I am working with a 2018 MacBook Pro.
I was working fine with Acrobat DC and the following day continuing on it failed to open any PDFs. I uninstalled and re-installed but it had the same issues.
I called Apple Joint Venture for assistance and the operator suggested I create a New user on my Mac. We did this and reinstalled the Acrobat DC on the Test User. This seemed to work but its not ideal as all of my work is on the other user name account.
Can someone please advise how I can get the original program working on my account?
Try opening a PDF. Look on the Window menu. Is it listed? If so try Window > Tile > Horizontal.
Hi terryl,
As per the issue description mentioned above, you are unable to open any pdf using Acrobat, is that correct?
Could you try following troubleshooting steps:
1- Reboot the machine once if you haven't already and check if that helps.
2- If that doesn't work, check if an update is available for Acrobat using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again.
3- If issue still persists, try the troubleshooting steps given in the following forum thread under post#3:
Acrobat Pro DC won't open files on Mac
Let us know if you need any help.
Shivam
Thank you for your input Shivam but this was the solution below
Hi
Thank you so much this worked I very much appreciate your help.
