WIN10, Outlook 2016, IE11, Acrobat DC, web link direct to pdf will not open unless acrobat is already open.
receive the error message:
please let me know if anyone else has had this happen and if there is a solution.
thank you,
justin
Hi Justin,
Sorry for the delay in response.
As the issue persists in new user account as well, please contact the support using this link: Contact Customer Care
-Shivam
Hi Joostin420,
As per the issue description mentioned above, you are facing issue with web links in a pdf, is that correct?
Could you let us know dot version of Acrobat installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Also, would it be possible to share the pdf file you are working with to replicate the issue at our end? To share the file here in the forums, refer to the steps given in this link: How to share a file using Adobe Document Cloud
You may also share the link for the pdf via private message - How Do I Send Private Message
Let us know if you need any help.
Shivam
no; a link directly to a pdf from an email within ms outlook 2016 opens acrobat dc as expected, but the error message above is received.
if acrobat dc is open prior to opening a link directly to a pdf from an email within ms outlook 2016 the pdf will open normally as expected.
thank you,
justin
Hi Justin,
Would it be possible to share the pdf file you are working with to replicate the issue at our end? To share the file here in the forums, refer to the steps given in this link: How to share a file using Adobe Document Cloud
You may also share the link for the pdf via private message: How Do I Send Private Message
Shivam
hello,
please see link: https://www.saba.edu/images/oer.pdf
WIN10, Outlook 2016, IE11, Acrobat DC. when this link is received within an email via ms outlook 20016 and the link is opened direct to pdf it will not open with acrobat dc unless an instance of acrobat dc is already open. we have adobe acrobat dc set to open pdf with the application. we receive the error message above.
thank you,
justin
I have already tried the "repair installation" without any changes - issue still remains.
I will try resetting preferences and report back.
thank you,
justin
removing the preferences folder resetting preferences made no difference.
thank you,
justin
Hi Justin,
Try removing Acrobat DC using cleaner tool found here: Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs , restart the computer and then reinstall Acrobat DC from here -Download and install Acrobat DC subscription , reboot the machine after installation and try again.
-Shivam
hello,
so far same exact results with 6 installations. have also tried removing with cleaner and reinstall to humor..
thank you,
justin
Hi Justin,
Could you try replicating the issue with Acrobat in a new user account on the machine and check?
To create a new account - select the Start button, then select Settings > Accounts > Family & other people > Add someone else to this PC.
-Shivam
hello,
to clarify.... the same error is replicated on 6 different workstation installations I have tried... I have added another user account numerous times already... I am able to replicate the error/issue with every workstation. adobe acrobat dc pro is set as the default program for viewing pdf's. adobe acrobat dc pro ver.2018.011.20058
WIN10 pro x64, Outlook 2016, IE11, Acrobat DC. the resulting error is what is received if an instance of adobe acrobat is not open prior to clicking web link direct to pdf within the body of an email within outlook 2016.
thank you,
justin
Hi Justin,
-Shivam
