How do I make a circular image of a square image?
Participant ,
Aug 10, 2018 Aug 10, 2018
How would I make this image circular? I mean I would like to make this image transparent around the corners so that it is shaped circular with a diameter of 28 pixels. It now has a dimension of 28x28 pixels.
I know how to draw a perfect circle with a diameter of exactly 28 pixels and place it exactly over the square, but that only leaves me with an additional layer with of a circle.
Any help will be appreciated.
831
Participant , Aug 10, 2018 Aug 10, 2018
Ok. I got it. I found in the menu Layer->Create Clipping Mask. That did it.
Thank you.
Adobe
Rearrage the layers, then right click on the top layer and select clipping mask
Participant ,
I only see "Clip Thumbnails to Layer Bounds" and "Clip Thumbnails to Document Bounds".
Participant ,
Thank you.
You need to right click  on the layer’s name to get the memu which contains clipping mask command
Aug 19, 2021 Aug 19, 2021
I want to make a square logo with a round border .
Not seeing " create clipping mask
or elipse
Feb 14, 2023 Feb 14, 2023
You have to select both of the objects, then go to Create Clipping Mask. I just get there by searching it in 'Help'. When you click Create Clipping Mask, it will crop to the shape you've made.
