”
Sfär 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Sicksack 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Skakreducering 19.1.6, © 2014-2018 Adobe. All rights reserved. – från filen “Shake Reduction.plugin”
Skapa fläckar 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Skapa plattor 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Skeva 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Skevhet 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Skriptingstöd 19.1.6, © 2002-2018 Adobe. All rights reserved. – från filen “ScriptingSupport.plugin”
Smart oskärpa 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Smetig penna 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Solarisera 19.1.6 © 1993-2018 Adobe. All rights reserved. – från filen “Solarize.plugin”
Spaces 19.1.6, © 2015-2018 Adobe. All rights reserved. – från filen “Spaces.plugin”
Spara för webben 19.1.6, © 1999-2018 Adobe. All rights reserved. – från filen “Save for Web.plugin”
Sprejade streck 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Standardavvikelse 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Stansa ut 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
STL 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Strukturpenna 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Stämpel 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Stänk 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Stöd för multiprocessor 19.1.6 © 1990-2018 Adobe. All rights reserved. – från filen “MultiProcessor Support.plugin”
Sumi-e 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Summering 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Svamp 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Targa 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Texturerare 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Torr pensel 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Träkol 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
U3D 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Undermålning 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Varians 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “statistics.plugin”
Vattenfärg 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Vattenringar 19.1.6, © 1991-2018 Adobe. All rights reserved. – från filen “Filter Gallery.plugin”
Vind 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Virtual Reality Modeling Language (VRML) 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Virvel 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Våg 19.1.6, © 2003-2018 Adobe. All rights reserved. – från filen “Standard Multiplugin.plugin”
Wavefront|OBJ 19.1.6 © 2006-2018 Adobe. All rights reserved. – från filen “U3D.plugin”
Wireless Bitmap 19.1.6 © 1989-2018 Adobe. All rights reserved. – från filen “WBMP.plugin”
Valfria plugin-program och plugin-program från tredje part:
FontExplorer X Pro 3.5.6, by HLW – från filen “/Applications/Adobe Photoshop CC 2018/Plug-Ins/FontExplorer X for Photoshop CC 2018.plugin/”
Dubblett-plugin-program och avaktiverade plugin-program: INGA
Plug-ins som inte hämtades: INGA
Tillägg:
com.adobe.inapp.purchase 1.0.0 - från filen “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_15_144/purchaseStock.html”
com.adobe.Butler.backend 2.0.0 - från filen “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
Bibliotek 1.0.0 - från filen “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_15_144/index.html”
Nytt dokument 2.2.1 - från filen “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.fnft-2.2.1/fnft.html?v=2.2.1.30”
com.adobe.inapp.typekit.purchase 1.0.0 - från filen “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_15_144/purchaseTypekit.html”
Starta 2.2.1 - från filen “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.start-2.2.1/index.html?v=2.2.1.67”
Adobe Color-teman 6.1.0 - från filen “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Exportera som 3.1.2 - från filen “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
Installerade TWAIN-enheter: INGA
