Premiere pro either crashes or gives me blue screen every time I try to to export anything. My project is a 300mb 5 minute video. I've read just about every thread on this issue and have not found a solution. These are all I've tried:
- changing the format to something less intensive like from h264 to .avi
- Tried different sequences
- Tried changing name of output file
- tried changing the video renderer from CUDA to software
- tried rolling back to previous versions of Premiere pro.
My friend pointed out that my fans go crazy when my computer shuts down which may be pointing at a psu issue so I've upgraded my psu from 750w to 1000w; still no fix. What is wrong?? AME crashes also, so is it my computer? I can't imagine so as I'm able to render the project just fine. The only thing I'm contemplating at this time would a be a clean install of windows but I'm not even entirely sure if that will work either.
Blue screen usually means hardware issue.
I recently had a few bsod and graphics card driver crashes.
Turned out a power connector was not connecting properly.
Might want to check the rest of your hardware.
Do not the log files tell you anything?
Hi ann, i'll go ahead and give that a try and update you. AME log does give me error code: -1609629695 but I can't find anything on the web pertaining to it
No I mean windows log when it crashes/bsod.
it gives me "attempted execute of noexecute memory". I've took everything apart, blew some dust out and reattached everything. so far, computer has not crashed but I can't say the same for premiere and AME
What does Windows Event Viewer say about the crashes?
Fault bucket , type 0
Event Name: BlueScreen
Response: Not available
Cab Id: 0
Problem signature:
P1: a
P2: 80050039
P3: 2
P4: 1
P5: fffff8003bc2e0f9
P6: 10_0_17134
P7: 0_0
P8: 256_1
P9:
P10:
Look for the data in that red square, the Faulting Module and Exception Code.
It just gives me that when i get the bsod. there's no event logs when premiere crashes
