If I have more than one document open and go to full screen view, when I try to return to the normal interface it has been "enlarged" as though it's on a larger screen and menus, tabs and other controls are hidden off-screen. Nothing I can do except quit and start over. WTF? Anyone know how to fix it so I can have more than one doc open and use full screen view. The way it is now, as soon as I finish looking at one doc in full screen view, none of the tabs for other docs can be selected because they are all off-screen.
As per the issue description mentioned above, you are facing issue when exiting full-screen view in Acrobat, is that correct?
Check if an update is available for Acrobat using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again. If that doesn't work, try resetting preferences for Acrobat using the steps given in this link: How to reset Acrobat Preference settings to default. reboot the machine after resetting preferences and try again.
Also, let us know dot version of Acrobat and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Let us know if you need any help.
Shivam
