Learn about Edge Delivery Services in upcoming GEM session
SOLVED
HTTPService Desperation
Avatar
Level 1
This is a desperate situation for me...
I have a few HTTPService's ready to be called when
necessary... however, I have noticed that after about 5 minutes,
the service (any of them) is sent again. I have tried to implement
concurrency="single" and also a httpService.disconnect(); after
each of the responses... no go. This is so frustrating! This is a
VERY desperate situation for me. I would appreciate some
knowledge!
1 Accepted Solution
Avatar
Correct answer by
Level 1
Well, I learned something new... after creating my own trace
function and writing a log to the server, i found out that when you
create a popup and initiate a Timer class, that Timer class is not
remove along with the Popup. Thus the HTTPService was called once
when i manually called it, and once more when the Timer officially
ran out.
Word to Adobe: when a child is removed from the display list,
so should everything within that child be also. Real nice.
Thank you for your help anyways, Greg. You led me to this
conclusion.
Avatar
Former Community Member
Describe how you are using your HTTPService. How are they
sent, as in what triggers calling the send() method for them? Need
more info on your situation.
Avatar
Level 1
I've defined and HTTPService as an MXML Component with an id
of myService. I simple call a function that executes
myService.send();
Here's a sample HTTPService that I'm calling:
<mx:HTTPService id="myService"
url="/webservices/assetDelete.cfm"
result="handleRemoveVideoPlain(event)"
fault="handleRemoveVideoFault(event)"
resultFormat="text" concurrency="single">
Avatar
Yes, but I'd like to know more about what calls the send()
function of this HTTPService, the timing etc. What contains that
component, how is send() called in your case, etc.
Avatar
Level 1
I'm not able to post my exact code due to restrictions but
this is the exact process:
Button:
Calls a function to create a PopUp that controls the creation
of variables and media ...
PopUp:
Varialbes are created are sent to a Bindable textfield @
parentApplication and a root Function is called.
@root Function:
Removes the previous PopUp, creates a new StatusPopUp and
executes the request to my HTTPService. The service is set up per
the above code.
HTTPService result:
The result removes the StatusPopUp, parses the xml response,
and creates a final Alert.
That's the process...
Avatar
So user clicks a button, fills in some information in a
popup, closes the popup, and a new status popup appears, and the
HTTPService is called? Can't imagine why it gets sent multiple
times.
I still think it should be possible to boil this down to a
greatly simplified sample app that still at least shows the
structure of the app.
Avatar
Level 1
http://www.dcolumbus.net/httpservice/
That's a barebones duplicate of what I'm doing in my other
app... and this far I have not noticed it happen. This really
sucks. There are differences between the two:
1) I'm using CF as my server-side script.
2) We're using sessions for user login and such.
I cannot duplicate the exact environment, but this will at
least give you insight into how my App is structured.
Avatar
I can't imagine how an HTTPService is being called twice,
unless it's send it being called by some event that fires twice
when you think it should be called once.
You might be able to have a Boolean variable okToSend set to
true, and set it to false after the result handler finishes, that
way it won't fire twice. But then you need a way for it to be set
back to true when appropriate.
Avatar
Correct answer by
Level 1
ran out.
conclusion.
