hi,
i want to send a document for signature. On my mac and on my pc I saw this message:
What can I do?
Sophia
P.S. please excude my english.
Hi Sophiak,
As per the issue description mentioned above, you are facing issue when trying to send pdf for signature, is that correct?
If you are using Acrobat or Reader try logging-out and login-in back, check if that resolves the issue. If you still experiencing the problem you may use this service via web browser: Sign In — e-signature and e-sign Software Solution — Adobe Sign
Also, make sure your web browser is updated to the latest patch. You may refer to the following help docs for more inf
...Copy link to clipboard
Hi Sophiak,
Also, make sure your web browser is updated to the latest patch. You may refer to the following help docs for more info:
An error occurred while trying to access the service | unable to connect to PDF services
End of Life for TLS1.0 and 1.1 support
Let us know if you need any help.
Shivam
