In the latest Lightroom Classic Update 7.5 I cannot specify the starting number when I wish to rename photographs and start with a certain Start Number.
In previous versions of LR Classic, there was a field that I could enter a starting number. That field is not available. I hope this screen shot is helpful. In this instance, I had started a numbering sequence from -001 and had renamed and numbered 4 images. I then wanted to pick other images, and start the numbering sequence at -005 and could not specify this.
I did a quick test, and the Sequence # renaming token is working in my LR. In the File Naming drop-down, please do Edit and post a screen shot of the Filename Template Editor, e.g.
John, thank you very much for your willingness to help. I'm not sure what had gotten changed, but once I worked with this by changing several of the settings, I was able to get the Start Number box to show up, as it always has before. Again, THANK YOU!
T.J.
Glad you got it resolved.
