Losing image size / resolution when exporting!
Aug 27, 2018 Aug 27, 2018
I have read everything I can find, have checked and rechecked my settings and I can't figure out the issue.  My raw image is 17.6 mb, when I import the image and do some adjustments in Lightroom and export it, it is only 1.2 mb.  I have checked the slider is at 100 for quality and it is set to 300 dpi on export.  What am I missing?  I even imported the image again, made no adjustments to it and exported it and it is at 4 mb.  Any ideas?
4.4K
LEGEND , Aug 27, 2018 Aug 27, 2018
Yes, that's it, 1834x2755 is a little small for a 16x24 print. To get an export large enough, you'd probably want 200 pixels per inch, try these export settings
Moved from Creative Cloud forum.
JPG is a compression technology. It compresses your image with extremely minimal loss of quality. So there is nothing wrong with a result of 1.2mb. It does not mean a loss of quality (other than the extremely minimal amount caused by compression); it does not mean a loss of resolution.
In fact, looking at megabytes is the wrong thing to do. It misleads you and causes you to take unnecessary and even harmful actions.
What you need to look at is the exported image with your own eyeballs; how does the quality look? I'm sure it looks fine (because it is fine). Also, look at the number of pixels in the image, are these the number of pixels you expected when you did the export? I'm sure it is (because Lightroom gets that right too).
Thanks For the help. i wouldnt normally have an issue except my client wants to have a 16 x 24 print made and the print lab is indicating it’s not a high enough resolution to print it that size.
Are there more specifics? What is the size in pixels of this export? You may have to instruct Lightroom to provide more pixels when you export.
I think what you are looking for is the "dimensions 4928x3280 and cropped 1834-x2755" . Is that what you are looking for?
Got it!  Thank you!  I had no idea that's how you did it!  xoxo appreciate it!
brendak13044509
CORRECTION
Uncheck the "Don't Enlarge" box
First: DPI is only an indication how a picture should be printed at 100%. Infact you could add this parameter from 1 to very high, without changing one single pixel of your image. As a rule of thumb this parameter is set to something between 200 to 300, without having any influance on the quality.
This is different for an other parameter pair: resolution in pixels. You sensor has a physical resolution and that one will determine the size of your picture. There is generally no good reason to increase that resolution to get better image quality.
The sensor is normally colour blind (favon sensor from Sigma is an exception to this). Colour is captured by adding filters to the sensor pixels. Normally the are arranged in what is called a Bayer pattern. Developping RAW pictures means interpolating these Bayer pattern values into real colour information. Ech pixel is availablein 12 to 14 (most modern sensors have 14 bits) bits, compressed in a nondestructive way. So this means that in a worst case scenario and with 14 bits a Raw picture has a storage need of Xres*Yres*14bits/8bits+some bytes for storing parameters needed.
A Jpeg file has 3x8bitsxResolution, so this file should be bigger in size, if there would not be mathematical transformations, allowing to rearrange the pixels in such a manner that it is easy to compress. The aim here is to transform in a way that is effective but not or barly noticable for the human eye. This process is destructive, meaning that a compressed image cannot be reconstructed to be exactly equal to the original. The quality factor tells here, how much of the data gets lost. Highly compressed images show noticable artifacts. At a quality factor of 100 (12 in Photoshop), you do not notice any loss of quality, but even then, your picture may be highly compressed. The compression rate depends on the image. An image having only one colour would be best compressed. In the same sens, images with a lot of changes are dificult to compress.
A property of Jpeg is that when you open a Jpeg file and you resave as Jpeg without modification, the introduced artefacts will increase. So resaving will make your image worse.
I suppose that your customer needs 16x24 inch pictures, which is quite big. You need to know at what dpi this size is needed. Inches and dpi will translate into pixels. There is the use of this obscure dpi factor. Or for a given pixel size and a given print density you have a given size you can print.
A 24 x 16 inch picture can be printed in good quality at 200 dpi meaning that your picture should have a pixel size of 4800x3200. If you camara produces smaller images, you can enlarge a little bit. If it is bigger, export with more dpi, ie keeping the picture at its native pixel size.
Btw, print quality could be still good enough at 150dpi or even 100dpi. Generally I prefer resizing in Photoshop, because I have more influence on the quality. Photoshop is quite good in interpolating pixels in an intelligent way.
If we learn your camera, I could advise on how to proceed best.
Remark: Bayer pattern and Jpeg compression and also dpi can be looked up on Wikipedia in detail. There are also other formats of interest explained: Tiff, raw, PSD, ...
ABAMBO | Hard- and Software Engineer | Photographer
