After installing Acrobat Pro XI I receive an "error 16" configuration error message when I launch the program. I am using Windows 10 and the program was previously installed and working fine. However, my hard drive crashed and waw replaced. I am still using Windows 10. Can you help?
Hi Geoffreyely,
As per the issue description mentioned above, you are getting error 16 when trying to launch Acrobat XI, is that correct?
Try launching Acrobat as an administrator using the steps given in the following link and check if that works
Run an Adobe program as administrator | Windows 7, Vista
If that doesn't work, try the troubleshooting steps given in this link: Configuration error in Adobe Creative Cloud or Adobe Creative Suite
You may refer to the steps given in the following forum t
...After trying all the other fixes listed here, I was still getting this message on Windows 10, It is because the program wants you to run as an administrator. G
o to the Acrobat 11 icon and right click. Go to properties and click. Choose compatibility tab and click. Choose (click) run as administrator and apply. Close out. You now be able to run the program!
Hi Geoffreyely,
You may refer to the steps given in the following forum threads discussing the similar issue:
ACROBAT XI PRO error 16 problem
Let us know if you need any help.
Shivam
I tried the solutions you recommended but to no avail. Anything else you can recommend? Is there someone I can talk to??
Hi geoffreyely,
Try enabling hidden admin account on the machine, login into that account and launch Acrobat from there. Refer to the steps given in the following link for the same: How to enable the hidden administrator in windows 10 - Microsoft Community
You may also contact support using this link: Contact Customer Care
Shivam
I tried to use hidden administrator with the lusrmgr,msc but the snapin would not allow addition of a new user
I tried your suggestion. It did NOT work. Is there someone I can speak to on the phone or by chat?
Hi geoffreyely,
You can contact support using this link: Contact Customer Care ( sign in to begin > select account issues > Adobe ID and signing in > show me my contact options > and select from chat or phone).
-Shivam
