Whenever I save a document I have been working on in Acrobat Pro 17 it seems to revert to an Acrobat Reader DC file. This obviously means that when I open the file again I have no access to any of the Pro tools which I have been using.
My question is: What can I do to re-open files in Pro 17 rather than Reader DC? Is it a case of asking our IT helpdesk to remove Reader DC or is there a simpler way?
In the preferences of Adobe Acrobat you can set it as default PDF handler.
Search bar at the top of http://www.microsoft.com/en-us/default.aspx to find out how to set your PDF file association to the program you wish to use
There is no good reason to have both Acrobat Pro and Acrobat Reader installed on the same system. The functions of Reader are a subset of those of Acrobat Pro.
- Dov
There's no such thing as an "Acrobat file" or a "Reader file". They are all PDF files, it's just a question of which application opens them.
Why do you have Reader if you have Acrobat, though? There's no need for it, unless you want to test the files you create in that application.
Uninstall Acrobat Reader and repair the installation of Adobe Acrobat.
Thanks for the replies guys.
The reason I currently have both is that I work for a large organisation and have no administrator rights. When I asked to have Pro installed the IT guys installed it but left reader there as well.
I was asking the above question to see if there was an easy way to do it without having to go to our IT to have Reader removed.
