Hello!
I have an index reference, and I would like to apply the Character Style Italic to all individual letter g . The letter g means glosary.
Is a big risk, please can you help me to config a secure GREP?
EXAMPLES:
human beings g
human beings 3, 13, 78, g
human beings g (See also human)
human beings 2, 6, 89, g (See also human, beings)
MY SCRIPT:
var myDoc = app.activeDocument,
myCodes = ["g"], C = myCodes.length, c;
app.findTextPreferences = null;
for ( c = 0; c < C; c++) {
app.findTextPreferences.findWhat = myCodes
; myFound = myDoc.findText();
var F = myFound.length, f;
for ( f = 0; f < F; f++) {
myFound
.appliedCharacterStyle = myDoc.characterStyles[0]; myFound
.appliedCharacterStyle = 'Italic'; }
thanks so much!
The reason why your expressions don't work (or not correctly) is that you have several unescaped backslashes in the search strings.
But you make things very complicated. Try this:
Find: " +(\\d[–\\d, ]*\\d?) *"
Change to: $1
Simply search for g whole-word only and case-sensitive.
but if I do this, the script will apply also the Italic to the words like:
beings
and it is not correct. Also will be nice to use a script because I have 15 script to apply.
That's why you should do whole-word only. In Grep: "\\bg\\b"
P.
is not working.
I need to use 2 script.jsx one with this:
myCodes = [" g "], C = myCodes.length, c;
and other with:
myCodes = ["g\r"], C = myCodes.length, c;
Look for "\\sg\\s"
\s covers any space, incuding \r.
Again, get yourself a good book on GREP.
same problem.
thanks for the advice, I am training but are many things to know.
For memory, I think Peter Kahrel wrote a book on Grep professionals consider as "the" reference!
Best,
Michel
HI Michel!
Please, give me the book name or link.
I take this opportunity, why you or Petter no create a deep course in Udemy.com?
Thanks for mentioning that title, Michel. It's actually out of print at the moment, but a new edition will be published soon by InDesignSecrets.
P.
Just what I needed.
I look forward to buying it.
Thanks so much!
finally, I finish the script. I hope will be useful to someone.
PROTOCOL FOR THE INDEX:
human beings(s)
human beings(s)
human beings(s) g
human being(s) g
human beings(s) (See human)
human beings(s) g (See human)
human beings(s) (See also human, beings)
human beings(s) 3, 13, 78
human beings(s) 134–136
human/beings(s) 3, 13, 78
human beings(s) 3, 13, 78, g
human beings(s) 3, 13, 78, g (See human)
human beings(s) 8, g (See human)
human beings(s) 3, 13, 78 (See human)
human beings(s) 8 (See human)
INDESIGN INDEX OPTIONS:
SCRIPT 0: BATCH TO RUN ALL YOUR SCRIPTS:
// http://www.rorohiko.com/wordpress/batch-textexport/
// https://www.indesignjs.de/extendscriptAPI/indesign-latest/#ScriptPreference.html
var thisScript = new File($.fileName);
var containingFolder = new Folder(thisScript.parent.absoluteURI);
//alert("This script is in " + containingFolder.absoluteURI);
var path = containingFolder.absoluteURI;
var appFolder = new Folder(Folder.appPackage.parent.absoluteURI);
//alert("The app folder is at " + Folder.decode(appFolder.absoluteURI));
function batch()
var f1 = File ( path+"/script1.jsx" );
var f1 = File ( path+"/script2.jsx" );
var f1 = File ( path+"/script3.jsx" );
var f1 = File ( path+"/script4.jsx" );
var f1 = File ( path+"/script5.jsx" );
var f1 = File ( path+"/script6.jsx" );
var f1 = File ( path+"/script7.jsx" );
var f1 = File ( path+"/script8.jsx" );
app.doScript ( f1 );
app.doScript ( f2 );
app.doScript ( f3 );
app.doScript ( f4 );
app.doScript ( f5 );
app.doScript ( f6 );
app.doScript ( f7 );
app.doScript ( f8 );
batch();
SCRIPT 1: FIX GENERAL ERRORS
replaceTextUsingGREP ("~>"," ");
replaceTextUsingGREP ("~S"," ");
replaceTextUsingGREP ("~|"," ");
replaceTextUsingGREP ("~3"," ");
replaceTextUsingGREP ("~4"," ");
replaceTextUsingGREP ("~%"," ");
replaceTextUsingGREP ("~f"," ");
replaceTextUsingGREP ("\\s+?/\\s+?","/");
function replaceTextUsingGREP (input, output) {
app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
app.findGrepPreferences.findWhat = input;
app.changeGrepPreferences.changeTo = output;
//app.activeDocument.changeGrep();
var changedResults = app.activeDocument.changeGrep();
SCRIPT 2: FIX ERROR PAGE NUMBERS
var IndexEntryOneWord = "(\^\[\\l\\u\]+?)";
var IndexEntryMultiplesWords = "(\^\[\\l\\u\]+?\\s\[\\l\\u\]+?)";
var type = "((\\(([\\l\\u\])+?\\))?)";
var firstSpace = "\\s+?";
var firstNumberPage = "(\\d+?)";
var nextNumberPage = "(((,\\s\\d+?)+?)?)";
var nextSpace = "((\\s+?)?)";
var endParagraph = "\$";
replaceTextUsingGREP ( //human(s)·20,·7..| --> human(s)··20,·7|
IndexEntryOneWord+
type+
firstSpace+
firstNumberPage+
nextNumberPage+
nextSpace+
endParagraph,
"$1$2\\s\\s$5$6");
replaceTextUsingGREP ( //human beings(s)·20,·7..| --> human beings(s)··20,·7|
IndexEntryMultiplesWords+
type+
firstSpace+
firstNumberPage+
nextNumberPage+
nextSpace+
endParagraph,
"$1$2\\s\\s$5$6");
SCRIPT 3: FIX ERROR SPACES
replaceTextUsingGREP (", g \r",", g\r");
replaceTextUsingGREP (" / ","/");
SCRIPT 4: FIX LATIN CHARACTERS
replaceTextUsingGREP ("√°","á");
replaceTextUsingGREP ("√Å","Á");
replaceTextUsingGREP ("√©","é");
replaceTextUsingGREP ("√â","É");
replaceTextUsingGREP ("√≠","í");
replaceTextUsingGREP ("√ç","Í");
replaceTextUsingGREP ("√≥","ó");
replaceTextUsingGREP ("√ì","Ó");
replaceTextUsingGREP ("√∫","ú");
replaceTextUsingGREP ("√ö","Ú");
replaceTextUsingGREP ("√±","ñ");
replaceTextUsingGREP ("√ë","Ñ");
SCRIPT 5: FIX THE LETTER G INDICATE THE GLOSARY
var glosary = "(,?\\s+?g)";
var glosaryWithoutPageNumbers = "(g)";
replaceTextUsingGREP ( //human(s)·20,·7, g..| --> human(s)··20,·7,·g|
IndexEntryOneWord+
type+
firstSpace+
firstNumberPage+
nextNumberPage+
glosary+
nextSpace+
endParagraph,
"$1$2\\s\\s$5$6,\\sg");
replaceTextUsingGREP ( //human beings(s)·20,·7, g..| --> human beings(s)··20,·7,·g|
type+
firstSpace+
firstNumberPage+
nextNumberPage+
glosary+
nextSpace+
endParagraph,
replaceTextUsingGREP ( //human(s)·g..| --> human(s)··g|
IndexEntryOneWord+
type+
firstSpace+
glosaryWithoutPageNumbers+
nextSpace+
endParagraph,
"$1$2\\s\\sg");
replaceTextUsingGREP ( //human beings(s)·g..| --> human beings(s)··g|
type+
firstSpace+
nextSpace+
endParagraph,
"$1$2\\s\\sg");
SCRIPT 6: FIX ERRORS CROSS REFERENCES
var nextSpace1 = "(\\s+?)";
var crossReference = "(?=\\(véa)";
replaceTextUsingGREP ( //human beings(s)·20,·7·(véase person)..| --> //human beings(s)· 20,·7·(véase person)|
IndexEntryOneWord+
type+
firstSpace+
firstNumberPage+
nextNumberPage+
nextSpace1+
crossReference,
"$1$2\\s\\s$5$6\\s");
replaceTextUsingGREP ( //human(s)·20,·7·(véase person)..| --> //human(s)· 20,·7·(véase person)|
type+
firstSpace+
firstNumberPage+
nextNumberPage+
nextSpace1+
crossReference,
replaceTextUsingGREP ( //human beings(s)·(véase person)..| --> //human beings(s)··(véase person)|
IndexEntryOneWord+
type+
firstSpace+
crossReference,
"$1$2\\s\\s");
replaceTextUsingGREP ( //human(s)·(véase person)..| --> //human(s)··(véase person)|
type+
firstSpace+
crossReference,
"$1$2\\s\\s");
SCRIPT 7: CLEAN OVERRIDES
// Clear All Overrides
// Written by TAW. (c) 2014 by Bookraft Solutions, Israel (Id-Extras.com)
// Please do not delete this copyright notice.
var myOverrideType = OverrideType.ALL;
// var myOverrideType = OverrideType.CHARACTER_ONLY;
// var myOverrideType = OverrideType.PARAGRAPH_ONLY;
var allStories = app.activeDocument.stories.everyItem();
// Remove overrides from all stories
try{
allStories.clearOverrides(myOverrideType);
catch (e){
//alert ("No stories!")
// Remove overrides from all footnotes
try{
allStories.footnotes.everyItem().texts.everyItem().clearOverrides(myOverrideType);
catch (e){
//alert ("No footnotes!")
// Remove overrides from all table
try{
allStories.tables.everyItem().cells.everyItem().paragraphs.everyItem().clearOverrides(myOverrideType);
catch (e){
//alert ("No tables!")
//alert("Overrides cleared!");
SCRIPT 8: APPLY ITALIC TO THE LETTER G OF GLOSARY
myCodes = [" g\r"], C = myCodes.length, c;
myFound
Thanks, Peter and Michele.
I had some issues with the range numbers. Please, some help?
Really are patter combination is possible, but here are the most cases (the dot means SPACE and the vertical bar the END OF PARAGRAPH 😞
human··17··|
human·17··|
human··17,·56,·56··|
human···17,·18–21,·56······|
human··17–21,·56,·61··|
human·17–21,·56–61······|
human·17–21,·56–61,·660······|
I expect:
human··17|
human··17|
human··17,·56,·56|
human··17,·18–21,·56|
human··17–21,·56,·61|
human··17–21,·56–61|
human··17–21,·56–61,·660|
But the result is (in color red the erros):
human··17|
human··17|
human··17,·56,·56|
human··17–21–21,·56,·56|
Here my script:
var dash = "((\~\=\\d+?)?)";
IndexEntryOneWord+
type+
firstSpace+
firstNumberPage+
dash+
nextNumberPage+
nextNumberPage+
nextSpace+
endParagraph,
"$1$2\\s\\s$5$6$7$8$9");
Thanks you.
Change to: $1
amazing Peter!
finally based in your example I did this for the cross-references:
INCORRECT:
human·g·|
human·17, g (See also person)··|
human·17,·18–21,·(See person)·|
CORRECT:
human··g|
human··17, g|
human··17, g (See also person)|
human··17,·18–21,·(See person)|
THE SCRIPT:
replaceTextUsingGREP (" +(\\d[–\\d, ]*\\d?) *", "\\s\\s$1"); // numbers
replaceTextUsingGREP (" +([g\\(véa*])","\\s\\s$1");
replaceTextUsingGREP (" +(g)(\\(véa*)","\\s\\s$1\\s$2");
replaceTextUsingGREP ("\\s+\\r", "\\r");
replaceTextUsingGREP (",\\s\\sg",",\\sg");
replaceTextUsingGREP ("(,\\sg\\s)\\s(\\(véa*)","$1$2");
replaceTextUsingGREP ("(\\d\\s)\\s","$1");
Thanks a lot!
P.
How does an ebook go out of print?
I'm just showing my age! The epub is in fact still available from O'Reilly, the PDF is not.
An updated edition of the PDF and a new Epub will be available from InDesignSecrets soon.
P.
