How would I make this image circular? I mean I would like to make this image transparent around the corners so that it is shaped circular with a diameter of 28 pixels. It now has a dimension of 28x28 pixels.
I know how to draw a perfect circle with a diameter of exactly 28 pixels and place it exactly over the square, but that only leaves me with an additional layer with of a circle.
Any help will be appreciated.
Ok. I got it. I found in the menu Layer->Create Clipping Mask. That did it.
Thank you.
Rearrage the layers, then right click on the top layer and select clipping mask
I only see "Clip Thumbnails to Layer Bounds" and "Clip Thumbnails to Document Bounds".
Thank you.
You need to right click on the layer’s name to get the memu which contains clipping mask command
I want to make a square logo with a round border .
Not seeing " create clipping mask
or elipse
You have to select both of the objects, then go to Create Clipping Mask. I just get there by searching it in 'Help'. When you click Create Clipping Mask, it will crop to the shape you've made.
