I'm using RH HTML X5.0.2. I accidentally clicked the
"Publish" button rather than the "Preview" button after Generating.
I've never setup any Publishing preferences so I have no idea what
it's doing! When I try to open the project from Version Control, I
get a msg: "This project is already open in another instance of the
application."
The button would have only been enabled if something had been
configured as a Publish destination. You may find that you need to
give RoboHelp HTML the three finger salute and open it up fresh.
I'm not sure. I suppose it may. If RoboHelp had files in a
state of limbo I suppose it could. I've never worked with the
RoboSource Control server so can't say.
I don't use RSC either but I'm sure you could do a check on
the files in the RSC database to see if they contain your generated
changes. If so, you should just be able to check them out and
continue.
