Hi. I've got a problem with my Jotform thats' embedded in an iframe into a Muse website, it does not work right viewed through the website, but in the Jotform builder view it's fine. So Jotform says it's something t wrong with the site:
Does someone know what I should do about this?
How exactly did you upload the homepage data to the server?
And what makes you think, that the error is related to a Jotform from?
Are there any third party widgets involved on your site?
Did you try to use the jotform code in a newly created document?
Did you use the correct code snippet? You find it in the JotForm tab „Publish“ of your form in the „Embed“ section. Just try the first entry there called „Embed“.
yes I've done that, the form works, except form one item in the form, so I imidiatly thought it was something within jot form to fix, but then they checked may site and found the Syntax Error, which I don't know how to solve:)
Could you give us a link to the page with this form?
I had embedded a jotform in my muse site, now I have turned it into a link to the instead, so problem solved, although in another way that I planned.
