Im trying to install Lr 6,14 unsuccessfully, spent hours on installing/uninstalling Lr file from the Adobe webside as the dowloaded zip file does not contain exe. file to run the program. Pease help as Im loosing it... I originally purchased Lr 6,0 and wanted to update so it would run my raw files
[Moderator moved from Adobe Creative Cloud to Lightroom Classic CC — The desktop-focused app.]
are you downloading from here, Download Photoshop Lightroom
[moved from Adobe Creative Cloud to Downloading, Installing, Setting Up]
Yes
Did you unzip the download folder with a decompression utility like WinZip or StuffIt?
See correct answer below for details.
Yes
did you successfully install lr 6.0?
if yes, what did you see after double clicking setup.exe from the unzipped 6.14 files?
There thing is the setup does not include the exe files. I installed /uninstalled it dozens often times, guy from Adobe tried too. Nothing
You have to download the "Application Installer" to install Lightroom 6.0 (from the link I gave above). On Windows it is an .exe file. Did you do that?
Step 1 — Download and install Lightroom 6.0 from the Application Installer at Download Photoshop Lightroom
Step 2 — Download and install the 6.14 update (has to be unzipped on Windows) from the same web site.
Five hrs later still no hope. The guy from Adobe support is working only it only my PC remotely. Nobody solution found. App keeps falling. So the Lr 6.0 is now being installed again ans apparently the path should run fine now . Will find out
Update, it had taken so long that the Adobe agent had disconnected saying he would come back to it tomorrow ;(
Oh so sorry for my chaotic writting an misstypos , my auto wording sucks. I'm installing Lr 6.0 Again and will give a try for update ones more time
Success! After installing Lr 6.0 Again the launch worked (also Adobe Application Manager 10.0 had had been installed prior to installation of the Lr 6)
Do not forget to apply the 6.14 update now. It's the last update for the perpetual license and holds some new cameras and lenses and applies some fixes.
