First problem
When i add one video in premiere that works but when i add the second one only sound can be added.
When i do a new installation from scratch it work a couple of times good but then the problem is back again.
The video format is the same 1920x1080 and 50 fps
Second problem when i click help premiere is closed.
ernstg56244535 wrote
First problem
Check your Source Patching and Track Targeting:
MtD
First problem
MtD
You need to source patch the track: double click on the clip in the project panel which will trigger the patching, then add from Source monitor to timeline.
Thanks everyone it works.
