3 Replies Latest reply on Aug 8, 2018 4:45 PM by davidn77786114
    Script for applying hyperlinks to text
    tudor-v Level 2
      Hello,
      I made a people directory document in InDesign using data merge. Each person has information about his/her social network URLs (LinkedIn, Twitter).
      Is it possible to make a script which searches the InDesign document for all strings looking like this:
      LinkedIn Profile: http://a-very-long-url
      and transforms them into just LinkedIn Profile but with the URL applied as a hyperlink?
      If it's easier for the find/replace operation I could mark the string with delimiters before running the script, to avoid complex URL detection scripting. Maybe something like this (Markdown style): [LinkedIn Profile](http://a-very-long-url/)
      Thank you!
        • 1. Re: Script for applying hyperlinks to text
          Ronald63 Level 4
          Quick snippet, try  ...
          var doc = app.activeDocument;
          // get URL
          app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences.findWhat = '(?i)(?<=LinkedIn Profile: )(https?|www)\\S+\\>';
          var mURL  = doc.findGrep();
          // get Texte
          app.findGrepPreferences.findWhat = 'LinkedIn Profile:';
          var mSource  = doc.findGrep();
          for (var k = 0; k <mSource.length; k++){
              var mHyperlinkDestination = doc.hyperlinkURLDestinations.add(mURL[k].contents);
              var mHyperlinkTextSource = doc.hyperlinkTextSources.add(mSource[k]);
              mHyperlink = doc.hyperlinks.add(mHyperlinkTextSource,mHyperlinkDestination);
              mHyperlink.name =mURL[k].contents;
              mHyperlink.visible=false;
          //remove URL text
          app.changeGrepPreferences.changeTo = '';
          doc.changeGrep();
          //rename 'LinkedIn Profile: ' to 'LinkedIn Profile'
          app.findGrepPreferences.findWhat = 'LinkedIn Profile: ';
          app.changeGrepPreferences.changeTo = 'LinkedIn Profile';
          doc.changeGrep();
          • 2. Re: Script for applying hyperlinks to text
            tudor-v Level 2
            Thank you! Your script worked very well.
            • 3. Re: Script for applying hyperlinks to text
              davidn77786114
              Thank you for providing Ronald. This was super useful. However, being unfamiliar with coding I'm having trouble tweaking the code so it will operate for my purposes. Instead of hyperlinking LinkedIn Profile: I need to hyperlink #1111 but the digits can be variables and there may also be five digits at times.
              Sample below:
              How would I go about doing this?
              After the # is where I'm stuck:
              // get URL
              app.findGrepPreferences.findWhat = '(?i)(?<=# )(https?|www)\\S+\\>='
              // get Texte
              app.findGrepPreferences.findWhat = '#'
              //remove URL text
              doc.changeGrep();
