the problem is I have the 3D option available but when I'm trying to create new 3D Object by hitting the 'Create' button I get the error message saying I have to turn Graphic Acceleration in options - but its on.
I have 2 Video cards, both nVidia (GTX 680 and GTX 1080) so after I've found an info that Adobe Photoshop does not support multi GPU I've tried to switch them off in nVidia setting for the application (force to use first and then second) but that didn't help.
Tried to turn the graphic acceleration of, resetting Photoshop, turning it on again with different settings, Basic, Normal, Advanced. Still have this error message when I try to Create some 3D shapes.
All other functions work, I have no glitches, no crashes, Oil Paint works.. help ?
latest Windows 10, latest CC, latest drivers
thanks, S.
Hi Sn3d,
Please follow the steps mentioned in Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues and let us know if that helps.
Akash
Hi Sn3d,
Akash
Hi Akash,
thanks for replying . I've checked all the steps and that's no help for me. It doesn't crush at all, works fine like I've wrote before, nothing is grayed out, 3D window has all the buttons but when I try to create an object it says there is no Graphic Acceleration.
best,
S.
I'm having the same trouble -- especially after the latest round of updates. My video driver is completely up to date but Adobe informs me that it's not the latest driver or that it doesn't support the acceleration.
Dear Adobe, you need to change to suit us; not the other way around. You caused the problem because I was quite capable of doing 3D graphics BEFORE your latest update. Roll it back.
Was a solution found for this problem? I was using 3D graphics before my latest update but now they are greyed out. I followed all the steps in the recommended help but it's still not functioning.
Hi Tomgri
A few basic steps for troubleshooting the 3D graphics.
1. Check your document is in RGB mode - 3D is not available in other image modes
2. Check you have "Use graphics processor" checked in Preferences Performance
3. Go to Help >System Info - click "Copy" and paste the info here. It may help us see why 3D is greyed out.
Dave
Thanks so much Dave, I had it in CYMK! Appreciate your help!
Sincerely,
Tara
You're welcome
Dave
please I have the same issue. I can't use 3d in my photoshop cc 2017, although I am still using free mode.
Adobe Photoshop Version: 2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006 x32
Number of Launches: 6
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:12, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
Physical processor count: 2
Processor speed: 1600 MHz
Built-in memory: 1954 MB
Free memory: 260 MB
Memory available to Photoshop: 1410 MB
Memory used by Photoshop: 70 %
Alias Layers: ^0
Modifier Palette: Enabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=768, right=1366
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=1
glgpu[0].GLMemoryMB=1024
glgpu[0].GLName="Intel(R) HD Graphics"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="20.19.15.4531"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel(R) HD Graphics 400"
glgpu[0].GLRendererID=8881
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumdim32.dll,igd10iumd32
.dll,igd10iumd32.dll,igd12umd32.dll"
glgpu[0].GLDriverDate="2016092
9000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADIN
G_LANGUAGE_VERSION]="1.30 - Build 20.19.15.4531"
glgpu[0].glGetProgramivARB[GL_
FRAGMENT_PROGRAM_ARB][GL_MAX_P
ROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_
TEXTURE_UNITS]=[8]
COMBINED_TEXTURE_IMAGE_UNITS]=[192]
VERTEX_TEXTURE_IMAGE_UNITS]=[32]
DRAW_BUFFERS]=[8]
VERTEX_UNIFORM_COMPONENTS]=[4096]
FRAGMENT_UNIFORM_COMPONENTS]=[4096]
VARYING_FLOATS]=[64]
VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::G
L_ARB_VERTEX_PROGRAM]=1
L_ARB_FRAGMENT_PROGRAM]=1
L_ARB_VERTEX_SHADER]=1
L_ARB_FRAGMENT_SHADER]=1
L_EXT_FRAMEBUFFER_OBJECT]=1
L_ARB_TEXTURE_RECTANGLE]=1
L_ARB_TEXTURE_FLOAT]=1
L_ARB_OCCLUSION_QUERY]=1
L_ARB_VERTEX_BUFFER_OBJECT]=1
L_ARB_SHADER_TEXTURE_LOD]=0
clgpu[0].CLPlatformVersion="1.2 "
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=773
clgpu[0].CLName="Intel(R) HD Graphics 400"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="20.19.15.4531"
clgpu[0].CLBandwidth=0
clgpu[0].CLCompute=0
License Type: Tryout Version
Serial number: Tryout Version
GUIDBucket:
bucket: 128
test: ReduceUXFriction
Application folder: C:\Program Files\Adobe\Ado
be Photoshop CC 2017 (32 Bit)\
Temporary file path: C:\Users\Tommy\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 464.4G, 375.5G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\P
lug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2016/09/17-17:22:04 79.577309 79.577309
AdbePM.dll PatchMatch 2016/05/17:03:10:18 1.573920 1.573920
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.577309 79.577309
AdobeXMP.dll Adobe XMP Core 2016/09/
14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/
AdobeXMPScript.dll Adobe XMP Script 2016/09/
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2016/09/17-17:22:04 79.577309 79.577309
ahclient.dll AdobeHelp Dynamic Link Library 2.0.0.2
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib 10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17) 1.000000
ARE.dll ARE 2016/09/17-17:22:04 79.577309 79.577309
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/
13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/
Bib.dll BIB 2016/09/17-17:22:04 79.577309 79.577309
BIBUtils.dll BIBUtils 2016/09/17-17:22:04 79.577309 79.577309
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.0.1 2.1.0.1
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2016/09/17-17:22:04 79.577309 79.577309
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/01/
26-16:09:33 80.1060872 80.1060872
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.1
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.0.0
Plugin.dll Adobe Photoshop CC 2017 18.0.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (32 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (32 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.0.0
PSViews.dll Adobe Photoshop CC 2017 18.0.0
SCCore.dll ScCore 2016/01/26-16:09:33 80.1060872 80.1060872
SVGRE.dll SVGRE 79.577309 79.577309
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D”
Accented Edges 18.0.0 - from the file “Filter Gallery”
Adaptive Wide Angle 18.0.0 - from the file “Adaptive Wide Angle”
Angled Strokes 18.0.0 - from the file “Filter Gallery”
Average 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Average”
Bas Relief 18.0.0 - from the file “Filter Gallery”
BMP 18.0.0 - from the file “Standard MultiPlugin”
Camera Raw 9.6 - from the file “Camera Raw”
Camera Raw Filter 9.6 - from the file “Camera Raw”
Chalk && Charcoal 18.0.0 - from the file “Filter Gallery”
Chrome 18.0.0 - from the file “Filter Gallery”
Cineon 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Cineon”
Clouds 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Clouds”
Collada 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D”
Color Halftone 18.0.0 - from the file “Standard MultiPlugin”
Colored Pencil 18.0.0 - from the file “Filter Gallery”
CompuServe GIF 18.0.0 - from the file “Standard MultiPlugin”
Conté Crayon 18.0.0 - from the file “Filter Gallery”
Craquelure 18.0.0 - from the file “Filter Gallery”
Crop and Straighten Photos 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “CropPhotosAuto”
Crop and Straighten Photos Filter 18.0.0 - from the file “Standard MultiPlugin”
Crosshatch 18.0.0 - from the file “Filter Gallery”
Crystallize 18.0.0 - from the file “Standard MultiPlugin”
Cutout 18.0.0 - from the file “Filter Gallery”
Dark Strokes 18.0.0 - from the file “Filter Gallery”
De-Interlace 18.0.0 - from the file “Standard MultiPlugin”
Dicom 18.0.0 - from the file “Dicom”
Difference Clouds 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Clouds”
Diffuse Glow 18.0.0 - from the file “Filter Gallery”
Displace 18.0.0 - from the file “Standard MultiPlugin”
Dry Brush 18.0.0 - from the file “Filter Gallery”
Eazel Acquire 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “EazelAcquire”
Entropy 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
Export Color Lookup Tables NO VERSION - from the file “Export3DLUT”
Extrude 18.0.0 - from the file “Standard MultiPlugin”
FastCore Routines 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “FastCore”
Fibers 18.0.0 - from the file “Standard MultiPlugin”
Film Grain 18.0.0 - from the file “Filter Gallery”
Filter Gallery 18.0.0 - from the file “Filter Gallery”
Flash 3D 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D”
Fresco 18.0.0 - from the file “Filter Gallery”
Glass 18.0.0 - from the file “Filter Gallery”
Glowing Edges 18.0.0 - from the file “Filter Gallery”
Google Earth 4 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D”
Graphic Pen 18.0.0 - from the file “Filter Gallery”
Halftone Pattern 18.0.0 - from the file “Filter Gallery”
HDRMergeUI 18.0.0 - from the file “HDRMergeUI”
HSB/HSL 18.0.0 - from the file “Standard MultiPlugin”
IFF Format 18.0.0 - from the file “Standard MultiPlugin”
IGES 18.0.0 (2017.0.0 20161012.r.53 2016/10/
Ink Outlines 18.0.0 - from the file “Filter Gallery”
JPEG 2000 18.0.0 - from the file “JPEG2000”
Kurtosis 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
Lens Blur 18.0.0 - from the file “Lens Blur”
Lens Correction 18.0.0 - from the file “Lens Correction”
Lens Flare 18.0.0 - from the file “Standard MultiPlugin”
Liquify 18.0.0 - from the file “Liquify”
Matlab Operation 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “ChannelPort”
Maximum 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
Mean 18.0.0 (2017.0.0 20161012.r.53 2016/10/
Measurement Core 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “MeasurementCore.8me”
Median 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
Mezzotint 18.0.0 - from the file “Standard MultiPlugin”
Minimum 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
MMXCore Routines 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “MMXCore”
Mosaic Tiles 18.0.0 - from the file “Filter Gallery”
Multiprocessor Support 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “MultiProcessor Support”
Neon Glow 18.0.0 - from the file “Filter Gallery”
Note Paper 18.0.0 - from the file “Filter Gallery”
NTSC Colors 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “NTSC Colors”
Ocean Ripple 18.0.0 - from the file “Filter Gallery”
OpenEXR 18.0.0 - from the file “Standard MultiPlugin”
Paint Daubs 18.0.0 - from the file “Filter Gallery”
Palette Knife 18.0.0 - from the file “Filter Gallery”
Patchwork 18.0.0 - from the file “Filter Gallery”
Paths to Illustrator 18.0.0 - from the file “Standard MultiPlugin”
PCX 18.0.0 (2017.0.0 20161012.r.53 2016/10/
12:23:00:00 CL 1094006) - from the file “PCX”
Photocopy 18.0.0 - from the file “Filter Gallery”
Photoshop 3D Engine 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Photoshop3DEngine”
Photoshop Touch 14.0 - from the file “PSDX”
Picture Package Filter 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “ChannelPort”
Pinch 18.0.0 - from the file “Standard MultiPlugin”
Pixar 18.0.0 (2017.0.0 20161012.r.53 2016/10/
12:23:00:00 CL 1094006) - from the file “Pixar”
Plaster 18.0.0 - from the file “Filter Gallery”
Plastic Wrap 18.0.0 - from the file “Filter Gallery”
PLY 18.0.0 (2017.0.0 20161012.r.53 2016/10/
PNG 18.0.0 - from the file “Standard MultiPlugin”
Pointillize 18.0.0 - from the file “Standard MultiPlugin”
Polar Coordinates 18.0.0 - from the file “Standard MultiPlugin”
Portable Bit Map 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “PBM”
Poster Edges 18.0.0 - from the file “Filter Gallery”
PRC 18.0.0 (2017.0.0 20161012.r.53 2016/10/
Radial Blur 18.0.0 - from the file “Standard MultiPlugin”
Radiance 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Radiance”
Range 18.0.0 (2017.0.0 20161012.r.53 2016/10/
Render Color Lookup Grid NO VERSION - from the file “Export3DLUT”
Reticulation 18.0.0 - from the file “Filter Gallery”
Ripple 18.0.0 - from the file “Standard MultiPlugin”
Rough Pastels 18.0.0 - from the file “Filter Gallery”
Save for Web 18.0.0 - from the file “Save for Web”
ScriptingSupport 18.0.0 - from the file “ScriptingSupport”
Shake Reduction 18.0.0 - from the file “Shake Reduction”
Shear 18.0.0 - from the file “Standard MultiPlugin”
Skewness 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
Smart Blur 18.0.0 - from the file “Standard MultiPlugin”
Smudge Stick 18.0.0 - from the file “Filter Gallery”
Solarize 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Solarize”
Spatter 18.0.0 - from the file “Filter Gallery”
Spherize 18.0.0 - from the file “Standard MultiPlugin”
Sponge 18.0.0 - from the file “Filter Gallery”
Sprayed Strokes 18.0.0 - from the file “Filter Gallery”
Stained Glass 18.0.0 - from the file “Filter Gallery”
Stamp 18.0.0 - from the file “Filter Gallery”
Standard Deviation 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
STL 18.0.0 (2017.0.0 20161012.r.53 2016/10/
Sumi-e 18.0.0 - from the file “Filter Gallery”
Summation 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
Targa 18.0.0 - from the file “Standard MultiPlugin”
Texturizer 18.0.0 - from the file “Filter Gallery”
Tiles 18.0.0 - from the file “Standard MultiPlugin”
Torn Edges 18.0.0 - from the file “Filter Gallery”
Twirl 18.0.0 - from the file “Standard MultiPlugin”
U3D 18.0.0 (2017.0.0 20161012.r.53 2016/10/
Underpainting 18.0.0 - from the file “Filter Gallery”
Vanishing Point 18.0.0 - from the file “VanishingPoint”
Variance 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics”
Virtual Reality Modeling Language | VRML 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D”
Water Paper 18.0.0 - from the file “Filter Gallery”
Watercolor 18.0.0 - from the file “Filter Gallery”
Wave 18.0.0 - from the file “Standard MultiPlugin”
Wavefront|OBJ 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D”
WIA Support 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “WIASupport”
Wind 18.0.0 - from the file “Standard MultiPlugin”
Wireless Bitmap 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “WBMP”
ZigZag 18.0.0 - from the file “Standard MultiPlugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
Recent Files 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.ccx.st
art\index.html”
com.adobe.inapp.purchase 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\c
om.adobe.DesignLibraryPanel.html\purchase.htm
l”
New Document 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.ccx.st
art\fnft.html”
Libraries 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.Design
LibraryPanel.html\index.html”
Start 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.ccx.st
art\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.experimentation.exten
sion\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\c
om.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.photos
hop.crema\PSPanel\dialog.html”
Device Preview 1.3.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com
.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.0 - from the file “C:\Program Files\Common Files\Adobe\CEP
\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
CC2017 on a trial - I don't think so !
If you want to try Photoshop download the current version for trial from Adobe. If you like it beyond 7 days then take out a subscription.
Dave
I still have 5 days left on trial
The problem is that I can use the 3d function, any solution?
Sincerely,
Tomisin.
How did you get a trial version of CC 2017? It is two versions old and not being offered any more.
Sorry - I don't know where you got that from but my advice is the same. Given that CC2017 was replaced in October 2017 a 7 day trial will have run out long ago.
Download the current trial from Adobe. Also please note - 3D features will require a 64 bit operating system.
Dave
Oh that's why, I am using a 32 bits operating system.
Here is my System Info, dont know why my 3D greyed out?
Adobe Photoshop Version: 21.0.2 20191122.r.57 2019/11/22: e3e4068e635 x64 Number of Launches: 213 Operating System: Mac OS 10.14.6 System architecture: Intel CPU Family:6, Model:14, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading Physical processor count: 8 Logical processor count: 16 Processor speed: 3000 MHz Built-in memory: 65536 MB Free memory: 40568 MB Memory available to Photoshop: 61826 MB Memory used by Photoshop: 70 % ACP.local Status: - SDK Version: 1.24.4 - Core Sync Status: Reachable and compatible - Core Sync Running: 4.3.20.55 - Min Core Sync Required: 4.3.4.2 ACPL Cache Config: Unavailable Alias Layers: Disabled. Modifier Palette: Disabled. Highbeam: Disabled. Touch Bar Property Feedback: Enabled. Image tile size: 1024K Image cache levels: 4 Font Preview: Medium TextComposer: Latin OpenCL crashed on 17/6/2019 at 4:06:05 PM (Initializing OpenCL and OpenCL enabled features) Display: 1 Main Display Display Bounds: top=0, left=0, bottom=1440, right=2560 OpenGL Drawing: Enabled. OpenGL Allow Old GPUs: Not Detected. OpenGL Drawing Mode: Advanced OpenGL Allow Normal Mode: True. OpenGL Allow Advanced Mode: True. AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=2
NumNativeGPUs=2
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=6144
glgpu[0].GLName="AMD Radeon HD - FirePro D700 OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRenderer="AMD Radeon HD - FirePro D700 OpenGL Engine"
glgpu[0].GLRendererID=16915457
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Jun 23 2019 21:50:55)"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=6144
clgpu[0].CLName="AMD Radeon HD - FirePro D700 Compute Engine"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915456
clgpu[0].CLDriverVersion="1.2 (Aug 20 2019 17:19:54)"
clgpu[0].CLBandwidth=1.66718e+11
clgpu[0].CLCompute=1233.04
nativegpu[0].NativeName="AMD Radeon HD - FirePro D700"
clgpu[1].CLPlatformVersion="1.2 (Jun 23 2019 21:50:55)"
clgpu[1].CLDeviceVersion="1.2 "
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=6144
clgpu[1].CLName="AMD Radeon HD - FirePro D700 Compute Engine"
clgpu[1].CLVendor="AMD"
clgpu[1].CLVendorID=33692672
clgpu[1].CLDriverVersion="1.2 (Aug 20 2019 17:19:54)"
clgpu[1].CLBandwidth=1.751e+11
clgpu[1].CLCompute=1245.77
nativegpu[1].NativeName="AMD Radeon HD - FirePro D700"
License Type: Subscription Serial number: 94070240545124511174 GUIDBucket:Composite Core (enable_composite_core): onComposite Core GPU (comp_core_gpu): offComposite Core UI (comp_core_ui): offDocument Graph (enable_doc_graph): off Application folder: /Applications/Adobe Photoshop 2020/ Photoshop scratch has async I/O enabled Scratch volume(s): Startup, 894.0G, 498.2G free Required Plug-ins folder: /Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Required/Plug-ins/ Primary Plug-ins folder: /Applications/Adobe Photoshop 2020/Plug-ins/ Installed components: dvametadata.framework dvametadata 12.1.0.0 AdobeXMPScript.framework AdobeXMPScript 79.164036 79.164036 ICUUnicode.framework ICUUnicode gtlib_12.0.23744 ICUConverter.framework ICUConverter gtlib_12.0.23744 AdobeCrashReporter.framework AdobeCrashReporter 7.7.2 boost_system.framework boost_system 12.1.0.0 AdobeACE.framework AdobeACE 2.20.02.45092 97.614776 AdobeOwl.framework AdobeOwl 5.5.0 mediacoreif.framework mediacoreif 12.1.0.0 dvascripting.framework dvascripting 12.1.0.0 dvaappsupport.framework dvaappsupport 12.1.0.0 dvaunittesting.framework dvaunittesting 12.1.0.0 AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.44656 79.613314 k2.framework k2 1 AIDE.framework AIDE 1.5.0.44606 79.613133 dynamiclink.framework dynamiclink 12.1.0.0 dvaaccelerate.framework dvaaccelerate 12.1.0.0 dvametadataUI.framework dvametadataUI 12.1.0.0 AdobeExtendScript.framework AdobeExtendScript 4.5.11.1 82.2 boost_filesystem.framework boost_filesystem 12.1.0.0 AdobeBIB.framework AdobeBIB 1.2.03.44658 79.613319 AdobeXMPFiles.framework AdobeXMPFiles 79.164036 79.164036 AdobeLinguistic.framework 24237 dvaplayer.framework dvaplayer 12.1.0.0 PlugPlugOwl.framework PlugPlugOwl 9.4.0.46 AdobeAGM.framework AdobeAGM 4.30.87.44658 79.613319 adobe_caps.framework adobe_caps 11.0.0.14 1.584361 AdobeSVGRE.framework AdobeSVGRE 6.0 97.614776 AdobePDFL.framework AdobePDFL 15.0.0.44606 79.348578 dvacore.framework dvacore 12.1.0.0 AdobePIP.framework AdobePIP 8.1.0.40.48685 AdobePDFSettings.framework AdobePDFSettings 1.7 AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.44656 79.613314 dvatransport.framework dvatransport 12.1.0.0 Cg.framework NVIDIA Cg AdobeXMP.framework AdobeXMPCore 79.164036 79.164036 AdobeJP2K.framework AdobeJP2K 1.2.2.44568 79.273548 dvaaudiodevice.framework dvaaudiodevice 12.1.0.0 LogSession.framework LogSession 8.1.0.40.48685 PlugPlugExternalObject.framework 9.2.0.46 AdobeScCore.framework AdobeScCore 4.5.11.1 82.2 AdobeSVGAGM.framework AdobeSVGAGM 1.0.45092 97.614776 dvametadataapi.framework dvametadataapi 12.1.0.0 CITThreading.framework WRServices.framework AdobeBIBUtils.framework AdobeBIBUtils 1.1.44658 79.613319 boost_threads.framework boost_threads 12.1.0.0 aif.framework aif 6.0.00.1 1. AdobeCoolType.framework AdobeCoolType 5.17.00.45092 97.614776 dvamediatypes.framework dvamediatypes 12.1.0.0 AdbePM.framework AdbePM 4.0.00.377265 1.613549 boost_date_time.framework boost_date_time 12.1.0.0 dynamic-torqnative.framework Torq Native 1 AdobeMPS.framework AdobeMPS 5.8.1.44729 79.613613 dvaui.framework dvaui 12.1.0.0 ahclient.framework ahclient 4.1.1.0 ICUData.framework ICUData gtlib_12.0.23744 dvamarshal.framework dvamarshal 12.1.0.0 Unified Extensibility Platform uxp-3.3.7.56 Required plug-ins: Accented Edges 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Adaptive Wide Angle 21.0.2, © 2014-2019 Adobe. All rights reserved. - from the file “Adaptive Wide Angle.plugin” Angled Strokes 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Average 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “Average.plugin” Bas Relief 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” BMP 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Camera Raw 12.1 (351), Copyright © 2019 Adobe Systems Incorporated - from the file “Camera Raw.plugin” Camera Raw Filter 12.1 (351), Copyright © 2019 Adobe Systems Incorporated - from the file “Camera Raw.plugin” Chalk & Charcoal 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Charcoal 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Chrome 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Cineon 21.0 © 2002-2019 Adobe. All rights reserved. - from the file “Cineon.plugin” Clouds 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “Clouds.plugin” Color Halftone 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Colored Pencil 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Conté Crayon 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Craquelure 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Crop and Straighten Photos 21.0 © 2003-2019 Adobe. All rights reserved. - from the file “CropPhotosAuto.plugin” Crop and Straighten Photos Filter 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Crosshatch 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Crystallize 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Cutout 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Dark Strokes 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” De-Interlace 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Dicom 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “dicom.plugin” Difference Clouds 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “Clouds.plugin” Diffuse Glow 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Displace 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Dry Brush 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Eazel Acquire 21.0 © 2007-2019 Adobe. All rights reserved. - from the file “EazelAcquire.plugin” Entropy 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Export Color Lookup Tables 21.0 © 2012-2019 Adobe. All rights reserved. - from the file “Export3DLUT.plugin” Extrude 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” FastCore Routines 21.0 © 1990-2019 Adobe. All rights reserved. - from the file “FastCore.plugin” Fibers 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Film Grain 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Filter Gallery 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Fresco 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Glass 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Glowing Edges 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Grain 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Graphic Pen 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Halftone Pattern 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Halide Bottlenecks 21.0 © 2019 Adobe. All rights reserved. - from the file “HalideBottlenecks.plugin” HDRMergeUI 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “HDRMergeUI.plugin” HSB/HSL 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” IFF Format 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” IGES 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “U3D.plugin” Ink Outlines 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” JPEG 2000 21.0 © 2001-2019 Adobe. All rights reserved. - from the file “JPEG2000.plugin” Kurtosis 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Lens Blur 21.0.2, © 2002-2019 Adobe. All rights reserved. - from the file “Lens Blur.plugin” Lens Correction 21.0.2, © 2002-2019 Adobe. All rights reserved. - from the file “Lens Correct.plugin” Lens Flare 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Liquify 21.0.2, © 2001-2019 Adobe. All rights reserved. - from the file “Liquify.plugin” Matlab Operation 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “ChannelPort.plugin” Maximum 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Mean 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Measurement Core 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “MeasurementCore.plugin” Median 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Mezzotint 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Minimum 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” MMXCore Routines 21.0 © 1990-2019 Adobe. All rights reserved. - from the file “MMXCore.plugin” Mosaic Tiles 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Multiprocessor Support 21.0 © 1990-2019 Adobe. All rights reserved. - from the file “MultiProcessor Support.plugin” Neon Glow 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Note Paper 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” NTSC Colors 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “NTSC Colors.plugin” Ocean Ripple 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” OpenEXR 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Paint Daubs 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Palette Knife 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Patchwork 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Paths to Illustrator 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” PCX 21.0 © 1989-2019 Adobe. All rights reserved. - from the file “PCX.plugin” Photocopy 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Picture Package Filter 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “ChannelPort.plugin” Pinch 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Pixar 21.0 © 1989-2019 Adobe. All rights reserved. - from the file “Pixar.plugin” Plaster 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Plastic Wrap 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Pointillize 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Polar Coordinates 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Portable Bit Map 21.0 © 1989-2019 Adobe. All rights reserved. - from the file “PBM.plugin” Poster Edges 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” PRC 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “U3D.plugin” Radial Blur 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Radiance 21.0 © 2003-2019 Adobe. All rights reserved. - from the file “Radiance.plugin” Range 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Render Color Lookup Grid 21.0 © 2012-2019 Adobe. All rights reserved. - from the file “Export3DLUT.plugin” Reticulation 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Ripple 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Rough Pastels 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Save for Web 21.0.2, © 1999-2019 Adobe. All rights reserved. - from the file “Save for Web.plugin” ScriptingSupport 21.0, © 2002-2019 Adobe. All rights reserved. - from the file “ScriptingSupport.plugin” Shake Reduction 21.0.2, © 2014-2019 Adobe. All rights reserved. - from the file “Shake Reduction.plugin” Shear 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Skewness 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Smart Blur 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Smudge Stick 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Solarize 21.0 © 1993-2019 Adobe. All rights reserved. - from the file “Solarize.plugin” Spaces 21.0, © 2015-2019 Adobe. All rights reserved. - from the file “Spaces.plugin” Spatter 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Spherize 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Sponge 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Sprayed Strokes 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Stained Glass 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Stamp 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Standard Deviation 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Sumi-e 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Summation 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Targa 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Texturizer 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Tiles 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Torn Edges 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Twirl 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” U3D 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “U3D.plugin” Underpainting 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Vanishing Point 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “VanishingPoint.plugin” Variance 21.0 © 2006-2019 Adobe. All rights reserved. - from the file “statistics.plugin” Water Paper 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Watercolor 21.0.2, © 1991-2019 Adobe. All rights reserved. - from the file “Filter Gallery.plugin” Wave 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Wind 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Wireless Bitmap 21.0 © 1989-2019 Adobe. All rights reserved. - from the file “WBMP.plugin” ZigZag 21.0.2, © 2003-2019 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin” Optional and third party plug-ins: NONE Duplicate and Disabled plug-ins: NONE Plug-ins that failed to load: NONE Unified Extensibility Platform - Extensions: com.adobe.ccx.start 3.2.0.70 - from the file "/Library/Application Support/Adobe/UXP/extensions/com.adobe.ccx.start-3.2.0/" CDO: 1.62.3
CmdN: 1.2.0
CDP: 1.89.3 Extensions: com.adobe.Butler.backend 2.3.4 - from the file “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html” com.adobe.stock.panel.licensing 0.1.0 - from the file “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Required/CEP/extensions/com.adobe.stock.panel.licensing/index.html” New Document 3.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.fnft-3.0.0/fnft.html?v=3.0.0.4” Libraries 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_6_70/index.html” com.adobe.inapp.typekit.purchase 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_6_70/purchaseTypekit.html” Home 2.9.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.start-2.9.0/index.html?v=2.9.0.47” com.adobe.capture.extension 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_6_70/extensions/capture/capture.html” Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html” Export As 4.8.12 - from the file “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/index.html” Export As 4.8.12 - from the file “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/index.html” Installed TWAIN devices: NONE
Hi Lindsi - for some reason Photoshop is seeing one Open GL GPU and two Open CL GPUs on your system. Multiple GPUs can cause issues with Photoshop. However, given that both appear to be the same card I don't know why this is happening.
I use Windows not Mac so can't advise the next steps in troubleshooting that, but hopefully a Mac user will come along shortly and help you further.
Dave
Adobe Photoshop-versie: 21.0.3 20200115.r.91 2020/01/15: 21f283574f6 x64 Aantal keer gestart: 43 Besturingssysteem: Mac OS 10.13.2 Systeemarchitectuur: Intel CPU-familie:6, Model:6, Stepping:1 met MMX, SSE-integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading Aantal fysieke processors: 4 Aantal logische processors: 8 Snelheid processor: 2300 MHz Ingebouwd geheugen: 8192 MB Beschikbaar geheugen: 3392 MB Hoeveelheid beschikbaar geheugen voor Photoshop: 6247 MB Geheugen in gebruik door Photoshop: 70 % ACP.local Status: - SDK Version: 1.24.4 - Core Sync Status: Bereikbaar en compatibel - Core Sync Running: 4.3.28.24 - Min Core Sync Required: 4.3.4.2 ACPL Cache Config: Aliaslagen: Uitgeschakeld. Wijzigingspalet: Uitgeschakeld. Grootlicht: Ingeschakeld. Touch Bar-eigenschapsfeedback: Uitgeschakeld. Blokgrootte van afbeelding: 1024 kB Niveaus voor afbeeldingscache: 4 Lettertypevoorvertoning: Normaal TextComposer: Latijn Scherm: 1 Hoofdscherm Monitor met hoge DPI Grenzen: boven= 0, links= 0, onder= 900, rechts= 1440 Scherm: 2 Grenzen: boven= 0, links= 1440, onder= 768, rechts= 2720 OpenGL-tekenen: Ingeschakeld. OpenGL-modus Oude GPU's toestaan: Niet gedetecteerd. OpenGL-tekenmodus: Geavanceerd OpenGL-modus Normaal toestaan: Waar. OpenGL-modus Geavanceerd toestaan: Waar. AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLMemoryMB=1536
glgpu[0].GLName="Intel Iris Pro OpenGL Engine"
glgpu[0].GLVendor="Intel Inc."
glgpu[0].GLRenderer="Intel Iris Pro OpenGL Engine"
glgpu[0].GLRendererID=16925954
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:19:43)"
clgpu[0].CLMemoryMB=1536
clgpu[0].CLName="Iris Pro"
clgpu[0].CLVendor="Intel"
clgpu[0].CLVendorID=16925952
clgpu[0].CLDriverVersion="1.2(Nov 9 2017 18:56:36)"
clgpu[0].CLBandwidth=4.48757e+10
clgpu[0].CLCompute=221.338
nativegpu[0].NativeName="Intel Iris Pro Graphics"
Type licentie: Abonnement Serienummer: 90970024681417596370 GUIDBucket:Composite Core (enable_composite_core): onComposite Core GPU (comp_core_gpu): offComposite Core UI (comp_core_ui): offDocument Graph (enable_doc_graph): off Toepassingsmap: /Applications/Adobe Photoshop 2020/ Werkgeheugen van Photoshop heeft asynchrone I/O ingeschakeld Werkvolume(s): Start, 233,6 GB, 30,9 GB vrij Map met vereiste plug-ins: /Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/PlugIns/Required/ Primaire map voor plug-ins: /Applications/Adobe Photoshop 2020/Plug-ins/ Geïnstalleerde componenten: dvametadata.framework dvametadata 12.1.0.0 AdobeXMPScript.framework AdobeXMPScript 79.164036 79.164036 ICUUnicode.framework ICUUnicode gtlib_12.0.23744 ICUConverter.framework ICUConverter gtlib_12.0.23744 AdobeCrashReporter.framework AdobeCrashReporter 7.7.2 boost_system.framework boost_system 12.1.0.0 AdobeACE.framework AdobeACE 2.20.02.45092 97.614776 AdobeOwl.framework AdobeOwl 5.5.0 mediacoreif.framework mediacoreif 12.1.0.0 dvascripting.framework dvascripting 12.1.0.0 dvaappsupport.framework dvaappsupport 12.1.0.0 dvaunittesting.framework dvaunittesting 12.1.0.0 AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.44656 79.613314 k2.framework k2 1 AIDE.framework AIDE 1.5.0.44606 79.613133 dynamiclink.framework dynamiclink 12.1.0.0 dvaaccelerate.framework dvaaccelerate 12.1.0.0 dvametadataUI.framework dvametadataUI 12.1.0.0 AdobeExtendScript.framework AdobeExtendScript 4.5.11.1 82.2 boost_filesystem.framework boost_filesystem 12.1.0.0 AdobeBIB.framework AdobeBIB 1.2.03.44658 79.613319 AdobeXMPFiles.framework AdobeXMPFiles 79.164036 79.164036 AdobeLinguistic.framework 24237 dvaplayer.framework dvaplayer 12.1.0.0 PlugPlugOwl.framework PlugPlugOwl 9.4.0.46 AdobeAGM.framework AdobeAGM 4.30.87.44658 79.613319 adobe_caps.framework adobe_caps 11.0.0.14 1.584361 AdobeSVGRE.framework AdobeSVGRE 6.0 97.614776 AdobePDFL.framework AdobePDFL 15.0.0.44606 79.348578 dvacore.framework dvacore 12.1.0.0 AdobePIP.framework AdobePIP 8.1.0.40.48685 AdobePDFSettings.framework AdobePDFSettings 1.7 AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.44656 79.613314 dvatransport.framework dvatransport 12.1.0.0 AdobeXMP.framework AdobeXMPCore 79.164036 79.164036 AdobeJP2K.framework AdobeJP2K 1.2.2.44568 79.273548 dvaaudiodevice.framework dvaaudiodevice 12.1.0.0 LogSession.framework LogSession 8.1.0.40.48685 PlugPlugExternalObject.framework 9.2.0.46 AdobeScCore.framework AdobeScCore 4.5.11.1 82.2 AdobeSVGAGM.framework AdobeSVGAGM 1.0.45092 97.614776 dvametadataapi.framework dvametadataapi 12.1.0.0 CITThreading.framework WRServices.framework AdobeBIBUtils.framework AdobeBIBUtils 1.1.44658 79.613319 boost_threads.framework boost_threads 12.1.0.0 aif.framework aif 6.0.00.1 1. AdobeCoolType.framework AdobeCoolType 5.17.00.45092 97.614776 dvamediatypes.framework dvamediatypes 12.1.0.0 AdbePM.framework AdbePM 4.0.00.377265 1.613549 boost_date_time.framework boost_date_time 12.1.0.0 dynamic-torqnative.framework Torq Native 1 AdobeMPS.framework AdobeMPS 5.8.1.44729 79.613613 dvaui.framework dvaui 12.1.0.0 ahclient.framework ahclient 4.1.1.0 ICUData.framework ICUData gtlib_12.0.23744 dvamarshal.framework dvamarshal 12.1.0.0 Unified Extensibility Platform uxp-3.3.7.56 Vereiste plug-ins: Adaptief groothoek 21.0.3, © 2014-2019 Adobe. All rights reserved. - van het bestand “Adaptive Wide Angle.plugin” Andere wolken 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “Clouds.plugin” Arcering 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Asymmetrisch 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Basreliëf 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Bereik 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” BMP 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Bol 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Camera Raw 12.2 (386), Copyright © 2020 Adobe Systems Incorporated - van het bestand “Camera Raw.plugin” Camera Raw-filter 12.2 (386), Copyright © 2020 Adobe Systems Incorporated - van het bestand “Camera Raw.plugin” Chroom 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Cineon 21.0 © 2002-2019 Adobe. All rights reserved. - van het bestand “Cineon.plugin” Conté crayon 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Craquelure 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” De-Interlace 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Dicom 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “dicom.plugin” Diffuse gloed 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Donkere lijnen 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Droog penseel 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Eazel Acquire 21.0 © 2007-2019 Adobe. All rights reserved. - van het bestand “EazelAcquire.plugin” Entropie 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” FastCore Routines 21.0 © 1990-2019 Adobe. All rights reserved. - van het bestand “FastCore.plugin” Filigraan 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Filmkorrel 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Filter Figuurpakket 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “ChannelPort.plugin” Filter Foto's uitsnijden en rechttrekken 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Filtergalerie 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Foto's uitsnijden en rechttrekken 21.0 © 2003-2019 Adobe. All rights reserved. - van het bestand “CropPhotosAuto.plugin” Fotokopie 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Fresco 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Geaccentueerde randen 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Gebrandschilderd glas 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Geef diepte 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Gemiddelde 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “Average.plugin” Gescheurde randen 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Gips 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Glas 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Golf 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Grafische pen 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Halftoonraster 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Halide Bottlenecks 21.0 © 2019 Adobe. All rights reserved. - van het bestand “HalideBottlenecks.plugin” HDRMergeUI 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “HDRMergeUI.plugin” Hoeklijn 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Houtskool 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” HSB/HSL 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” IFF-formaat 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” IGES 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “U3D.plugin” Inktomtrek 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” JPEG 2000 21.0 © 2001-2019 Adobe. All rights reserved. - van het bestand “JPEG2000.plugin” Kleur halftoon 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Kleur-opzoektabellen exporteren 21.0 © 2012-2019 Adobe. All rights reserved. - van het bestand “Export3DLUT.plugin” Kleurpotlood 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Klodder 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Kneep 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Knipsel 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Korrel 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Krijt en houtskool 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Kristal 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Kronkel 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Lappendeken 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Lenscorrectie 21.0.3, © 2002-2019 Adobe. All rights reserved. - van het bestand “Lens Correct.plugin” Matlab Operation 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “ChannelPort.plugin” Maximaal 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Mediaan 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Metingskern 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “MeasurementCore.plugin” Mezzotint 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Minimaal 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” MMXCore-routines 21.0 © 1990-2019 Adobe. All rights reserved. - van het bestand “MMXCore.plugin” Moyenne 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Mozaïektegels 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Neon gloed 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” NTSC-kleuren 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “NTSC Colors.plugin” Oceaanrimpel 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Ondersteuning van meerdere processors 21.0 © 1990-2019 Adobe. All rights reserved. - van het bestand “MultiProcessor Support.plugin” OpenEXR 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Oplichtende rand 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Opslaan voor web 21.0.3, © 1999-2019 Adobe. All rights reserved. - van het bestand “Save for Web.plugin” Optelling 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Paden naar Illustrator 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Paletmes 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” PCX 21.0 © 1989-2019 Adobe. All rights reserved. - van het bestand “PCX.plugin” Perspectiefpunt 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “VanishingPoint.plugin” Pixar 21.0 © 1989-2019 Adobe. All rights reserved. - van het bestand “Pixar.plugin” Plastic 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Pointilleren 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Poolcoördinaten 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Portable Bit Map 21.0 © 1989-2019 Adobe. All rights reserved. - van het bestand “PBM.plugin” Posterranden 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Postpapier 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” PRC 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “U3D.plugin” Radiaal vaag 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Radiance 21.0 © 2003-2019 Adobe. All rights reserved. - van het bestand “Radiance.plugin” Raster Kleur opzoeken renderen 21.0 © 2012-2019 Adobe. All rights reserved. - van het bestand “Export3DLUT.plugin” Rimpel 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Ruw pastel 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Schokreductie 21.0.3, © 2014-2019 Adobe. All rights reserved. - van het bestand “Shake Reduction.plugin” Schuin 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Scriptondersteuning 21.0, © 2002-2019 Adobe. All rights reserved. - van het bestand “ScriptingSupport.plugin” Slim vervagen 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Solariseren 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “Solarize.plugin” Spaces 21.0, © 2015-2019 Adobe. All rights reserved. - van het bestand “Spaces.plugin” Spetters 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Spons 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Sproeilijn 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Standaardafwijking 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Stempel 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Structuurmaker 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Sumi-e 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Targa 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Tegels 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” U3D 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “U3D.plugin” Uitvloeien 21.0.3, © 2001-2019 Adobe. All rights reserved. - van het bestand “Liquify.plugin” Vage lens 21.0.3, © 2002-2019 Adobe. All rights reserved. - van het bestand “Lens Blur.plugin” Variantie 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Verplaatsen 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Vezels 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Vlek 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Voorbewerking 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Waterpapier 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Waterverf 21.0.3, © 1991-2019 Adobe. All rights reserved. - van het bestand “Filter Gallery.plugin” Welving 21.0 © 2006-2019 Adobe. All rights reserved. - van het bestand “statistics.plugin” Wind 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Wireless Bitmap 21.0 © 1989-2019 Adobe. All rights reserved. - van het bestand “WBMP.plugin” Wolken 21.0 © 1993-2019 Adobe. All rights reserved. - van het bestand “Clouds.plugin” ZigZag 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Zon 21.0.3, © 2003-2019 Adobe. All rights reserved. - van het bestand “Standard Multiplugin.plugin” Optionele plug-ins en plug-ins van derden: GEEN Identieke en uitgeschakelde plug-ins: GEEN Plug-ins die niet konden worden geladen: GEEN Unified Extensibility Platform – Extensies: com.adobe.ccx.start 3.2.0.70 – uit bestand "/Library/Application Support/Adobe/UXP/extensions/com.adobe.ccx.start-3.2.0/" CDO: 1.62.3
CmdN: 1.2.0
CDP: 1.89.3 Extensies: com.adobe.Butler.backend 2.3.4 - uit het bestand “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Resources/CEP/extensions/com.adobe.Butler.backend/index.html” com.adobe.stock.panel.licensing 0.1.0 - uit het bestand “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Resources/CEP/extensions/com.adobe.stock.panel.licensing/index.html” Nieuw document 3.1.0 - uit het bestand “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.fnft-3.1.0/fnft.html?v=3.1.0.12” Bibliotheken 1.0.0 - uit het bestand “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_7_76/index.html” com.adobe.inapp.typekit.purchase 1.0.0 - uit het bestand “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_7_76/purchaseTypekit.html” Start 2.10.0 - uit het bestand “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.start-2.10.0/index.html?v=2.10.0.21” com.adobe.capture.extension 1.0.0 - uit het bestand “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_7_76/extensions/capture/capture.html” Adobe Color-thema's 6.1.0 - uit het bestand “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Resources/CEP/extensions/com.adobe.KulerPanel.html/index.html” Exporteren als 4.8.12 - uit het bestand “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Resources/CEP/extensions/com.adobe.photoshop.crema/index.html” Exporteren als 4.8.12 - uit het bestand “/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app/Contents/Resources/CEP/extensions/com.adobe.photoshop.crema/index.html” Geïnstalleerde TWAIN-apparaten: GEEN
