I've been rendering out 360 videos in the past few weeks and occasionally I've been getting these weird glitching videos on the output. In premiere it plays back fine ( with proxy switching) so I reckon it's something happening in the render. I've recently updated my graphics drivers, and still the same problem. Here're my computer specs:
OS Name Microsoft Windows 10 Pro
Version 10.0.17134 Build 17134
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name APONE
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
System SKU SKU
Processor AMD Ryzen 7 1800X Eight-Core Processor, 3600 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1201, 9/05/2017
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume3
Locale Australia
Hardware Abstraction Layer Version = "10.0.17134.1"
Username APONE\EDIT02
Time Zone AUS Eastern Standard Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 22.8 GB
Total Virtual Memory 50.9 GB
Available Virtual Memory 33.7 GB
Page File Space 19.0 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and the device is not InstantGo, Un-allowed DMA-capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
Display:
Name NVIDIA Quadro P4000
PNP Device ID PCI\VEN_10DE&DEV_1BB1&SUBSYS_11A310DE&REV_A1\4&1DA95F35&0&0019
Adapter Type Quadro P4000, NVIDIA compatible
Adapter Description NVIDIA Quadro P4000
Adapter RAM (1,048,576) bytes
Here's an unlisted example of the video on youtube Legacy Sydney BeachPoemShot58 graded - YouTube
p.s just tried to render out a section with software only playback engine to bypass the video card but still got the stuttering
There are a couple other threads of recent posting with this type of issue ... stuttering due to repeated frames. Search for them here and over on the UserVoice system ...
Adobe Bug /Feature service: https://adobe-video.uservoice.com/forums/911233-premiere-pro
A typical first attempt at a problem like this is to find where your cache/cache database files are located on disc in your Preferences dialog, close PrPro, and go delete everything in those folders. Reboot & see if things improve.
Neil
Hi there thanks for the reply, I'll check out those threads. Whenever we render anything at the office we clean the cache on the particular computer we're on.
Calum Wakeling
Head of Audio
[Personal information removed by moderator.]
Also could you link me to these specific discussions I can't find them. Cheers
Calum Wakeling
Head of Audio
Put stutter in the search box on this forum, there's a fair number of threads to look through. Only a couple at the moment on the UserVoice ... I think this needs more mention over there, so ... add in over there, make a new one or add on to the couple that pop up with "stutter" in the search box.
Neil
https://adobe-video.uservoice.com/search?filter=merged&query=stutter . None of these cover my problem
Calum Wakeling
Head of Audio
Did you search this forum?
Neil
Yes I have, I can't find anything. If you've found some could you link them to me?
Just type "stutter" in the forum's search bar ... too many to link.
Neil
Yep I've done that. None of those threads relate to my problem.
All of these stutter threads are talking about playback stutter within Premiere or issues pertaining to Mac specific issues. I said in my initial post "I've been rendering out 360 videos in the past few weeks and occasionally I've been getting these weird glitching videos on the output. In premiere it plays back fine ( with proxy switching) so I reckon it's something happening in the render. I've recently updated my graphics drivers, and still the same problem."
Where do I go to actually get support for the problem I'm having? After a full day on live chat from Adobe they led me here. Now here I'm told to search the forum...
Several threads I've seen had the repeat-frame problems in exports.
It's not a common thing, very small group getting it. So that makes getting a perfect answer all the more difficult. Which is a darn frustrating thing for you, understood.
I can't replicate, neither can most users, which means probably the developers are having trouble doing so.
Which is even worse.
It is very important that you post your issue with that sample and your direct details on the UserVoice system. That goes directly to the development team for perusal. The more data they get, the quicker they can get at something.
Neil
Ok, I have searched, using stutter, repeated frames, jitter etc. I can't find anything like my problem, please send me a direct link to these threads you're talking about!
Those are links just to the forums...
calumw20207515 wrote
Calum Wakeling
Head of Audio
Please do not include phone numbers, websites, email, and other business or personal information. Please do not use a signature when posting in the forum.
