When trying to install Photoshop Elements 10 on my Mac... I see "“Install” can’t be opened. You should eject the disk image."
I've tried following solutions on here but nothing has worked so far, I've tried install > show package content > Contents > Mac OS > Install... this shows the same error message that install can't be opened.
I'm not sure what else to try?
Thanks in advance
K
Thank you, the solution above that suggested looking for a log file, didn't work, for some reason there was no log file at least nothing I could locate using the suggested solutions.
I did manage to install PSE 10 eventually by doing the following:
Opening Terminal (I just searched on my Mac)
This kicked the i
...Copy link to clipboard
Exactly which version of the operating system?
Below is about CS6 (and earlier) but your PSE-10 is about the same age
CS6 and earlier programs have not been tested and will not be updated for Mac El Capitan or later operating systems
-which means that you try to use CS6 and earlier at YOUR risk of having problems due to Apple updates
-Apple did not maintain backward compatibility with old programs in El Capitan or Sierra
--Adobe has a workaround to Apple's problem of not maintaining backward compatibility
--READ HERE https://forums.adobe.com/thread/2301916 for an Adobe solution to installing old programs, including a link to installing the old Java runtime that is required
--Also read for more information https://forums.adobe.com/thread/2458382
This kicked the installer into gear and I finally have it installed
