new Robohelp file extensions...
Mar 10, 2009 Mar 10, 2009
Hello,
I am using RoboHelp X5.0.1 & when I was checking some files back into source control, I noticed 6 new file extensions that had been checked out and have not checked back in.
I'm wondering if anyone knows what they are for and if they are important to keep in the project?
.hha
.trb
.trf
.trk
.trl
.trs
Any information would be greatly appreciated.
many thanks, in advance
Maxine
1.6K
Hi Maxine.
Does your project contain ant AutoCad files or output because I suspect these files are related to that.
Mar 11, 2009 Mar 11, 2009
Hi Colum,
Thankyou for getting back to me - your question made me start thinking about what might be different in this help file & I remembered that when I updated the files this time, I added in some Image Maps to some of the main screen shots, so could these have caused these new file extensions?
many thanks for your help!
Maxine
I don't think these files have anything to do with image maps maxine. To be honest I'm not a big user of image maps but I've gone back into one of my projects that uses them and I can't find these file extensions anywhere. Out of interest, do these files show up in the "Unused Files" report?
Advisor ,
Google ".trk" and it helpfully fills in ".trk file extension." Click the first search result and see the dozen-or-so uses of the file extension, none of which are related to RoboHelp (Garmin maps, Kermit scripts, WAV files, etc.).
Seems like your issue might be map images (directional maps, not hyperlink maps).
Good luck,
Leon
Mar 12, 2009 Mar 12, 2009
Hello, Colum, I just ran the Unused files report - no they don't show up there - nor do they show up on the Used files report!! ?
Leon, I also did a google search & found similar references - I don't know - am at a bit of a loss, but they don't appear to be affecting my generated files at all, so I think I'll just leave them there.
thankyou all for your help!
regards
Maxine
Hi Maxine.
If the files were checked out but were not checked in after your updates, I guess you are right. Whatever was done during the edits removed any reference to these files. To be on the safe side, you could always use a find tool to search through all your source files for a reference to these new file extensions.
Me again. I've had another thought which is dangerous for this time of the afternoon! If you check out the project, delete the projectname.cpd file, open and compile the project and then run the Unused Files report, do the new files show up?
Mar 17, 2009 Mar 17, 2009
Hi Colum, thankyou - I tried deleting the .cpd & recompiling then running the Unused Files report, but they still don't show up - will try the general search for the files & see if they show up!
regards
Maxine
I see these extensions in a RH8 project. They contain various bits of information that can be read by opening them in a text editor.
Maybe the project has been opened in RH8.
Apr 29, 2009 Apr 29, 2009
Hi..i remembered having seen all the extensions somewhere...so i just played around and noticed that these files are generated temporarily during the time when a Webhelp is being generated.
After compiling the Robohelp webhelp you get a dialog with View Result | Publish | Done | Help...
Till such point as time as you click any one of these options, the files are available in your folder.
After clicking on any one of these buttons, the files will automatically be deleted.
So, I presume, you had added these files to ur source control before closing the "Generating Webhelp" dialog.
I hope this solution is helpful....
RoboHelp Documentation
Download Adobe RoboHelp
