VIDEO EXPLANATION AND FULL DOCUMENTATION OF PROBLEM
SFTP layer problem: Dreamweaver and WPengine Hosting problem - YouTube
Please watch this video
Error: IDD_SSH_KEY_CHANGE_DIALOG
FTP Log (from Dreamweaver) : Username and password incorrect
FTP Log (from WPengine server) : setegid(): Operation not permitted
Problem:
Dreamweaver can not connect using SFTP once an IP, username, password are changed
DWR must be uninstalled, the roaming folder deleted, and STE files imported again to reconnect.
Does not happen with ALL servers, at this time is specific to AmazonAWS (more specifically the host WPengine)
Expected:
When SFTP connection info is updated and saved the connection should work.
To compound the problem:
Adobe DWR support chat says it's WPengine
WPengine support chat says it's Dreamweaver
Conclusions: one or both of the following are true
A: Dreamweaver is not connecting to SFTP correctly
B: WPengine is restricting something that Dreamweaver specifically does
(I believe that WPengine is using Amazon AWS)
To recreate the problem:
WPengine:
Create an SFTP connection, Save it
Dreamweaver
Connect using SFTP user/pass setting on port 2222 and upload files
WPengine Hosting
Change the SFTP password
Update the password in Dreamweaver
Try to reconnect
=> failure, intermittent
WPengine Hosting
Change the IP address
Request an IP migration
-or-
Switch from PHP 5 => 7
=> failure, guaranteed
Links to all tickets:
Adobe Forum:
Adobe DWR bug report documented here:
35211247 "dreamweaver-stfp-error-id-ssh-key-change-dialog"
Dreamweaver STFP error "ID_SSH_KEY_CHANGE_DIALOG" – Adobe Dreamweaver CC: Feature Ideas
WPengine Support Ticket documented here:
Request #1155186 -
WPengine Rep: Connor - https://help.wpengine.com/hc/en-us/requests/1155186
Just to be sure, did you try and edit a Wordpress Template in Dreamweaver and try uploading the template using Dreamweaver? Do you have a case number for your interaction? If so, can you send it to me over a private message? To send a private message, click my picture and use the Message button. We will get in touch with you for investigation.
Thanks,Preran
I built the template from the ground up IN Dreamweaver. Every single line on every PHP, JS and CSS file was written by hand. This is not a "junk theme" from a template website, I am using DWR as my IDE to develop PHP
