Hi all,
I'm having a little problem with something that I believe should be quite simple. I'm trying to create a deck chair's striped canvas, which tapers from the top to the bottom of the shape. I need the stripes inside of the shape to taper also, meaning that the width at the top of the stripe will be slightly wider than its width at the bottom.
I had been messing about with envelope distort but this is just affecting the shape and using it as a clipping mask to the unaffected striped gradient behind.
Hope I've made that understandable.
Please help!
Will
If those orange stripes are a pattern or gradient, its not going to work that way. You'll need to make the stripes out of actual shapes and group them.
Object > Envelope Distort > Envelope Options:
Distort Pattern fills
Brilliant, thank you very much!
It may be brilliant, but not very flexible.
Did you try:
