I've installed Acrobat Reader DC (free) and uninstalled it several times on Windows 10. The install completes normally but I can't get the application to open or to respond when double-clicking a .pdf file name.
Tried it all for a second time and found that I could open Reader from the application in the Adobe directory on my C drive. Then fixed it to the start menu and all seems OK now.
David
Hello Stephenc,
We're sorry for the trouble you had with Adobe Reader, please use Acrobat cleaner tool to remove installed Adobe Reader Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
Reboot the machine once and then download the latest version of Adobe Reader from Adobe - Adobe Acrobat Reader DC Distribution
Let us know how it goes and share your observation.
Anand Sri.
[Edited response]
After a few tries (to find the right place to right click to find properties) I completed the uninstall/cleaning and reinstall as you suggested and the results are unchanged. I do appreciate your help.
Steve Clarke
Hi Stephenc,
We're sorry for the delayed response and inconvenience caused. Please create a test user profile with full admin rights and try installing Adobe Reader and see if the issue is reproducible.
Anand Sri.
Thank you Anand, how can I learn to create a test user profile with full
administrative rights? I will be happy to run the test. Steve Clarke
Anand I just saw your prior email explaining how to run with full
administrative rights. If I follow that procedure will it create the test
user profile?
On Wed, Aug 22, 2018 at 8:27 AM, Stephen Clarke <
Hi Stephen,
Please follow the steps from the following Microsoft support link https://support.microsoft.com/en-in/help/4026923/windows-10-create-a-local-user-or-administrator-acc...
Anand Sri.
Anand, I believe I completed the steps just as you outlined but I see no
change in the way Reader responds:
1. Double click the shortcut icon and it thinks for a few seconds and
doesn't do anything.
2. Double click a .pdf and it thinks for a few seconds and doesn't do
anything.
Any more ideas? You are welcome to access my machine if you wish. Steve
Clarke
Hello Steve,
We're sorry for the delayed response and inconvenience caused. have you created a test user profile with full admin rights (steps shared to create a test user profile in https://support.microsoft.com/en-in/help/4026923/windows-10-create-a-local-user-or-administrator-acc... )?
If not, please create a test user profile with admin rights, and install Adobe Reader and check. If you still experience any issue, please share your contact details, the best time for a callback and the timezone so that we can schedule a remote session and can assist you further. Please share these details by private message only How Do I Send Private Message
For testing purpose, please connect the machine to a different network environment like a guest wireless network or a mobile hotspot and disable the security software and try installing Adobe Reader.
Let us know how it goes and share your findings.
Thanks for your time and patience thus far.
Regards
Anand Sri.
I have exactly the same problem and this does not solve it.
David
David
