Hi all,
I recently updated to CC2018 and have encountered a problem with an ongoing project.
I have a couple of lightboxes that are disabled by default and only enabled by clicking on triggers. Now before the update everything worked normally and I could click on elements behind the area where the lightboxes would pop up. Now on the new version they block the elements although you can see them normally. I tried exporting with and without the lightboxes so I know it must be them.
This is the version that still works normally: www.wattmarck.com
and this is the new version where you can no longer click on the desktop elements behind the lightboxes: www.wattmarck.com/wip/explore.html
The triggers are the buttons on the taskbar on the lower part of the page.
I hope someone can help me because I have no idea about how to trubble shoot this. I'm not even sure if its connected to my upgrade to CC2018 reopening the project on a reinstalled CC2017 didnt solve the issue.
Thank you!
Could you please
Then we will have a closer look.
I cannot escape from either lightbox.
The first version works as expected here (if one finds the cloe button ), the second doesn’t. I think we can fix this when having a look at the .muse file.
