Hello all!
I am trying to export two videos for indoor advertisement screen, I need them to be in an unusual aspect ratio: one of them needs to be 7680х1080 (64:9), the other one 11520х1080 (32:3).
I changed sequence settings to appropriate aspect ratio, everything seems to be right. When I am exporting, resolution changes automatically to 4096x1080, even when I uncheck "match source" and change it to 7680, it changes back to 4096 immediately.
Please help!
Looks like you can do both:
The export format needs to be able to handle the resolution. I don't know if you'll get that with H.264.
What format should I use then? Please advise.
The first one is doable with H.265.
The second one I have no idea.
The question is, how to do it when it changes automatically when I try to export.
Uncheck the chain and set it manually.
Thank you, your screenshot solved my problem!
You'll need to find out what formats the advertising playback system can work with and choose one that allows those specs.
H.264 wont let you export over 4K.
