Greetings,
I'm experiencing a lot of trouble with my copy of Photoshop CC 2018. First, it displays an error window at launch saying that it couldn't run a non-cited operation due to a program error. Closing this window will still let you use Photoshop, but with two other problems. The first one being: the paint brush is laggy as hell; le the line will drag behind the brushs and the strokes will only be displaying after a variable delay, wich is veeeeery anoying. I made my reseach on this problem, and it seems that a common solution is to deactivate material acceleration. Expect... I can't do that, because the same error window mentionned earlier will pop again and upon closing it, will turn into gray all of the menus, effectively rendering Photoshop useless. I have to close and relaunch it to have a somewhat functionnal software again.
My specs are:
Intel Core i5 4670
Windows 7 SP1
16 Go RAM
NVIDIA GeForce GTX 1060 3GB & double screen setup
Wacom Intuo SP
I've allready tried the following fixes to no avail:
- Updating OS & Drivers, incuding the CG ones
- reinitalizing preferences
- uninstalling and reinstalling Photoshop CC
- lowering the smooth option of the brush to 0
I can provide the folowing data:
- A Dxdiag of my machine (complete list of the technical characteristics)
- Logs extracted with the support software provided by Adobe.
As a last note, I'll say that I also have a competitor's software installed, and that I have have no brush lag or system issues with it.
I hope that my probelm can be solved, as I do prefer the way more functionnality-rich environement of Photoshop over said competitor soft.
Hi
You mention double displays. They work fine if they are plugged into the same GPU. Multiple GPUs with conflicting drivers can cause issues. See section 7 here: Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
If you only have one GPU please go to Photoshop Help>System Info and click "Copy". Then paste the info here.
Dave
Thanks for your response. Both of the screens are pluged to the same GPU (and I only have that one afaik; no video plug on the MB), albeit one via Displayport and the other with DVI (can't do otherwise as the displayports are dead on one of the monitors and the CG only have 1 DVI and 1 HDMI ports as alternatives)
Here is the data you asked for:
Version Adobe Photoshop : 19.1.5 20180604.r.346 2018/06/04: 1175273 x64
Nombre de lancements : 3
Système d'exploitation : Windows 7 64 bits
Version : 7 SP1 6.1.7601.24168
Architecture système : UC Intel Famille :6, modèle :12, niveau :3 avec MMX, SSE Entier, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Nombre de processeurs physiques : 4
Vitesse du processeur : 3392 MHz
Mémoire intégrée : 16263 Mo
Mémoire libre : 10414 Mo
Mémoire disponible pour Photoshop : 14878 Mo
Mémoire utilisée par Photoshop : 70 %
Calques d'alias : Désactivé.
Palette de touches de modification : Désactivé.
Highbeam: Activé.
Taille de la mosaïque d'images : 1024K
Niveaux de mémoire cache de l'image : 4
Aperçu de la police : Moyenne
Compositeur de texte : Latin
Affichage : 1
Limites d'affichage : haut = 0, gauche = 0, bas = 1080, droite = 1920
Affichage : 2
Limites d'affichage : haut = 0, gauche = -1920, bas = 1080, droite = 0
Dessin OpenGL : Désactivé.
Anciens GPU OpenGL autorisés : Non détectés.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=3072
glgpu[0].GLName="NVIDIA GeForce GTX 1060 3GB"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="24.21.13.9882"
glgpu[0].GLRectTextureSize=32768
glgpu[0].GLRenderer="GeForce GTX 1060 3GB/PCIe/SSE2"
glgpu[0].GLRendererID=7170
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
glgpu[0].GLDriverDate="20180730000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=3072
clgpu[0].CLName="GeForce GTX 1060 3GB"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="398.82"
clgpu[0].CLBandwidth=1.40835e+11
clgpu[0].CLCompute=1600.23
Type de licence : Abonnement
Numéro de série : 96040354890011576731
GUIDBucket:
Dossier de l'application : C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Chemin des fichiers temporaires : C:\Users\SMOGSH~1\AppData\Local\Temp\
Le disque de travail de Photoshop comporte l'E/S asynchrone activé.
Volume(s) de travail :
Démarrage, 465,7 Go, 271,9 Go libres
Dossier des modules externes obligatoires : C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Dossier principal des modules externes : C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Composants installés :
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/11/22-18:28:12 79.589342 79.589342
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2017/10/31-06:12:59 79.250229 79.250229
AdobePIP.dll Adobe Product Improvement Program 7.4.1.109.46827
AdobeSVGAGM.dll AdobeSVGAGM 79.588619 79.588619
AdobeXMP.dll Adobe XMP Core 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPFiles.dll Adobe XMP Files 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPScript.dll Adobe XMP Script 2017/07/13-01:06:39 79.160924 79.160924
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/11/22-18:28:12 79.589342 79.589342
ahclient.dll AdobeHelp Dynamic Link Library 3.0.0.6
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8) 1.000000
ARE.dll ARE 2017/11/22-18:28:12 79.589342 79.589342
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/11/22-18:28:12 79.589342 79.589342
BIBUtils.dll BIBUtils 2017/11/22-18:28:12 79.589342 79.589342
boost_date_time.dll photoshopdva 11.1.0
boost_filesystem.dll photoshopdva 11.1.0
boost_signals.dll photoshopdva 11.1.0
boost_system.dll photoshopdva 11.1.0
boost_threads.dll photoshopdva 11.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/11/22-18:28:12 79.589342 79.589342
CRClient.dll Adobe Crash Reporter Client DLL 1.6.3.0
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 11.1.0
dvacore.dll photoshopdva 11.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 11.1.0
dvamediatypes.dll photoshopdva 11.1.0
dvametadata.dll photoshopdva 11.1.0
dvametadataapi.dll photoshopdva 11.1.0
dvametadataui.dll photoshopdva 11.1.0
dvaplayer.dll photoshopdva 11.1.0
dvatransport.dll photoshopdva 11.1.0
dvaui.dll photoshopdva 11.1.0
dvaunittesting.dll photoshopdva 11.1.0
dynamiclink.dll photoshopdva 11.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1150526 81.1150526
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.22
JP2KLib.dll JP2KLib 2017/10/31-01:22:04 79.268591 79.268591
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
LogSession.dll LogSession 7.4.1.109.46827
mediacoreif.dll photoshopdva 11.1.0
MPS.dll MPS 2017/10/31-01:22:04 79.588396 79.588396
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2018 19.1.5
Plugin.dll Adobe Photoshop CC 2018 19.1.5
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 8.5.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 8.5.0.87
PSArt.dll Adobe Photoshop CC 2018 19.1.5
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2018 19.1.5
SCCore.dll ScCore 2017/08/31-12:13:14 81.1150526 81.1150526
SVGRE.dll SVGRE 79.586793 79.586793
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WinRTSupport.dll Adobe Photoshop Windows RT Support 19.0.0.0
WRServices.dll WRServices Thu June 21 2017 12:26:24 Build 0.22473 0.22473
wu3d.dll U3D Writer 9.3.0.113
Modules externes obligatoires :
3D Studio 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Aérographe 19.1.5 - du fichier “Filter Gallery.8bf”
Aplatissement 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Aquarelle 19.1.5 - du fichier “Filter Gallery.8bf”
Asymétrie 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Barbouillage 19.1.5 - du fichier “Filter Gallery.8bf”
Bas-relief 19.1.5 - du fichier “Filter Gallery.8bf”
BMP 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Camera Raw 10.4 - du fichier “Camera Raw.8bi”
Carrelage 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Chrome 19.1.5 - du fichier “Filter Gallery.8bf”
Cineon 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Cineon.8bi”
Cisaillement 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Collada 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
CompuServe GIF 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Contour accentué 19.1.5 - du fichier “Filter Gallery.8bf”
Contour déchiré 19.1.5 - du fichier “Filter Gallery.8bf”
Contour encré 19.1.5 - du fichier “Filter Gallery.8bf”
Contour lumineux 19.1.5 - du fichier “Filter Gallery.8bf”
Contour postérisé 19.1.5 - du fichier “Filter Gallery.8bf”
Contraction 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Coordonnées polaires 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Correction de l'objectif 19.1.5 - du fichier “Lens Correction.8bf”
Couleurs NTSC 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “NTSC Colors.8bf”
Couteau à palette 19.1.5 - du fichier “Filter Gallery.8bf”
Craie/Fusain 19.1.5 - du fichier “Filter Gallery.8bf”
Craquelure 19.1.5 - du fichier “Filter Gallery.8bf”
Crayon Conté 19.1.5 - du fichier “Filter Gallery.8bf”
Crayon de couleur 19.1.5 - du fichier “Filter Gallery.8bf”
Cristallisation 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Croisillons 19.1.5 - du fichier “Filter Gallery.8bf”
Découpage 19.1.5 - du fichier “Filter Gallery.8bf”
Demi-teintes couleur 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Désentrelacement 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Diagonales 19.1.5 - du fichier “Filter Gallery.8bf”
Dicom 19.1.5 - du fichier “Dicom.8bi”
Dispersion 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Eazel Acquire 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “EazelAcquire.8ba”
Ecart type 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Effet mosaïque 19.1.5 - du fichier “Filter Gallery.8bf”
Effet pointilliste 19.1.5 - du fichier “Filter Gallery.8bf”
Emballage plastique 19.1.5 - du fichier “Filter Gallery.8bf”
Enregistrer pour le Web 19.1.5 - du fichier “Save for Web.8be”
Entropie 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Eponge 19.1.5 - du fichier “Filter Gallery.8bf”
Etalement 19.1.5 - du fichier “Filter Gallery.8bf”
Exporter les tables de correspondance de couleur 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Export3DLUT.8be”
Extension WIA 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “WIASupport.8li”
Extrusion 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Fibres 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Filtre Camera Raw 10.4 - du fichier “Camera Raw.8bi”
Filtre Collection d'images 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “ChannelPort.8bf”
Filtre Rogner et désincliner les photos 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Flash 3D 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Flou de l'objectif 19.1.5 - du fichier “Lens Blur.8bf”
Flou optimisé 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Flou radial 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Fluidité 19.1.5 - du fichier “Liquify.8bf”
Format IFF 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Fresque 19.1.5 - du fichier “Filter Gallery.8bf”
Galerie de filtres 19.1.5 - du fichier “Filter Gallery.8bf”
Google Earth 4 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Grain 19.1.5 - du fichier “Filter Gallery.8bf”
Grain photo 19.1.5 - du fichier “Filter Gallery.8bf”
Grand-angle adaptatif 19.1.5 - du fichier “Adaptive Wide Angle.8bf”
Halide Bottlenecks 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “HalideBottlenecks.8bx”
Halo 19.1.5 - du fichier “Standard MultiPlugin.8bf”
HDRMergeUI 19.1.5 - du fichier “HDRMergeUI.8bf”
IGES 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
JPEG 2000 19.1.5 - du fichier “JPEG2000.8bi”
Lueur diffuse 19.1.5 - du fichier “Filter Gallery.8bf”
Matlab Operation 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “ChannelPort.8bf”
Maximum 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Médiane 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Mezzo-tinto 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Minimum 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Moteur 3D Photoshop 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Photoshop3DEngine.8bi”
Motif de demi-teintes 19.1.5 - du fichier “Filter Gallery.8bf”
Moyenne 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Average.8bf”
Moyenne arithmétique 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Multiprocesseur 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “MultiProcessor Support.8bx”
Néon 19.1.5 - du fichier “Filter Gallery.8bf”
Noir/Blanc 19.1.5 - du fichier “Filter Gallery.8bf”
Noyau de mesures 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “MeasurementCore.8me”
Nuages 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Clouds.8bf”
Nuages par différence 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Clouds.8bf”
Océan 19.1.5 - du fichier “Filter Gallery.8bf”
Onde 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Ondulation 19.1.5 - du fichier “Standard MultiPlugin.8bf”
OpenEXR 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Papier gaufré 19.1.5 - du fichier “Filter Gallery.8bf”
Papier humide 19.1.5 - du fichier “Filter Gallery.8bf”
Pastels 19.1.5 - du fichier “Filter Gallery.8bf”
Patchwork 19.1.5 - du fichier “Filter Gallery.8bf”
PCX 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “PCX.8bi”
Photocopie 19.1.5 - du fichier “Filter Gallery.8bf”
Photoshop Touch 19.0 - du fichier “PSDX.8bi”
Pinceau à sec 19.1.5 - du fichier “Filter Gallery.8bf”
Pixar 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Pixar.8bi”
Placage de texture 19.1.5 - du fichier “Filter Gallery.8bf”
Plâtre 19.1.5 - du fichier “Filter Gallery.8bf”
Plume calligraphique 19.1.5 - du fichier “Filter Gallery.8bf”
PLY 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Point de fuite 19.1.5 - du fichier “VanishingPoint.8bf”
Pointillisme 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Portable Bit Map 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “PBM.8bi”
Portée 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
PRC 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Radiance 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Radiance.8bi”
Réduire tremblement 19.1.5 - du fichier “Shake Reduction.8bf”
Rendu de la grille de correspondance de couleur 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Export3DLUT.8be”
Réticulation 19.1.5 - du fichier “Filter Gallery.8bf”
Rogner et désincliner les photos 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “CropPhotosAuto.8li”
Routines FastCore 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “FastCore.8bx”
Routines MMXCore 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “MMXCore.8bx”
Solarisation 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “Solarize.8bf”
Sommation 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Soufflerie 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Sous-couche 19.1.5 - du fichier “Filter Gallery.8bf”
Spaces 19.1.5 - du fichier “Spaces.8li”
Sphérisation 19.1.5 - du fichier “Standard MultiPlugin.8bf”
STL 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Sumi-e 19.1.5 - du fichier “Filter Gallery.8bf”
Support de script 19.1.5 - du fichier “ScriptingSupport.8li”
Tampon 19.1.5 - du fichier “Filter Gallery.8bf”
Targa 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Tourbillon 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Tracés vers Illustrator 19.1.5 - du fichier “Standard MultiPlugin.8bf”
TSL/TSI 19.1.5 - du fichier “Standard MultiPlugin.8bf”
U3D 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Variance 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “statistics.8ba”
Verre 19.1.5 - du fichier “Filter Gallery.8bf”
Virtual Reality Modeling Language | VRML 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Vitrail 19.1.5 - du fichier “Filter Gallery.8bf”
Wavefront|OBJ 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “U3D.8bi”
Wireless Bitmap 19.1.5 (20180604.r.346 2018/06/04: 1175273) - du fichier “WBMP.8bi”
Zigzag 19.1.5 - du fichier “Standard MultiPlugin.8bf”
Dossier des modules externes tiers et facultatifs : SANS
Modules externes désactivés et doublons : AUCUN
Modules externes dont le chargement a échoué : AUCUN
Extensions :
com.adobe.inapp.purchase 1.0.0 - A partir du fichier “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseStock.html”
com.adobe.Butler.backend 2.0.0 - A partir du fichier “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
Bibliothèques 1.0.0 - A partir du fichier “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\index.html”
Nouveau document 2.2.1 - A partir du fichier “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.2.1\fnft.html?v=2.2.1.30”
com.adobe.inapp.typekit.purchase 1.0.0 - A partir du fichier “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_14_207\purchaseTypekit.html”
Démarrage 2.2.1 - A partir du fichier “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.2.1\index.html?v=2.2.1.67”
Thèmes Adobe Color 6.1.0 - A partir du fichier “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Exporter en tant que 3.1.2 - A partir du fichier “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Modules TWAIN installés : AUCUN
Hi
You are right there is only one GPU and it is detected OK but for some reason Open GL drawing is disabled. Your drivers are up to date as far as I can tell
If you can't get into Preferences to change that (and you have already reset preferences) then I would uninstall and reinstall again - but this time run the Adobe CC cleaner tool between the uninstall and reinstall.
https://helpx.adobe.com/uk/creative-cloud/kb/cc-cleaner-tool-installation-problems.html
Dave
I did as instructed, but unfortunatly it didn't change anything. Uninstalled Photoshop CC and then downloaded and ran the cleaner as an administrator to clean all softwares, just in case. Strange thing to note: I didn't get a log text file as indicated once the cleaner was done and closed. I then re-dowloaded the installer and ran it. Once it was done, Photoshop launched and I was greeted with that same error message. The problem persist with preferences and the lag too. I checked the system info and OpenGL drawing is still disabled. Is there a way we could activate it other than the preference menu? A config file? Registery parameter?
So. I managed to solve at least one problem. I don't have any error messages and can access to performances as long as I launch Photoshop as an admin. I do however still experience lag on my brush strokes, with or without material acceleration. Tried to switch between different modes of performances that we can define in the "advanced" option (an relaunching the software between changes), but that didn't improve anything.
