Ok, this is weird. If I have a selection and try Alt+backspace to fill, I get a beep notification, no error pop up or anything. If I press backspace again immediately, it works.
I basically have to double press backspace for it to work properly, plus I get an annoying beep. Any advice?
My keyboard is not the problem, I checked with both alt keys and with other keyboard.
I already closed Photoshop several times, the problem persists.
Ps. is there an "event listener" or something that can display what the beep is trying to tell?
Hi All,
This issue is resolved in Photoshop 19.0.1.
Please update Photoshop from Creative Cloud desktop app. If you do not see the update available, check for the update manually, From the Creative Cloud desktop app gear menu, choose Check for App Updates.
Thanks all for your patience.
Akash
This is a know problem, that Adobe knows about. When they fix it is another matter. For now, you just have to keep pressing twice.
Great Is that a cc 2018 issue ?
Hi All,
Akash
I see this also on Windows 10 Photoshop CC 2018. CC 2014 works correctly I suggest using CC 2014.
There are reported CC 2018 problems with the Alt key. Photoshop Family Customer Community
I believe so, and I have a feeling it might be fixed pretty quickly, as there have been a lot of comments on it.
@andresl38083298 It's Not any photoshop bug or any version problem,
& there is no Need to update photoshop,
I also have same problem in my photoshop so after lots of struggle & research i found this solution.
Just set your windows language to "English US"
Control Panel > Clock, language & Region > Language > Add English US OR Choose Make Primary Language.
Thats It
do it & tell me It works or not...
My windows language was never set to anything else than English US, but still I had that bug. BUT:
Updating PS fixed it!!
I was skeptical at first, but the latest update really did fix that issue.
I have installed all versions, but problem remaining same.
